Setting Blueray player before TV calibration question (IRE over HDMI). - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-25-2008, 01:18 PM - Thread Starter
cvearl's Avatar
Varios calibration documentation on many websites talk about first setting your "player" correctly before beginning calibration of the TV.
One area I am stuck on is IRE setting on a Blueray player (in my case the BD30) of either 0 or 7.5 DEPENDANT ON CONNECTION METHOD.
From HOME THREATERMAG...
When troubleshooting brightness for information below black, you can adjust the player's IRE. If there's a choice between 0 and 7.5 go with 0. On some sets this is called DARK for 0 and LIGHT for 7.5. Only have to adjust if you cannot get the drop shadow on the THX Optimization pattern on the DVD to appear when the brightness is turned all the way up. Setting IRE to 0 io so that "Below Black" is being sent to your TV. Otherwise the drop shadow sometimes cannot be displayed and Brightness settings cannot properly be made. This is echoed to some degree in THX's own documentation.
Avical's DVE User-Level tutorial at avical.com and Preparing the DVD p[layer for calibration before starting...
"If there is a black-level control and the composite or S-video output is being used, place it in the 7.5 IRE position (LIGHT). If component is being used, place it in the "0" IRE position (DARK)."
And lastly from Panasonics OWN manual for the BD30 BD Player on page 20...
"Black Level Control
Select lighter or darker for adjusting the black level control to the
desired setting for picture enhancement.
≥Lighter: When video is output from VIDEO OUT or S VIDEO OUT
terminal.
≥Darker: When video is output from COMPONENT VIDEO OUT
terminal."
So. You can see a common thread here. If component, set to DARK (0 IRE) and if composite or s-video, set it to LIGHT (7.5 IRE).
Any comments on this from seasoned calibrators is welcomed but more importantly, and the reason I post this is this...
What about when over HDMI!? No one talks about this IRE setting over HDMI. Anyone know the correct setting of IRE for HDMI output from your DVD or BD Player?
I am playing with calibration and I am perplexed by this one.
*EDIT* Here is more I have stumbled upon...
Oh and then I have found this... http://www.avsforum.com/avs-vb/showt...89#post4969789
Guess I have more reading to do. But at least the answer (upon a fast read through) appears to be in there.
C.
Panasonic 42" Plasma TH42-PZ85U
Panasonic Blueray Player DMP-BD35
Sony 5.1 Home Theater DAV-HDX475 (wish it was Panasonic but it's ok)
cvearl is offline
post #2 of 10 Old 10-25-2008, 01:37 PM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 64
HDMI is a digital connection, which should have defined levels, and there shouldn't be any change depending upon settings. Most likely the BD30 doesn't alter video levels for HDMI, so if you're using that connection then odds are the setting on the player doesn't have any effect and you really don't need to know anything about how analog connections used different levels for black.
alluringreality is offline
post #3 of 10 Old 10-25-2008, 01:56 PM
nicholc2's Avatar
Unfortunately, there is no simple answer to this question. It all depends on what video range your TV expects to see. Most of the time, a TV will expect Video black to start at 7.5IRE or bit 16. Therefore any level below that will be below black. Most computer monitors expect it to be 0IRE and take the full range from 0-255.
However, some TVs (mine included) still expect the full range and do not handle below black or whiter than white properly.
What you need to do is find a ramp pattern to display on your TV that goes from 0-255 and indicates the points below black and whiter than white. The AVCHD disc you can burn from this forum has such a pattern, btw. First pull up that pattern with your BD player set to 7.5IRE. Then set your brightness and contrast so that you can see every step in the pattern all the way from black to white.
If your TV handles the signal correctly, then you should see the black level below the three dots that indicate video black and it should look black. You should also see the white level above the three dots that indicate video white on the other side of the pattern and they should still be white.
If you see what is obvious clipping by your TV (white that looks reddish or pinkish), and no matter what you do with contrast or brightness that doesn't change, then your TV may want the full range. Change the BD player to 0IRE and repeat the test.
Without a calibration, that's the only way to be able to tell. Compare and choose which looks correct. Chances are if your TV is newer, then 7.5 will be what you want.
nicholc2 is offline
post #4 of 10 Old 10-25-2008, 02:01 PM
nicholc2's Avatar
Possibly, but that setting probably determines at what level video black is sent. I am not sure if that affects HDMI with the BD30, though. I haven't had a chance to test one yet.
nicholc2 is offline
post #5 of 10 Old 10-25-2008, 02:22 PM - Thread Starter
cvearl's Avatar
Thank you everyone. I will check to see if the darkness setting has any effect on blueray output over my HDMI. That should help.
But just off hand...
At the BD30's MFG's default setting of LIGHT (7.5), and running the Blueray version of DVE HD basics, the greyscale ramp does indeed show all the steps distinctly when I lower the contrast from 100 down to about 80 or so. Also, even at 100 on contrast the THX white crush pattern (6 squares or something or other) does not crush no matter what and whitest squares remain white to the eye even at 100 contrast.
I'll get back to everyone once I can try light versus dark on the BD30. But that said, in the owners thread I get alot of "leave it at light or you'll crush blacks" comments. But no one has actually addressed this as an "official IRE over HDMI best practice" type question.
C.
cvearl is offline
post #6 of 10 Old 10-26-2008, 11:11 AM - Thread Starter
cvearl's Avatar
Not sure if this is still accurate or not but...
Well, this post may not be 100% perfect scientific way to explain all this, but given the alternate, images really would help. Lots of jibber-jabber and jargon only goes so far. I'm simply amazed at how confounding video information has to be. What should be basic principles of video (think "atoms have protons, electrons and neutrons") seemingly require advanced degrees in video theory. Uggh. Anyway, here goes an attempt to convey knowledge to the layman....
- DVD MPEG is IRE 0.0
- IRE is the name of the group that set the standard
- 0.0 is the "total black" side of the scale. It goes to "total white" at 100.0.
- North America (will call it "USA" for purpose of this article) has black set at 7.5 and not 0.0. Blame lazy engineers from a long time ago. Because of this, all of our equipment is different from Japanese stuff. Or at least is SUPPOSED to be different.
- When a NTSC USA player gets a DVD, it's output is stepped up +7.5 IRE so the tv understands it and it looks correct. When an analog signal (VHS, cable, tv, etc) is inputted into a digital device, the device steps down the IRE by -7.5 so it is at proper 0.0 for digital needs (playback, capture, encode, etc).
SOURCE...
http://forum.videohelp.com/topic259098.html
Not even sure if I have answered this yet or not. But that was interresting but a few years old now.
C.
cvearl is offline
post #7 of 10 Old 10-26-2008, 11:50 AM
Quoted: 57 Post(s)
Liked: 64
The new stuff you posted is again about analog voltage levels. It isn't anything you need to know if you're using HDMI. Out of the 4 players with HDMI I've owned they've all appeared to do typical video levels over HDMI by default and black level settings have had no effect, which is why I would guess that would be the generally expected case with most devices.
If you want to test if the player is expanding to computer levels like nicholc2 was talking about, the AVCHD from the link below should work in a Panasonic Blu-ray player. Patterns 1 and 3 in the Basic Settings section wouldn't show any flashing lower than 17 or higher than 234 if the levels were expanded. If you don't want to burn the disk, then DVE has levels lower than 16 in the pluge pattern (I think they might call it something like -4% below black) and the disk should also have above white somewhere. Anyway, if you're able to see levels lower than 16 (black) or higher than 235 (white), then I think it's safe to assume you're getting video levels to the TV over HDMI. In short, if you can see all the bars that DVE mentions in the pluge then I say don't worry about it because the stuff you keep quoting is not relevant for HDMI.
post #8 of 10 Old 10-26-2008, 02:52 PM - Thread Starter
cvearl's Avatar
Fantastic response. Thanks.
They also meantion much of what oyu have just said here taken from that link I posted...
"2) For DVD players when using a digital output (DVI, HDMI).
When using digital outputs, your primary concern is to get the DVD’s image data output as undisturbed as possible. As simple as this might seem, design/price constraints, sloppy engineering, and ‘features’ can get in the way of transferring the digital data from the DVD intact. Always try to avoid using any image-altering features such as picture controls. These adjustments will usually have negative impacts on picture quality.
When using digital outputs, the major adjustment option you have is the one for digital levels. As is common in consumer labeling, the labels for this can be confusing. The most common labeling will at least hopefully show that you are making an adjustment to the DVI/HDMI digital outputs, and usually the options will read ‘Normal/Enhanced’ or ‘Normal/Expanded’ or ‘Video/PC,’ or some such label. The last pair of labels is clearer, as this adjustment is choosing whether or not the digital image data is correctly output using Studio (also called Video) levels, or is incorrectly re-mapped to PC levels. You should choose to maintain Studio levels by checking to make sure this option is properly set, usually by selecting the equivalent of "video" or "normal." Usually the default setting will correctly choose the option for Studio levels, but not always. Check to make sure....
Because you are using digital outputs, adjustments for analog outputs shouldn’t be a consideration. Unfortunately again, due to cost-saving designs sometimes analog output adjustments, such as those for IRE setup, are implemented digitally even though they have nothing to do with digital outputs. Here your concern is still to ensure that the digital image data is being left as undisturbed as possible. In a well-designed player, the IRE option will have no effect whatsoever when using digital outputs. If this setting causes any change in the image when using the digital outputs, you should use test patterns to see which option leaves data un-clipped. In this instance, the degree of clipping or image alterations may be severe, so Avia, DVE, or any good test disc will come in handy. In Avia, look for the moving near-black and near-white white bars; in DVE use the ramps (Title12:Chp14) and check for clipping (if you have access to Avia PRO, the Deep Ramps are excellent tests!). Use the IRE setup setting that maintains as much data as possible through to your display. The default setting may more likely be the preferred setting. Default is usually the 7.5IRE setting. This was reported to be the case on the Denon 3910; users should test this on their players and share model-specific observations to aid others!
With the hope that digital levels and IRE are conceptually disentangled, you should understand that the IRE setup option is really for the analog output, and shouldn’t have to be discussed when using digital outputs. Unfortunately, instead of implementing these analog adjustments in the analog domain, cost-conscious designs seem to be altering the digital values, which necessitates double-checking this option to make sure your digital levels are not being tampered with."
cvearl is offline
post #9 of 10 Old 10-28-2008, 09:20 AM
mtw4991's Avatar
I just calibrated by Samsung HL67a750 using DVE HD Basics(BD). I have the panasonic Blu Ray player-BD35 (brightness set at 0 by default) and Comcast cable both running HDMI to a Yamaha 663 avr. I have the 663 running HDMI to the sammy. I noticed that I was losing via clipping? the btb and wtw steps of the ramp right at the three white/black dots on each end for white/contrast and black/brightness.
My questions:
(1) should I "see" the next-to-last step at the 3 dots, then "lose" the last step past them?
(2) if so, is the 663 clipping the last 2 steps on each end?
(3) would running the HDMI video outs from the BD player to the sammy correct this?
(4) if I run the HDMI str8 and bypass the receiver, I lose 7.1 audio, because the BD35 doesn't have mutichannel analog outs, only the BD55 and I can't go another $100.
your advice is appreciated.
mtw4991 is offline
post #10 of 10 Old 10-28-2008, 07:20 PM - Thread Starter
cvearl's Avatar
My questions:
I am far from a guru on this stuff. This place is loaded with them. But a question I would have for you is about the pattern you are talking about....
Reverse grey scale ramp? The one for the Contrast?
On my PZ85 and BD30 with that blueray I CAN in fact get the last two brightest bars in the ramp to show separated or nor clipped" by lowering my contrast. So ya. You CAN actually get the second last aquares to be shown as separate. Well the black is a hard one to see but the white for sure. At least as I play around with mine.
But regarding the IRE, I think that effects black levels more as far as I know. If you are clipping below 100% black, the third bars from the middle closest to the edge of the screen or "outter darkest bars" are below black and when you increase BIRGHTNESS all the way up you should be able to see them. If you do, then you are not clipping black and running BTB signals to the TV. As for the white, I am not sure.
Check this document out...
http://www.avical.com/articles/avica..._tutorial.html
They explain all this better than I do.
I am now playing with the Getgray DVD and I am finding that as far as contast goes, THX Optimizer and Getgray are both happy with my set at 100% contrast and their patters show NO clipping whereas with DVE HD Basics does not pull the 2 brightest bars in the reverse greyscale out of clip until I drop under 80% Contrast so perhaps it's to do with the DVE?
Check a Starwars or Indiana Jones disk for the THX Optimizer tool in the options menu and they have a patter where there are 8 squares and if you can't un crush em (make em all distinct) by lowering contrast there may be something wrong with your setup.
Does your receiver have a 100% passthrough option? Then it should not be messing with the signal.
C.
cvearl is offline
Reply Display Calibration
