what is the difference in these options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-20-2009, 11:40 AM - Thread Starter
dark scorpio's Avatar
what is the different effect in raising lowering:
RCUT
RDRV
R-YR
i know these have to do with red but what exactly does each of these do?
I want to shoot my TV
dark scorpio is offline
post #2 of 9 Old 07-20-2009, 12:07 PM
ChrisWiggles's Avatar
first is red cut, second is red drive, third dunno what display is it?
ChrisWiggles is offline
post #3 of 9 Old 07-20-2009, 12:27 PM - Thread Starter
thanks, but what exactly does each one do if i lower one as opposed to the other? and im on a sony wega trinitron (standard not HD)
post #4 of 9 Old 07-20-2009, 12:48 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
Cuts are for the low end of grayscale.
Drivers are for high end.
Color Decoder for Red . Likely red saturation. Use a red filter or turn other colors off when using this parameter.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #5 of 9 Old 07-20-2009, 01:24 PM - Thread Starter
Originally Posted by Michael TLV View Post
Greetings
regards
so would lowering the saturation put an end to that glowing red that is annoying? red is way to strong on numerous shows
post #6 of 9 Old 07-20-2009, 01:53 PM
Quoted: 41 Post(s)
Liked: 144
Greetings
Yes ... but you will need to confirm with your eyes.
post #7 of 9 Old 07-20-2009, 02:11 PM - Thread Starter
ok thanks a lot for the info, really appreciate it. ill be back to bug you if i have any more questions
post #8 of 9 Old 07-21-2009, 01:44 PM - Thread Starter
ok turns out i have no R-YR in my service menu but can anyone tell me what these stand for?:
RPLU
RPLB
RPLS
appreciate anyone willing to help
post #9 of 9 Old 07-22-2009, 05:28 PM
I don't remember the older sony crts, but I do recall finding some service menu lists on those if you google around.
Have you started with a basic calibration first, and do you even know if you have a red push problem? Even with a color decoder that's pushing red, if you lower saturation a little bit from the 'correct' setting viewed via blue on bars, it should be pretty satisfactory. Have you started with this yet?
Reply Display Calibration
