New Calibration Tool, Excel Download - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 123 Old 01-29-2009, 08:05 PM
angryht's Avatar
Originally Posted by stereomandan View Post
HCFR doesn't display all the digits, but when I copy and paste into Excel, they are there.
Dan
Originally Posted by Bill Mitchell View Post
It might also be an improvement in Microsoft Office. I'm seeing the behavior Dan describes, that I can copy-and-paste the entire table. I'm using Vista and Microsoft Office 2007.
Well I tried it with excel 2007 and got the same result, it only pastes the visible digits? Maybe it's an XP thing.
Dan,
Here is my contribution. I put together a spreadsheet that calculates the new targets based on primaries that are off. So far I am getting the same results as the Accupel display calibration calculator. I was hoping others could check it and test it out. And maybe it could be incorporated into your tool. The formulas came from the article in Widescreen Review Magazine, December 2008. Thanks very much to Tom Huffman for making the complex math simple to understand (and all your other contributions). Let me know what you think.
I have updated to version 2 which cleans it up a bit and makes it a little more simple to use.
angryht color calculator ver 2.zip 6.90625k . file
-Greg
angryht is offline
post #32 of 123 Old 01-30-2009, 07:23 AM - Thread Starter
stereomandan's Avatar
Thanks! I'll take a look and see if I can integrate it.
Dan
stereomandan is offline
post #33 of 123 Old 01-30-2009, 12:50 PM
Bill Mitchell's Avatar
Dan,
So, I'm trying out the spreadsheet, and the results I see don't make sense.
Here's the raw measurements I started from for R/G/B/W:
Red Green Blue White
x 0.62700 0.29600 0.15200 0.31100
y 0.33700 0.58900 0.06400 0.16200
Y 16.58200 56.14500 5.76900 79.23100
Using your spreadsheet, under NEW TARGETS it comes up with a weird recommendation for Red Y of 54.42373, Green of 4.31013, Blue 20.49714. Possibly a rotation of variables somewhere? The corresponding calculated values from Accupel are: 16.582, 56.145, 5.769.
Another discrepancy with Accupel, the recommedations for the secondaries: the spreadsheet derives for the secondaries:
Yellow Cyan Magenta
0.61265 0.15522 0.31123
0.34792 0.07573 0.15551
58.73386 24.80727 74.92087
The yellow xy is about where Red is on the CIE chart, the Magenta xy is about where White is, and Cyan is about where Blue is. The corresponding recommendation from Accupel gives:
Yellow Cyan Magenta
0.415 0.224 0.323
0.498 0.327 0.163
73.2254 61.3788 23.8578
I don't have the article, yet. My usual book/magazine store had the Nov 2008, but not the Dec 2008, so I've not been able to verify the formulas. I probably need to make the tour of several more bookstores this weekend to see where I can find the Dec issue.
Bill Mitchell is offline
post #34 of 123 Old 01-30-2009, 02:24 PM
angryht's Avatar
That y value for white seems off by quite a bit. Typo?
-Greg
angryht is offline
post #35 of 123 Old 01-30-2009, 03:19 PM - Thread Starter
Small update to the spreadsheet. I included a saturation %Error chart for the 'u, 'v colorspace.
Dan
post #36 of 123 Old 01-30-2009, 08:01 PM
Yes, typo, I accidentally copied the y value from the Magenta instead of the White column. The correct value should have been 0.328.
post #37 of 123 Old 01-30-2009, 08:33 PM
thomasl's Avatar
Bill, you can also go to their web site and sign up for an on-line subscription - it's $15 - and gets you access to all issues with the articles in PDF format. Both of Tom H's articles are available via PDF viewing.
cheers,
--tom
thomasl is offline
post #38 of 123 Old 01-30-2009, 08:39 PM
angryht's Avatar
OK, I get a perfect match between the accupel calculator and the angryht calculator. Isn't that what you got? See files.
Angryht calcd and accupel.zip 98.34375k . file
-Greg
angryht is offline
post #39 of 123 Old 01-30-2009, 08:56 PM
angryht's Avatar
cheers,
--tom
Absolutely worth it!
Sheesh tom, where the heck have you been? Glad to hear from you again!
-Greg
angryht is offline
post #40 of 123 Old 01-30-2009, 09:04 PM
You're right. Double checking again with the corrected y value for white (now why didn't I see that right away myself?) the results are the same. My bad.
post #41 of 123 Old 01-30-2009, 09:12 PM
angryht's Avatar
No problem. Thanks for checking.
-Greg
angryht is offline
post #42 of 123 Old 01-30-2009, 09:13 PM
thomasl's Avatar
Thanks - yeah, I took a bit of a break from the audio/video hobby to concentrate on a few other hobbies but with winter firmly entrenched, I've gotten back into it. It's good to see all the familiar names still here in the forum.
cheers,
--tom
thomasl is offline
post #43 of 123 Old 01-31-2009, 02:15 AM
BeachComber's Avatar
Might want to delete the bad attachment off your post at the top of page 2
BeachComber is offline
post #44 of 123 Old 01-31-2009, 04:38 AM
angryht's Avatar
I'm not sure what you mean.
It has been proven that it works. See the 2 files in this
post.
-Greg
angryht is offline
post #45 of 123 Old 01-31-2009, 02:31 PM
post.
Edit to get rid of the file attachment in post #31....as you have a corrected file in post #38, so someone does not download file in post #31 now.
post #46 of 123 Old 01-31-2009, 05:56 PM
angryht's Avatar
The file in post #31 contains the spreadsheet and is named angryht color calculator ver 1.zip. The zip file in post #38 is called Angryht calcd and accupel.zip and contains 2 .bmp (pictures only) files showing that the results from the spreadsheet match those from the accupel calculator. I just zipped them together. That is why they have different names.
-Greg
angryht is offline
post #47 of 123 Old 02-03-2009, 08:37 AM
After working through myself the math behind the discussion in the other thread on the AVS HD disk, especially the gamma adjustment to even out the measurements, and with much assistance from Poynton's information and the equations on Lindbloom's site, I've worked up a spreadsheet that recalculates the saturation targets based on the measured primary points and the measured average gamma. Using these points does isolate the effects of saturation error a little better from the other CMS adjustments on the color gamut.
Dan, I did not get to the point, yet, of figuring out your spreadsheet well enough to adjust the comparison points for the delta E (Luv) calculation. And, in my calculation, I just used the raw RGB percentages provided by Tom Huffman, neglecting any quantizisation of the values when represented as integer values in YCbCr or RGB.
Enjoy,
Bill
SaturationReferences.zip 14.5576171875k . file
post #48 of 123 Old 02-06-2009, 11:16 AM - Thread Starter
Small update. The Calibration Aid worksheet now allows the user to select the gamma that they are targeting. This is the standard gamma power function.
Dan
post #49 of 123 Old 02-06-2009, 11:21 AM - Thread Starter
Enjoy,
Bill
Wow Bill. You put some work into that. I'll look over it again, and if you don't mind I can add it to the main file in post #1. Of coarse I'll give you credit.
Dan
post #50 of 123 Old 02-06-2009, 11:23 AM - Thread Starter
Would you like your calculations added to the main spreadsheet listed in post #1?
Dan
post #51 of 123 Old 02-06-2009, 11:27 AM
angryht's Avatar
Thanks, Dan. Any update on being able to incorporate primaries that are not in line, or adjustable, with the standards? I gave it a shot, but I don't want to post a modified version of yours and Bill's.
-Greg
angryht is offline
post #52 of 123 Old 02-06-2009, 11:28 AM
angryht's Avatar
Dan
You bet! Actually, I have updated it:
-Greg
angryht is offline
post #53 of 123 Old 02-06-2009, 01:39 PM
Dan
Feel free to use it, that was my intention. I notice you have posted an update; hopefully I'll have a chance to try it out this weekend.
Bill
post #54 of 123 Old 02-07-2009, 08:09 AM - Thread Starter
2-7-09 Updated to included Bill MItchell's and angryht's worksheets.
Bill, when I enter 2.22 gamma into your spreadsheet, the locations do not match my reference locations, which were verified by Tom Huffman to be correct. Can you check into this? For some reason the 100% saturation x,y locations are different than mine, which should be independant of gamma
Dan
post #55 of 123 Old 02-07-2009, 05:08 PM
Dan
I will look at it again. Since Tom did not post the 0% numbers, I didn't bother recalculating these, and I've been thinking those values should be easy to figure out.
Looking at your spreadsheet, it is curious that the Y values are not identical across the red/green/blue reference values. I picked up on all this in the other thread, which discussed how the values HCFR sent were designed to give a uniform luminance. So I would have expected the Y values to be identical in the reference data. I assumed the difference came from rounding errors in the calculation, but it does leave me wondering. Similarly I attributed small differences I saw between your reference values and my calculations to rounding differences in Excel.
I'll let you know what I learn.
Cheers,
Bill
post #56 of 123 Old 02-07-2009, 06:15 PM - Thread Starter
It's good that you picked up on the Y values not being identical from 0-100% saturation. I noticed this as well. The numbers I put in my spreadsheet are from Tom's information, based on the known RGB target points here: http://www.avsforum.com/avs-vb/showt...9#post15619419
I used Bruce Lindblooms's website to calculate the x, y Y targets based on the info that Tom provided. http://www.brucelindbloom.com/ In my measurements, my projector seems to agree with the numbers in my spreadsheet. There are slight variations in Y from 0-100 saturation.
The reason I question your calculations is because the 100% saturation x, y locations are off for some of the colors. They are known points, regardless of gamma and I'm sure the locations in my spreadsheet are correct.
Dan
post #57 of 123 Old 02-08-2009, 02:17 AM
Dan
Just as there are several different formulas for Delta E, there are several different formulas for this.
Again, use Lindbloom.
post #58 of 123 Old 02-08-2009, 12:04 PM
Dan
I re-tested the spreadsheet today, plugging in the Rec709 color primaries instead of my measured primaries, and I see the correct values for all the 100% saturation points. In the spreadsheet I had posted, I had left my measured primaries and modified gamma, to illustrate how to use it to predict the modified saturation points. My guess is that you were looking at results without modifying the colors to match 709, so of course the 100% saturation points looked different.
I replaced the file with a new one, that starts with the Rec709 colors and assumes a decode gamma of 2.22. I seems to me that this predicts the values you have hardcoded into the Gamut/Saturation/Brightness spreadsheet as the 709 saturation targets. The updated version has the benefit of incorporating 0% saturation targets that I have calculated. Tom Huffman did not include these in his table, but I have another more detailed spreadsheet that reproduces the calculation behind his numbers.
As regards the formulas in the spreadsheet, these of course are copied from Lindbloom's website, so the calculations should be the same as his online calculator. Obviously, Excel may display more or fewer digits depending on the formatting.
The model in the spreadsheet still uses the RGB percentages given by Tom directly. It does not yet model the process of 709 encoding to and decoding from the disk in YCbCr, which would introduce another couple rounding steps to integers, but might make the predictions slightly more accurate. I've already worked through those as part of another exercise I did to understand color encode/decode errors, so it would not be hard to incorporate those here. I might go ahead and do that, just for fun, to see what effect it has on the values.
By the way, I can explain the small dips in the Y values at the intermediate saturation points. As mentioned in the other thread, the HCFR provided values were designed to give the same brightness at all saturations with a gamma of 2.2. The percentage values you used in your spreadsheet assume a display gamma of 2.22. This small difference in gamma creates the dip in Y at intermediate points.
Cheers,
Bill
post #59 of 123 Old 02-08-2009, 02:00 PM
As I suggested above, I went ahead and calculated what happens to the intermediate saturation RGB points when they undergo the Rec709 conversion into the YCbCr representation on the disk. It's really pretty interesting, because with the different coefficients and thus ranges for each of the values in PbPr, where Y would have equal Red and Green components, 50% Y in the YCbCr representation after rounding ends up with slightly different values for Red and Green.
So, I've replaced the spreadsheet again. At the top, you can see the HCFR percentages posted by Tom Huffman, and what I believe end up being the percentages after they are encoded to and then decoded from the YCbCr representation on the AVS HD disk. If you modify the spreadsheet to use Tom's values instead of my calculated ones, it matches very closely the values currently coded into the Gamut/Saturation/Brightness spreadsheet. It could be that my calculated values would represent exactly what a set perfectly calibrated to Rec709 would display from the AVSHD disk. As my set is not nearly so perfect, I can't confirm this through measurement.
post #60 of 123 Old 02-16-2009, 05:00 AM
mssoll's Avatar
Dan,
This is my first post and my first attempt at calibrating. I originaly input Dusters settings and saw an improvement but I knew that I was still off. I am a photgrapher and already owned an I12 so it was no biggy to give it a shot. I followed the dummies guide and nailed the white balance.
My question is on the primary and secondary measurements. I am not clear on which patterns I should be measuring. The color or the saturation on the AVSHD disc I downloaded for my PS3.
Also, Once I start changinf the settings in RGBCYM, Will I then need to address the white balance again?
mssoll is offline
Reply Display Calibration
