Contrast Ratio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-30-2009, 07:06 PM - Thread Starter
ivtec's Avatar
Hi, have a question about Contrast Ratio like say Sony has 7000:1 and Sumsumg Has 20000:1, what are this difernces mean in terms of quality between this 2 modles? thanks.
ivtec is offline
post #2 of 4 Old 01-30-2009, 07:25 PM
Chad B's Avatar
Quoted: 526 Post(s)
Liked: 1239
That spec is so inflated it's nearly meaningless. Real world measured performance might only be 10% of that, but it varies widely from one manufacturer to the next.
It's about as bad as a little paperback sized car stereo amp that says it's 1000 watts.
Now if you have 2 Sonys and one is rated 7000:1 and the other is rated 20000:1, then you can surmise that the 20000:1 model will have darker blacks and a more vibrant picture, especially with dark movies or dark shows. But comparing a 7000:1 Sony to a 20000:1 Samsung means absolutely nothing.
Chad B is online now
post #3 of 4 Old 01-30-2009, 07:27 PM
SierraMikeBravo's Avatar
Quoted: 339 Post(s)
Liked: 216
Unless they took the dark measurment with the TV turned off.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #4 of 4 Old 01-30-2009, 09:10 PM
ChrisWiggles's Avatar
You don't specify what type of contrast ratio measurement those are.
The two most common that you will find are an on/off contrast ratio, and an ANSI contrast ratio. They are very different, and describe contrast performance in very different kinds of situations. They are both crucially important for a high quality image.
Please read this article about contrast ratios:
http://www.hometheaterhifi.com/volum...06-part-1.html
ChrisWiggles is offline
Reply Display Calibration
