(Update: It's no longer just greyscale calibration as I've added some new sections on colour decoders, primaries/secondaries, etc).
Over 250 hours of research and writing have gone into this guide.
This guide came about as the do-it-yourself (DIY) crowd has been asking more and more about greyscale and colour calibration over the years. With reliable colorimeters now under $150 USD and excellent free software like ColorHCFR available, it's a no-brainer that all DIY enthusiasts have some sort of colorimeter in their toolbox. If for no other reason than to better appreciate the complexities of colour calibration when they speak to a professional calibrator.
Countless number of calibration guides have been published prior to this one. Some of them quite good. The problem I found is that most assume that the reader already has the required equipment and knows exactly how to set it up properly. Most guides also assume that the reader has a good understanding of terms like D65, stimulus, CIE, etc. Some even provide links to highly technical documents as "required reading". Yes, many of these documents are very informative, but not everyone wants to earn a doctorate in colorimetry so that they can set their greyscale properly.
My guide takes a step backwards and makes the assumption that the reader has absolutely no knowledge of colour calibration. In fact, this guide assumes that the reader doesn't even *know* what "greyscale calibration" is! I explain what it is, why it's important, list the tools needed, where to get them, and walk you through the process from start to finish.
I hope you find it useful.
Comments and feedback are appreciated. I'm still tweaking portions of it as questions arise.
This is an option but it's beyond most people's budgets. The i1Pro is a spectroradiometer that remains accurate (doesn't drift) as much or basically not at all. It lets you keep your calibrate i1 Display Pro (Display 3) meter accurate. For more info see the"FAQ: Which meter is right for me?" in my sig. Read the second on using 2 meters.
Originally Posted by Pres2play /t/1029594/guide-greyscale-calibration-for-dummies/180#post_24378607
Thanks, Kal. The ChromaPure site shows the bundles that are available. Which version of ChromaPure should I go with, OEM or Retail?
If you only want to calibrate TVs and projectors using ChromaPure, the OEM is fine. The retail boxed version also comes with X-Rite software to calibrate PC/MAC monitors automatically (.iCC profiles). Choose whichever works for you.
Can you explain a little further the gamma calibration for sets that don't have 10-point gamma control? My display has presets (-3, -2, -1, 0, 1, 2, 3) and I can try each one, as you suggest, but which measurement mode(s) do I select in the Gamma module?
Originally Posted by Pres2play /t/1029594/guide-greyscale-calibration-for-dummies/180#post_24384335
You don't select any mode. If all you have is gamma presets then use the gamma preset value that is closest to 2.22. In this instance since you don't have the 10pt gamma controls you just select the best gamma preset. That's all you can do. You need not to use the gamma module since you have no way of calibrating the gamma . Recheck brightness after changing the gamma.
It's not clear if I have to pick one of the measure modes (10%, 20% and so on) to find out which one of the presets will give me 2.2 gamma. According to Hungro, I don't choose any of the modes.
Originally Posted by hungro /t/1029594/guide-greyscale-calibration-for-dummies/180#post_24386139
I use Chromapure. By clicking the pre greyscale tab once it opens and you take a full 10pt greyscale measurement it will give you an average gamma value. Get this as close to 2.22 as you can by changing your preset value and then remeasure and check gamma again make sure to check brightness when changing your gamma preset value it could change then you'll have to readjust then measure and so forth. Just fallow the greyscale for dummies guide
but when it comes to gamma do the fallowing I told you. You might have to readjust the greyscale as well once you found the correct gamma preset. It's a lot of back and forth to get everthing calibrated.
I just watched a video of the grayscale calibration in real time at CurtPalme and it's pretty cool. Can wait for my package to arrive in a few days. Thanks for your help.
Originally Posted by Pres2play /t/1029594/guide-greyscale-calibration-for-dummies/210#post_24388240
Kal,
Just curious, I saw this in your article Colour Science: Understanding Gamma...The correct approach is suggested by the sRGB standard and has fairly recently been codified in a new gamma specification called BT.1886, which uses 2.4 as a starting point but adjusts the overall response curve depending on the black level and white level of the display. Like sRGB, BT.1886 recommends a gamma response that is higher at the top end than at the low end. A straight power curve of 2.4 is correct only if the display has a zero black level and an infinite contrast ratio, which no real-world display has....
OLED TVs have zero black level. Should I be targeting 2.4 gamma?
Originally Posted by Pres2play /t/1029594/guide-greyscale-calibration-for-dummies/210#post_24388919
Kal,
OLED TV does not have zero black level. Zero black level implies panel does not emit any light whatsover. Which current tech does not yet allow. Black level can be very low on top of the line pro panels, but don't confuse it with zero black
Some reviewers measured 0.001 for black on ANSI contrast pattern from a Samsung OLED, but also measured 0 CD/m2 from a full black pattern...could be some stray light from neighbouring white squares found their way into the probe or some ABL creeped in ...
Sent from my ALCATEL ONE TOUCH 6030X using Tapatalk
Originally Posted by mytbyte /t/1029594/guide-greyscale-calibration-for-dummies/210#post_24392713
You see this mentioned in all the reviews, and it's said OLED televisions are the only sets that can do this. It seems Samsung and LG are not doing a good job promoting this feature.
Not just one review, all reports say this. My question is why Samsung didn't include a 10-point gamma control on this very expensive set. What a bummer
Gamma is listed in the Advance Settings menu in all the picture modes, but it's only the presets I mentioned. I managed to enter the hidden service menu as well, and it's not there either.
I get a great picture, though. Just means I have less control.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
