X-Rite Eye-One Display 2, also Projectors and LCD TV?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-18-2009, 07:27 AM - Thread Starter
Kedas's Avatar
Hi,
I'm considering buying such a color meter.
The specifications only say 'Monitor' calibration.
Does this mean I will not be able to use it for my LCD TV or Projector?
Or does what you can calibrate only depend on the software you use with it?
If I buy one I want to be able to calibrate my TV, monitor and Projector.
Otherwise it is too expensive to buy a different device for each display device.
Kedas is offline
post #2 of 5 Old 01-18-2009, 09:34 AM
Rolls-Royce's Avatar
Quoted: 243 Post(s)
Liked: 359
The meter itself is fine for monitor and projector calibration. However, the software that comes with it is only used to build calibration profiles for use with a computer's video card. It's fine if you're going to use an HTPC as your sole source, but not so good if you aren't. You'll need other software such as CalMAN or HCFR to calibrate displays such as TVs and HT projectors.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 5 Old 01-18-2009, 11:43 AM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Skim this looking at the pictures, ignoring the details of using HCFR (for now).
Grayscale ... for Dummies
bodosom is offline
post #4 of 5 Old 01-18-2009, 01:23 PM - Thread Starter
Kedas's Avatar
Thank you, I just ordered the eye one.
Kedas is offline
post #5 of 5 Old 03-22-2013, 10:34 AM
Sittler27's Avatar
Quoted: 693 Post(s)
Liked: 62
Sorry for bringing back an old thread here.
Would the x-rite colormunki smile be a good color meter to use for projector calibration with HCFR?
Or would the X-Rite I1 Display Pro be the minimal best one to use?
Sittler27 is offline
Reply Display Calibration
