New Calibration Tool, Excel Download - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #121 of 123 Old 08-18-2011, 07:05 AM
RyanHomsey's Avatar
Quoted: 113 Post(s)
Liked: 42
Thanks a bunch for this tool!
Having the HCFR bars definitely helps. Much easier to pull things in with the visual bars.
RyanHomsey is offline
post #122 of 123 Old 08-18-2011, 06:01 PM
kjgarrison's Avatar
Originally Posted by TomHuffman View Post
The problem with this is that different dE formulas yield different--often substantially different--results in this regard. Greg uses CIELUV exclusively, which I have much less faith in.
Indeed, this shows just what I have been talking about for some time. Take this oversaturated, but otherwise accurate, green: x0.296, y0.676, Y0.7152 and run the solver for both CIELUV and CIE94 (assume Rec. 709). You get radically different recommendations.
CIE94: 0.687 (Actually, a range of values between 0.674-0.701 all yield the same result. 0.687 is a median value)
CIELUV: 0.532 (a range of 0.518-0.546)
For a variety of reasons, I think that CIE94 gets the correct result.
BTW, I don't see how you are getting you %C and %H error values. The oversaturated green I defined above has perfect hue, yet your spreadsheet gives it a percentage error of %39.3.
Originally Posted by stereomandan View Post
I included some HCFR specific % bar values for 100% and 75% saturation points in the calibration aid tab.
I explain it in the "Special Hint" section of Post #1 in my Epson calibration thread.
http://www.avsforum.com/avs-vb/showt...7#post16166537
Dan
Dan, did you ever address the question Tom raised? (See bold text in his post above.)
kjgarrison is offline
post #123 of 123 Old 02-14-2012, 05:33 AM
SecondaryColors's Avatar
Hi,
Does anyone know how to access gray scale settings for a Sharp Aquos LC-26GA5U? It seems impossible to find the service menu code for this set. It has a C.M.S menu, but I don't see RGBhighend, RBGlowend, gains, drives, or bias.
SecondaryColors is offline
Reply Display Calibration
