Spyder3TV Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-13-2008, 02:46 PM - Thread Starter
hoyty's Avatar
Is the meter in the Spyder3TV package the same as all the other Spyder3 packages? Also in case anyone has older Spyder product and wants a Spyder3TV on the cheap you can upgrade at http://spyder.datacolor.com/s3tv_upgrade.php with your serial number.
hoyty is offline
post #2 of 21 Old 06-13-2008, 03:49 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
The electronics are the same ... the finish is different.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 21 Old 06-15-2008, 08:19 PM
drrick's Avatar
Michael, I was wondering the same thing as the OP, since I also got the e-mail. I don't mean to be dense, but just wanted to be sure of what you were saying--that the "new" spyder3 will not give us any improvement over a spyder2? Am I understanding you correctly? Thanks!
drrick is offline
post #4 of 21 Old 06-15-2008, 08:56 PM
Quoted: 41 Post(s)
Liked: 144
Greetings
I did not say that ...
There are two S3 probes out there. One with a shiny finish .. and the other with a dull finish. The Shiny one comes with the more $$ packages. The performance is the same for both types of S3 probes.
The S3 is supposed to be more accurate than the S2 ... and faster too.
Regards
post #5 of 21 Old 06-15-2008, 09:18 PM
Rayjr's Avatar
Quoted: 182 Post(s)
Liked: 223
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Michael,
Do you know if the spyder3 sensor will work with my spyderTV pro 2007 software?
RayJr
Rayjr is offline
post #6 of 21 Old 06-15-2008, 10:17 PM
Quoted: 41 Post(s)
Liked: 144
Greetings
If you had the S2 probe with the package, then it won't work with the S3 probe.
There might be a STV3 pro package in the works eventually ...
Nothing for now ...
Regards
post #7 of 21 Old 06-16-2008, 12:45 AM
mlaun's Avatar
I don't have much experience with TV's and HT but a lot with computer monitors.
I'm using a spyder 3 for computer moniters as well as an eye one. Both seem very close to each other, ergo: spyder 3 seems to be as accurate as the eye one. I did try a spyder II once was way off compare to the eye one.
mlaun is offline
post #8 of 21 Old 06-16-2008, 06:21 AM
Quoted: 41 Post(s)
Liked: 144
Greetings
Not to jump on you, but ...
I have spyder 2 probes that out performed my S3 probe by a wide margin. The S2 probes were closer to my spectrometer devices. That said, we then had an opportunity at the Datacolor facility to compare my S3 probe to 10 other S3 probes to test for accuracy. Turns out my S3 probe was the worst of the bunch and was tossed. The 10 others that they had varied in accuracy from "good" to "excellent." I took an "excellent" one as my replacement.
Lesson ... unless you have used a whole bunch of the same devices, saying that one's own experience with one device means that they are all like that is not good. These things are not high priced precision instruments so there will be manufacturing variance.
Sometimes you get a dog of a unit. But without the ability to see how well it compares to others, you can mistakenly conclude that the product does not work at all. All the while, 98% of others are getting good results from it.
Regards
post #9 of 21 Old 06-16-2008, 09:12 AM
mlaun's Avatar
I probably got a good III and an off II.
A shame that they vary so much. Beginners could have quite frustrating experiences. Not everybody has a spectrometer to compare his/her colorimeter against.
mlaun is offline
post #10 of 21 Old 06-16-2008, 11:05 AM
Lee Bailey's Avatar
Originally Posted by Michael TLV View Post
Greetings
Lesson ... unless you have used a whole bunch of the same devices, saying that one's own experience with one device means that they are all like that is not good. These things are pretty cheap to make and there will be manufacturing variance.
Sometimes you get a dog of a unit. But without the ability to see how well it compares to others, you can mistakenly conclude that the product does not work at all. All the while, 95% of others are getting good results from it.
Regards
Michael,
How does your new S3 perform then?
Lee Bailey is offline
post #11 of 21 Old 06-16-2008, 12:12 PM
Quoted: 41 Post(s)
Liked: 144
Greetings
It is performing just fine and replaces my older S2 devices.
Regards
post #12 of 21 Old 12-04-2008, 09:24 AM
hellerbrewing's Avatar
Can I use the Spyder3TV to calibrate my plasma as well as my LCD monitor? I don't really want something that contatnly monitors light and changes settings on the LCD, can I get away with one product for both?
hellerbrewing is offline
post #13 of 21 Old 12-04-2008, 03:51 PM
Bear5k's Avatar
This is the essence of why we had to quit recommending the S2 a ways back. The unit-to-unit variation was just too much.
I wonder if the S3's "quirks" have been fixed for use with phosphor-based displays.
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #14 of 21 Old 01-01-2009, 07:16 AM
David Susilo's Avatar
Quoted: 622 Post(s)
Liked: 588
Will the Spyder3TV software work with Spyder2 sensor? I dropped my Spyder3TV sensor (and cracked it) but I still have a couple of Spyder2 sensors. However, it doesn't seem to work with the software.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #15 of 21 Old 01-01-2009, 08:10 AM
Rayjr's Avatar
Quoted: 182 Post(s)
Liked: 223
Short answer.....no
RayJr
Rayjr is offline
post #16 of 21 Old 01-01-2009, 08:30 AM
Gregg Loewen's Avatar
Quoted: 24 Post(s)
Liked: 70
just email datacolor and tell them your s3 sensor is broken...they will send a replacement.
Ray...turn on your AOL IM !!
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is offline
post #17 of 21 Old 01-01-2009, 09:21 AM
Rayjr's Avatar
Quoted: 182 Post(s)
Liked: 223
Rayjr is offline
post #18 of 21 Old 01-01-2009, 10:17 AM
Quoted: 24 Post(s)
Liked: 70
ping me then!!
post #19 of 21 Old 01-01-2009, 10:22 AM
Rayjr's Avatar
Quoted: 182 Post(s)
Liked: 223
I can't see or contact you online.....we have a problem
Rayjr is offline
post #20 of 21 Old 01-02-2009, 12:02 PM
Ethenolas's Avatar
I have a 1080ub projector and can't seem to get the colors right...
Would you recommend spyder 2pro?
I have no experience calibration, but am good with computers...
OR
would you just recommend a calibration disc? (HD basics BD)
Ethenolas is offline
post #21 of 21 Old 01-02-2009, 12:05 PM
Quoted: 622 Post(s)
Liked: 588
for calibration software, just use HCFR software (freeware) and HD709 disc (free download). For the sensor, Spyder2 is enough for most people.
my home theatre
Reply Display Calibration
