September 23rd - Optoma HD33 3D 1080p Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-22-2011, 10:11 PM - Thread Starter
Braden Russell's Avatar
Today's Show:
One complaint we have about 3D is that it needs to be immersive if you are to appreciate the effect. Since most of us can't afford 100 inch plasmas, a front projector is pretty much the only choice you have for this type of experience, albeit an expensive one. Enter the Optoma HD33 (Buy Now $1500). Its a 1080p DLP projector that supports 3D. more...
Listen now - mp3
Braden Russell
Host, HDTV & Home Theater Podcast
Check it out at www.htguys.com
Braden Russell is offline
post #2 of 2 Old 09-23-2011, 05:17 PM
outspoken's Avatar
after 118 years you'd think we'd have this 3D thing down by now. We seem to be just reinventing the wheel.
outspoken is offline
Reply AVS Forum® Podcasts
Optoma Hd33 1080p 3d Projector
