March 24th - Gefen Wireless HDMI Adapter (EXT-WHDMI) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-24-2009, 01:18 AM - Thread Starter
Braden Russell's Avatar
Today's Show:
One issue many of us come across when setting up our home theaters is that the TV would look great in a particular spot in the room that is not necessarily the best spot for the source equipment. The dilemma is how do you get the video to the TV or projector. Gefen has you covered in this case. Their new wireless HDMI adapter will transmit HDMI audio and video up to 30 feet using Ultra-Wideband technology. But that is going to come at a cost. For that capability Gefen is selling the WDHDMI for $999. Still for some of you that cost is less than the cost of ripping up walls and running physical cables. more...
Listen now - mp3
Braden Russell
Host, HDTV & Home Theater Podcast
Check it out at www.htguys.com
Braden Russell is offline
post #2 of 7 Old 03-24-2009, 04:10 AM
wall-e's Avatar
The MP3 file is empty.
EDIT: it's fixed now.
wall-e is offline
post #3 of 7 Old 03-24-2009, 12:50 PM
Unearthed's Avatar
No HD audio = no dice. Especially for a grand...
Unearthed is offline
post #4 of 7 Old 03-24-2009, 01:57 PM
Big Lag's Avatar
Why are you saying, "no audio"? It says, specifically, it does audio.
Big Lag is offline
post #5 of 7 Old 03-24-2009, 02:13 PM
Mac The Knife's Avatar
Liked: 24
I suspect the lack of support for HD audio formats won't matter to most people, since most people will only be using it for the connection from the receiver to a front projector NOT from the source to the receiver (or maybe something like a wall mounted Plasma display where they dont want to run cable up the wall) . In both those cases the audio is handeld by the receiver, so all the need is the video on the wireless link.
Are there even any people out there who still go directly from the source to the TV, without using a receiver? Or who don't co-locate the receiver and all the sources?
Mac The Knife is offline
post #6 of 7 Old 03-24-2009, 05:59 PM
Unearthed's Avatar
I said "No HD audio."
post #7 of 7 Old 03-25-2009, 09:39 AM
stereomandan's Avatar
Exactly. I'm struggling to find cases where HD audio would come into play. Unless you have your components spread all over your room, it shouldn't matter.
I'm hoping the price on this comes down, or other competition shows up, because I would love to have something like this to send the video to my projector when I get my final theater done.
Dan
stereomandan is offline
Reply AVS Forum® Podcasts
