Beamr Bitrate Bonanza - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Scott Wilkinson
post #1 of 6 Old 08-15-2014, 11:40 AM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1330 Post(s)
Liked: 3875
Dror Gill, CTO of Beamr, explains his company's bitrate- and storage-reduction technology, including its image-quality measurement tool that is used to iteratively and automatically assess the image quality of JPEG photos and H.264 video, how consumers can use Beamr's JPEGmini to reduce the size of their photos without reducing image quality, how video-content providers are using Beamr Video to reduce the size and bitrate of their content with no loss in quality, plans for the future, answers to chat-room questions, and more.
Like AVS Forum on Facebook
Follow AVS Forum on Twitter
+1 AVS Forum on Google+
fookoo_2010 likes this.
Scott Wilkinson
Editor, AVS Forum
Scott Wilkinson is offline
post #2 of 6 Old 08-15-2014, 02:58 PM
fookoo_2010's Avatar
Quoted: 231 Post(s)
Liked: 80
Fascinating, the future of reduced bit rate for streaming is literally around the corner, if not here already.
fookoo_2010 is offline
post #3 of 6 Old 08-16-2014, 02:55 PM
elario's Avatar
Quoted: 42 Post(s)
Liked: 65
It's important to note that Beamr have made no improvements to the quality possible at a given bitrate.
elario is offline
post #4 of 6 Old 08-17-2014, 03:41 PM - Thread Starter
Liked: 3875
Exactly correct. Their goal is to preserve a given quality level at a lower bitrate.
Scott Wilkinson
Editor, AVS Forum
post #5 of 6 Old 08-17-2014, 04:38 PM
elario's Avatar
Quoted: 42 Post(s)
Liked: 65
Their goal is to further compress already compressed content as much as possible without 'noticeably' lowering quality. 'Noticeably' as according to their quality metric. It's a rather idiotic premise since it requires the content to already be lossy encoded at an arbitrary bitrate.
If we take a specific, unchanging source - for example the latest X-Men movie: if you feed Beamr video an uncompressed deliverable, it would give you an encode that is 50Mbps+. Because that's the only way that you can achieve something almost indistinguishable from source....very high bitrate.
If you feed it the movie - this time already compressed to 8Mbps H.264 - it will give you maybe a 6Mbps output, because it's quality metric feels that it is 'about the same'.
If you feed it the same movie, this time compressed to 3Mbps H.264, it will give you an output of maybe 2Mbps.
You can surely see the problem. It's the same movie, yet Beamr has given us 3 widely different bitrates. It's not an absolute metric. It doesn't suggest to us what bitrate we should use to deliver good quality content. For content providers it's completely useless since it requires an input that has already been encoded at an arbitrary bitrate.
Beamr won't tell you what bitrate to deliver your content at. You feed it a video and it simply re-encodes it at a lower bitrate and says "hey, this will look approximately the same". Anyone with a mathematical mind should see the problem here. Small differences are inherently indistinguishable. It's a parlour trick. You can achieve the same results by randomly choosing a % between 5 and 20 and re-encoding a clip with that percent less bitrate. Guess what - most people will not tell the difference. Whoop de do. You save money on bandwidth. Send your cheque to me, thanks.
Unfortunately, I think what their technology does, and probably the entirely of what i've written, will go right over the heads of most readers. The comment by fookoo_2010 should be proof of that. I'll say it again, Beamr have made no contribution to encoding efficiency. Whatever quality their software can achieve at a given bitrate... was already acheiveable at that bitrate with the existing encoders - the same encoding libraries that they use in their software without giving credit to the original developers.
elario is offline
post #6 of 6 Old 08-19-2014, 01:18 AM
Quoted: 231 Post(s)
Liked: 80
Really? I think that you are too enthralled by whatever the bit rate number is and that any reduction in that bit rate results in an inferior stream or media that you think that you can detect. If one cannot see the difference, what more can one want? I will give you a counter example to your argument: the initial release, not the Fincher version, of The Girl with the Dragon Tattoo in the American release versus the Swedish release on BR. The American release has half the bit rate of the Swedish version and they were indistinguishable on a professionally calibrated 50" Panasonic plasma. Your above logic assumes that whatever has been encoded has been done optimally in terms of bit rate. If you have any kind of programming experience, you should know that is not always true. I would submit that you have missed the boat when it comes to Beamr.
Reply AVS Forum® Podcasts
frontpage , Home Theater Geeks
