Vizio VX32L - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-19-2008, 01:35 PM - Thread Starter
xboxman123's Avatar
Hey guys, I was wondering if any of you have ANY calibration settings for the Vizio VX32L?
xboxman123 is offline
post #2 of 9 Old 03-19-2008, 02:54 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
screens are quite frequently different from unit to unit.
Go get a disc and a blue filter and you can do some basic contrast/brightness color/tint setup.
Anything more involved than that NEED to be done with a colorimeter.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 9 Old 03-19-2008, 03:32 PM - Thread Starter
xboxman123's Avatar
Thank you, I have done all the various discs out there, from AVIA to the Halo Calibration to HD DVD DVE Essentails. If I get a colorimeter such as the Datacolor SpyderTV will there be a drastic difference? Enoogh to warrant the 200 dollar price tag?
post #4 of 9 Old 03-19-2008, 03:59 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
the colorimeter to get in the sub-$200 range is the i1 display 2 (lt variant comes with netured software and lower price point, but the packaged software is only useful for PC calibration).
Pair that with software from either calman(added expense but user friendly) or HCFR (free but steep learning curve), and your service menu and you'll be able to get a very accurate greyscale and be able to more precisely set your white level, black level and to adjust both your color and tint.
The biggest get will be the white point and greyscale, it's hard to deffine "worth it" my wife doesn't think my time spent playing with the TV is worth it. And that's just my free time after she goes to sleep. Personally I'm ready to take another pass at it tonight after she goes to sleep. Quantifing perceptual difference is hard to do. At least you can use it to calibrate your PC too.
white point: cie location and color temprature of white
white level: lumanace of white
black level: luamance of black
grey scale: the tracking of grey staing at the same point as white as the lumance is reduced
color and tint controls do different things based on different set designs.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 9 Old 04-01-2008, 07:10 PM
jim.bennett's Avatar
Sotti-
Do you know how to access the service mode on the VX32L? Tried following the instructions here:http://www.bruzziforum.com/vbf/showthread.php?t=52 but none of the methods worked.
jim.bennett is offline
post #6 of 9 Old 04-03-2008, 09:41 AM
ashman5's Avatar
Originally Posted by jim.bennett View Post
Sotti-
i'm looking for this code also.
ashman5 is offline
post #7 of 9 Old 04-03-2008, 02:38 PM
I got a hold of the service manual for the VX37L (should be almost identical to the VX32L except for size) and there is nothing in it telling how to access a service mode, so I believe this TV does not have one.
post #8 of 9 Old 04-03-2008, 03:25 PM
ashman5's Avatar
probably has to be accessed through the service port
ashman5 is offline
post #9 of 9 Old 05-11-2008, 08:02 PM
Sutanreyu's Avatar
Could you go into that a bit further? I'm new to this deal and I need somewhere to start, (in terms of calibration). I don't want to plunk down a ton of cash on equipment that will only be used as a one-time deal, (not just yet, anyway).
Sutanreyu is offline
Reply Display Calibration
