January 3rd - HDTV Predictions for 2014 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-02-2014, 11:01 PM - Thread Starter
Braden Russell's Avatar
Today's Show:
Time for the HT Guys to look into our crystal ball and try and predict the HDTV and Home Theater landscape for 2014. Our crystal ball is never as clears as a good HDTV but we give it a shot nonetheless.
We also discuss:
  • Netflix Knocks a Dollar Off Its SD Streaming Service for New Users
  • LG reportedly will debut webOS TV at CES
  • NPD: IPTV installed base will surge over 2 years
  • Simplestream readies free live-TV streaming app
and a lot more...
listen now - mp3
Braden Russell
Host, HDTV & Home Theater Podcast
Check it out at www.htguys.com
Braden Russell is offline
post #2 of 2 Old 01-07-2014, 11:48 AM
HFGuy's Avatar
Quoted: 99 Post(s)
Liked: 61
Great show as always, thought I would comment on the volume control of separates.
Any audio chain will consist of multiple gain stages. The user only cares about the total gain, total gain translates into SPL at the output of the speakers. In separates the power amplifier will have a fixed gain, and the preamp will have variable gain. So the preamp will adjust its output signal to appropriately drive the power amp given the fixed gain of the power amp.
AV receivers have this same setup but the "preamp" section sits right beside the power amp, they will NOT change the gain of the power amp. basically when it comes to the volume control separates and a receiver are exactly the same.
HFGuy is offline
Reply AVS Forum Podcasts
