Sony Bravia KDL 32L4000 - Service menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 11-20-2008, 10:47 PM - Thread Starter
jangaboo's Avatar
anyone know the code to enter the service menu?
Display + 5 + Volume Up + power....doesn't work for me
jangaboo is offline
post #2 of 18 Old 11-22-2008, 10:48 AM
poodlehead's Avatar
Like most new sony's there is nothing you can do in the service menu other than do a reset....if you really have to see for yourself left,right,mute,center button,mute,menu
i-need-a-beak.com
poodlehead is offline
post #3 of 18 Old 11-23-2008, 09:28 AM - Thread Starter
jangaboo's Avatar
I LOVE YOU IT WORKED
picture time
jangaboo is offline
post #4 of 18 Old 12-02-2008, 10:07 PM
chan1011's Avatar
Can someone please explain what these options do?
chan1011 is offline
post #5 of 18 Old 12-03-2008, 08:53 AM
gp-se's Avatar
Quoted: 91 Post(s)
Liked: 70
they can screw up your tv if you don't know what your doing, if you change anything make sure to write down what the original setting was.
gp-se is offline
post #6 of 18 Old 12-03-2008, 09:59 AM
gp-se's Avatar
Quoted: 91 Post(s)
Liked: 70
Awesome this works for my S4100, I've been trying to figure out how to get in the service menu forever! Now I can finally adjust my colour decoder settings to get accurate colours.
gp-se is offline
post #7 of 18 Old 01-03-2009, 07:37 AM
jebise101's Avatar
Quoted: 23 Post(s)
any recommendation for xbox 360?
jebise101 is offline
post #8 of 18 Old 01-03-2009, 11:19 AM - Thread Starter
jangaboo's Avatar
i'm no expert
write down your tv's default settings and play around
jangaboo is offline
post #9 of 18 Old 01-16-2009, 11:27 AM
l_svps3's Avatar
My tv is a Latin American version , does anyone know where can I get it?, tech support does not want to provide it.
l_svps3 is offline
post #10 of 18 Old 01-16-2009, 06:13 PM - Thread Starter
jangaboo's Avatar
are you the one with the 32L4000 but its actually 32M4000
maybe try to see service menu code for 32M4000
jangaboo is offline
post #11 of 18 Old 01-17-2009, 09:16 AM
l_svps3's Avatar
No, but thanks for the suggestion, my tv is actually a KDL-32L4000 but is assembled in mexico and for some weird reason the keystroke described here does not work...
l_svps3 is offline
post #12 of 18 Old 01-17-2009, 02:21 PM - Thread Starter
jangaboo's Avatar
you have any pictures of the back of the TV?
Does it look like mine?
jangaboo is offline
post #13 of 18 Old 01-18-2009, 08:23 PM
l_svps3's Avatar
Probably mine is a 32M4000 packed as a 32L4000 which I think is the case, by any chance do you know the key sequence to access the service menu?
l_svps3 is offline
post #14 of 18 Old 02-18-2009, 04:24 PM
xrayer's Avatar
Hi,
I'm trying to find access to service menu and had tried following:
1) TV is off, press i+, 5, vol+ and switch on with remote
2) press the ´i+´, ´5´ and ´VOLUME -´ buttons all three together for 5 seconds. Then the INPUT button
3) One remote press one button after the next 'i+', '5', 'Analog'.
4) TV is on, left,right,mute,center button,mute,menu
but nothing works I hoped 26L4000 would be close to 32L4000. My remote is RM-ED014.
For sure, does "center" mean the round button in the center of left, right, up, down arrows? In my case TV responds to pressing this keys like I would press it individually. Does it depend on current signal source?
xrayer is offline
post #15 of 18 Old 11-27-2013, 03:24 AM
aereolis's Avatar
For KDL-26M4000-KDL-32M4000.  Copy and paste from service manual.
Traditional Service Mode is not available in this chassis. The only option for service technicians is to reset all of the settings to the Factory Default from
the Self Diagnostic screen.
CAUTION: Resetting the TV to the Factory Defaults will over-write all customer settings. Before performing this reset, contact the customer to
determine what adjustments they have made. (take a picture !)
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:
DISPLAY Channel 5 Volume + TV POWER .
The Self Check list displays. This is the SAME as accessing Service Adjustments.
Results for all of the following diagnostic items are displayed at the bottom of the screen. No error has occurred if the screen displays a “0”.
aereolis is offline
post #16 of 18 Old 02-03-2014, 03:34 AM
Ghiu V Vasile's Avatar
I need service manual for TV set SONY KDL-32W4000, Sir.
Have a nice day !
TG.V.I.
Ghiu V Vasile is offline
post #17 of 18 Old 08-09-2015, 10:34 AM
Liked: 0
can any one know service menu code for sony kdlw600b???
Bikash Agrawal is offline
post #18 of 18 Old 01-31-2016, 10:59 AM
Liked: 0
kdl42W653a
Друзья вы, что со своим АНБ вообще обнаглели. Где reset телевизора с вашими комбинациями реле в телевизоре щёлкают непонятно зачем, как я думаю это проблемы в ПО (прошивке) телевизора. Давайте сделайте чтоб всё работало.
Aleksei Rasulov is offline
Reply Display Calibration
