Inexpensive external CMS and gamma control with HDMI - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 238 Old 11-20-2009, 07:03 AM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
Yes I realise we are both in the dark, but the text you highlighted does seem to indicate that's the only way of adjusting things. Hopefully we'll hear from the horse's mouth what the correct answer is.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
post #182 of 238 Old 11-20-2009, 08:16 AM
Lee Bailey's Avatar
I believe that there must be software for the user to install on their laptop that would connect to the unit, from AVFoundry.
If this was a Spectracal labeled product, then I would think otherwise.
Though the user will still have to have some equipment/software to measure what they're changing.
Lee Bailey is offline
post #183 of 238 Old 11-20-2009, 08:39 AM
Quoted: 257 Post(s)
Liked: 153
Thanks Lee, I guess you'd know if they were selling Calman with the device, so hopefully you're right.
post #184 of 238 Old 11-20-2009, 09:50 AM
Bear5k's Avatar
There is no internal user interface planned for the device for the foreseeable future. You really need to use calibration software to use it effectively, anyway, so putting the UI on a PC is just the right way to go.
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #185 of 238 Old 11-20-2009, 10:02 AM
Quoted: 257 Post(s)
Liked: 153
So does this mean that the unit can only be adjusted with Calman or it will it come with some software to allow adjustment using a PC? I understand that using Calman means it can be really slick, but I'd still like the option of being able to use existing software and adjust the CMS 'manually' even if it's via a PC.
post #186 of 238 Old 11-20-2009, 10:12 AM
turbe's Avatar
Liked: 95
Posted earlier
Originally Posted by lovingdvd View Post
1) Does the CMS allow for control over all three axis - hue, saturation AND lightness?
Originally Posted by derekjsmith View Post
Yes the VideoEq Pro does, you have to be able to change the hue, saturation and lightness of all 6 colors RGBCMY. But as with all system like this you can only take away you can't add more saturation for example than your display will allow. But since most displays these days have or can enable wide gamut we are good.
3) What type of software is used to set the grayscale/CMS values?
The VideoEq and VideoEq Pro comes with software from AV Foundry to read/write and set the LUTs using text files in a common readable format that are compatible with Excel or Notepad for editing. This application will be enhanced over time to support industry standard formats all well.
We at SpectraCal are working on CalMAN v4 to support the direct control over the VideoEq and VideoEq Pro so you can use CalMAN to change the values within them directly. This is via the interface we design last spring and was showing at CEDIA this year with a prototype of CalMAN v4. This interface is copyrighted and patents are being applied for since we believe it is a unique way of controlling what can be a complex device. But all of this is for the CalMAN v4 beta.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #187 of 238 Old 11-20-2009, 12:02 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
No you can load precalculated LUT's to the device via a command line utility (I believe that's the plan). But I don't believe the provided software can generate a LUT.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #188 of 238 Old 11-20-2009, 01:38 PM
Lee Bailey's Avatar
The other thing missing is a remote control interface so you don't have to get up, find where you hid the device, dust it off, and push a button to change to a different lut.
post #189 of 238 Old 11-20-2009, 01:43 PM
Lee Bailey's Avatar
I think that if they (AVFoundry) were selling CALMAN with the device the price would have to be higher. So far the only version of CALMAN that supports multiple calibration/generator devices is the Pro version.
Though Spectracal is always coming up with ideas.
post #190 of 238 Old 11-26-2009, 06:39 AM
amt
amt's Avatar
Quoted: 17 Post(s)
Would it be possible to get a little more clarification on the 3x3 CMS matrix? Is this a true 3D Look-up-cube? How many index values for X,Y,Z (R,G,B)?
The reason I am curious is because I am wondering if this CMS could correct at not just 6 primary/secondary colors, but 6 colors at multiple levels of saturation. This would require more entries in the cube to be possible.
One would of course have to measure the 6 colors at, say 25%, 50%, 75%, and 100% saturation. And there would need to be an X,Y,Z index for each of these in the CMS cube. I think this would be nice for non-linear color gamuts in some projectors.
amt is offline
post #191 of 238 Old 12-17-2009, 08:09 AM
lordcloud's Avatar
Liked: 46
Any more info?
I LOVE MOVIES!!!!!!!!!!!!
lordcloud is offline
post #192 of 238 Old 12-17-2009, 10:28 AM
wrinklefree's Avatar
wrinklefree is offline
post #193 of 238 Old 12-17-2009, 05:46 PM
derekjsmith's Avatar
Liked: 116
We just started shipping the EAP's today
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #194 of 238 Old 12-17-2009, 06:12 PM
Gregg Loewen's Avatar
Quoted: 22 Post(s)
Liked: 68
hopefully we (THX video training) will be able to have 1 for the Open House at CES (saturday evening January 9th) from 7p-9pm.
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is offline
post #195 of 238 Old 12-17-2009, 08:52 PM
Liked: 116
Yes plus some other toys from AVF
Derek
post #196 of 238 Old 12-24-2009, 08:16 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
I only just now found out about VideoEq Pro. Very intriguing product!! This sounds like a great match for my RS-10.
Any chance one could still join the EAP?
____
Axel
Axel is offline
post #197 of 238 Old 12-24-2009, 09:07 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
The December newsletter said you could apply until 31-Dec-2009.
bodosom is offline
post #198 of 238 Old 12-24-2009, 09:20 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Got it! I found it in Calman's Dec Newsletter. Email sent...!
____
Axel
Axel is offline
post #199 of 238 Old 12-24-2009, 09:27 AM
Liked: 116
____
Axel
This is exactly what the VideoEq was built for
Derek
post #200 of 238 Old 12-24-2009, 11:11 AM
amt
amt's Avatar
Quoted: 17 Post(s)
____
Axel
I was told there was no EAP for the Pro. I have an RS2 (actually FPJ1), and was also looking forward to an EAP for the Pro, as it sounded like regular Eq was not capable enough to correct both primary and secondary colors.
amt is offline
post #201 of 238 Old 12-24-2009, 11:58 AM
turbe's Avatar
Liked: 95
The EAP VideoEq's have CMS
The VideoEq we are using for the EAP will have CMS
ControlCAL™
turbe is offline
post #202 of 238 Old 12-24-2009, 02:22 PM
amt
amt's Avatar
Quoted: 17 Post(s)
Not a complete one
If you care or need gamut correction (CMS) then the VideoEq Pro is what you need plus with the VideoEq Pro you also get to have 3 gamma/grayscale/gamut presets for day/night/sports type modes via IR jack.
amt is offline
post #203 of 238 Old 12-24-2009, 02:25 PM
Bear5k's Avatar
Originally Posted by amt View Post
Not a complete one
There may be a philosophical point you are making, but the EAP units have the full Pro CMS.
Bear5k is offline
post #204 of 238 Old 12-24-2009, 02:26 PM
erkq's Avatar
Quoted: 592 Post(s)
Liked: 428
Not a complete one
How is it incomplete? Is this like the Vision not having secondary color adjustments? Or not having hue, saturation AND luminance?
erkq is offline
post #205 of 238 Old 12-24-2009, 02:27 PM
amt
amt's Avatar
Quoted: 17 Post(s)
Sorry, just edited my post above. Look at the quote from Derek above.
Here is the link for full context: http://www.avsforum.com/avs-vb/showt...5#post17427545
amt is offline
post #206 of 238 Old 12-24-2009, 02:32 PM
amt
amt's Avatar
Quoted: 17 Post(s)
Believe me, I would love for the VideoEQ to have "complete" gamut correction. I would love to be wrong here, as I need a low cost solution for my FPJ1. So, can anyone say for sure the VideoEQ can correct saturation, hue and luminance on a projector like the RS2/FPJ1?
Also, is there a satisfaction guarantee? Can I return the product for a full refund within 30 days if it does not perform as expected, even if one participates in the EAP?
amt is offline
post #207 of 238 Old 12-24-2009, 03:14 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
I am looking forward to the answers to both questions. Maybe Derek could chime in...?
____
Axel
Axel is offline
post #208 of 238 Old 12-24-2009, 03:52 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Originally Posted by amt; View Post
Sorry, just edited my post above. Look at the quote from Derek above...
So, can anyone say for sure the VideoEQ can correct saturation, hue and luminance.
If Bill says it's so I think you can depend on it being so.
bodosom is offline
post #209 of 238 Old 12-24-2009, 04:02 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Although this doesn't answer your question I think it's safe to assume that unless this is a complete bust someone would be willing to buy the unit from you.
That said it does sound like you should wait until the product is released, reviewed and refreshed before you get one.
bodosom is offline
post #210 of 238 Old 12-24-2009, 05:06 PM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
I would expect that for the EAP there would be no or only a very limited satisfaction guarantee as it otherwise would take away from all the excitement that usually comes with being an early adopter. For my part, I am still very intrigued ...
____
Axel
Axel is offline
Reply Display Calibration
