HTPC Panasonic AE-900U; Dell Inspiron, resolution quesiton - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-03-2008, 06:03 AM - Thread Starter
Bluedog225's Avatar
Hi all
It's been an long time since I visited. I have been enjoying my Panasonic AE-900u for a couple of years now. I recently got a Dell Inspiron HTPC running Vista. I have an approximately 8'x12' Mississippi Mud Light Fusion screen (on plywood).
Problem-When I set the computer resolution to the native resolution of the projector (1280 x 720), the image quality is not that good (when using the projector image as my computer screen). Going to higher resolution results in cutting off part of my desktop.
Is this as good as it gets? I've tried overscan on and overscan off.
Any suggestions or direction to a thread on the topic would be appreciated.
Tom
Bluedog225 is offline
post #2 of 4 Old 09-03-2008, 08:58 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Are you running VGA cable or HDMI? If VGA ... needs better shielding and hope the cable run is not too long.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 4 Old 09-03-2008, 10:19 AM - Thread Starter
Bluedog225's Avatar
Originally Posted by Michael TLV View Post
Greetings
regards
I am running DVI to DVI with a 6 foot cable. Looks like a low end cable (came with Oppo DVD player). Would a cable upgrade make a difference?
post #4 of 4 Old 09-03-2008, 01:46 PM
hithere's Avatar
Quoted: 12 Post(s)
Just a thought, but you don't have scaling for overscan enabled on the graphics card, do you?
hithere is offline
Reply Display Calibration
