Spyder3TV Sucks!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-25-2008, 11:15 AM - Thread Starter
mp006ltk's Avatar
I have owned the Spyder 2 Pro system for my computer and been very happy with it for some time. I decided to buy the Spyder3TV and was severely disapointed. The display had been previously calibrated with good old video essentials. I was hoping to gain the ability to read RGB levels to set color temperature the way I do my computer monitors, but no such luck. The only thing it can do is tell you which of your presets are closest to the mark. All the other settings were identical + or - 1 notch to video essentials. Basically it didn't do any better with color temp then me just eyeballing it. SAVE YOUR MONEY!!! Buy a calibration DVD and skip the Spyder. What erks me the most is that the device is fully capable of performing this function but it's intentionally crippled by their software. If someone were to write a program using the spyder for this application, I would think they could make alot of money.
mp006ltk is offline
post #2 of 10 Old 07-25-2008, 11:45 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 141
Greetings
The program is just an extension of the old spyderTV program but with the new 3 probe. Nothing has changed.
Some get this package in order to use the probe with other software like the free one available at this site ....That HCFr program.
Traditionally, it was the Spyder TV pro package that permitted grayscale changes.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 10 Old 07-25-2008, 12:52 PM
eddiscus's Avatar
Like Michael TLV had said the only reason to buy the package is to get the Spyder 3 probe to use with another software package. The Spyder TV 2007 pro was the package before the spyder 3 that would do greyscale. But for some reason the spyder 3 does not work with the 207 pro version of software. If I rember correctly they wanted near $ 1000.00 you were not upgrading from a previous version.
The really entertaining point is if you purchase their pro version of software at about 3K it comes with a spyder 3 probe. Although the license in the software will run with other probes.
If you are just wetting your feet then the spyder 3 with the HCFR software is an ok start. Although there are other beginner level probes that are better choices.
The Calman 3 with I1 Pro probe package offers a higher level of accuracy and a software package that includes alot of calibration info as well as screen groups for beginners to advanced users.
eddiscus is offline
post #4 of 10 Old 07-29-2008, 10:51 AM
tomhungtom's Avatar
Can I use Spyder3 Probe with HCFR 2.0.1 now?
tomhungtom is offline
post #5 of 10 Old 07-29-2008, 02:28 PM
eddiscus's Avatar
http://www.avsforum.com/avs-vb/showt...1#post14308341
eddiscus is offline
post #6 of 10 Old 07-30-2008, 11:08 AM
kronickidd's Avatar
i doubt it
kronickidd is offline
post #7 of 10 Old 07-31-2008, 05:05 AM
Rudy A-traxx's Avatar
I recently bought it in France and I am as disappointed as you are.
I can't do anything with their software, my projector has no tint or color settings but just RGB... hope I'll find a simple software that could drive the Spyder 3 colorimeter.
Do you know if there is a software - not expensive - on Mac ? Thanks
Rudy A-traxx is offline
post #8 of 10 Old 07-31-2008, 05:51 AM
mlaun's Avatar
YES. I have version 2.1 Beta 160 of HCFR which works just fine with the '3'.
mlaun is offline
post #9 of 10 Old 07-31-2008, 05:57 AM
mlaun's Avatar
AFAIK HCFR has a MAC-Intel beta and are looking for people willing to test.
Go to www.homecinema-fr.com . Be warned though, the site is in french.
mlaun is offline
post #10 of 10 Old 08-01-2008, 04:42 AM
Great for me since I'm french. But I thought it was not compatible with this colorimeter. I will check that with them and I'll let you know.
But I can see - in the previous post - that on Windows, the HCFR software seems to be compatible with the Spyder 3 TV colorimeter. I'll also check and I'll tell you...
Reply Display Calibration
