The Official ChromaPure thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 260Likes
post #361 of 7331 Old 05-09-2010, 07:13 PM
muad'dib's Avatar
Quoted: 221 Post(s)
Liked: 55
Are you going to do/ or is it possible with i1pro? to have corrected LED tables?
Or is the i1pro good enough for that right now...
Thanks..
muad'dib is online now
post #362 of 7331 Old 05-09-2010, 07:25 PM
muad'dib's Avatar
Quoted: 221 Post(s)
Liked: 55
I noticed the workflow had the gamma done last...
Would it not be better to do this order:
1 - contrast
2 - brightness
3- gamma
4- white balance
5 - color/tint
6 - gamut
This way, you have the correct gamma from the start as a good base, then the rest will calibrate from there..
Or
Does gamma not really impact anything so doing it last is fine?
post #363 of 7331 Old 05-09-2010, 10:34 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
For now, our custom calibrations are offered for the Chroma 5 and Klein K-10 colorimeters only.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #364 of 7331 Old 05-09-2010, 10:37 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Do black level, white level, and then white balance. After that, the order is not critical.
1 - contrast
2 - brightness
3- gamma
4- white balance
5 - color/tint
6 - gamut
Or
Tom Huffman
Springfield, MO
post #365 of 7331 Old 05-10-2010, 07:42 AM
p5browne's Avatar
Quoted: 3134 Post(s)
Liked: 2448
Originally Posted by TomHuffman View Post
This is something we may add in the near future. I first wanted to see if the program was successful. Doing this requires a non-trivial capital investment on our part.
Can't find where Current Users can Download the Upgrade?
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is online now
post #366 of 7331 Old 05-10-2010, 08:37 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
I send a download link to only those who have sent in their Chroma 5s for recalibration. Other than this, there is no difference between this build and 1.2.1. In fact the new build won't even work without an updated license file.
Tom Huffman
Springfield, MO
post #367 of 7331 Old 05-11-2010, 07:30 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Secrets of Home Theater and High Fidelity just published a review of different DIY calibrations packages, including ChromaPure. Take a look.
http://www.hometheaterhifi.com/diy/8...-overview.html
Tom Huffman
Springfield, MO
post #368 of 7331 Old 05-11-2010, 08:59 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Well I can't comment on Calman but IMO the review is spot on with Chromapure and HCFR (and Calman is what I thought it to be). Having used both Chromapure and HCFR the choice is easy...Chromapure wins hands down. Do I regret not getting Calman? Not in the least. Chromapure does everything I need and makes it simple. It also has a tremendous help section (which I did not see mentioned in the review). Now that we can send Chroma 5's back to Tom for periodic tweaking I see no reason not to buy Chromapure.
I do have to check out the built-in Chromapure color pattern generator.....I was unaware of this feature....if my Mac (running XP in Boot Camp) outputs unaltered HDMI colors this sounds like huge timesaver.
Geof
Geof is offline
post #369 of 7331 Old 05-11-2010, 12:22 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Tom - is there any problem using a USB extension cable with the Chroma 5?
Edit: Never mind - already addressed positively. here
Buzz
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #370 of 7331 Old 05-11-2010, 12:30 PM
millerwill's Avatar
Quoted: 534 Post(s)
Liked: 316
That's a great review, Tom--Congratulations! I can certainly echo the ease of use of ChromaPure. (Still hope you will put out a Mac version; would buy it again!)
millerwill is offline
post #371 of 7331 Old 05-11-2010, 01:01 PM
bodosom's Avatar
Quoted: 280 Post(s)
Liked: 122
I use all three packages. Presumably I'm not the target audience since I found both this review and the (now dated) CalMAN review unhelpful (presumably because I know how they work).
They also need a technical copy editor.
bodosom is online now
post #372 of 7331 Old 05-11-2010, 01:10 PM
Canonazo's Avatar
Congratulations Tom, sounds like they were very impressed with your software - and I'd also like to say "thanks" - the information you post is always very helpful to someone like me just geting to know this stuff.
Canonazo is offline
post #373 of 7331 Old 05-11-2010, 11:45 PM
gtgray's Avatar
Quoted: 226 Post(s)
Liked: 146
One Chroma5 will be in the mail today!
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #374 of 7331 Old 05-14-2010, 08:17 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Got some lurker questions.
I have an old CRT that I adjusted using the original Video Essentials DVD back in the day (1999!). I am planning to upgrade to a plasma this summer/fall and plan to purchase a ChromaPure kit for calibration. The recent “Secrets” article was very helpful in my decision.
To automate the process some, I will be using a laptop via USB to HDMI. Will any ol’ USB to HDMI converter work fine since it's all digital data? Or is there a need for some level of quality (aka higher priced) when using an USB to HDMI converter? Any recommendations would be helpful.
I am thinking about getting the software now and doing a calibration on my old CRT using the ChromaPure DVD that is available. That way I can get familiar with the software etc… It will be good to know what my set of eye’s have become accustomed to over the years.
Not to step on a landmine but; Gamma? Can someone describe the “visual” difference between an ideal HDTV with a flat 2.2 v.s. 2.35? I have read Tom’s article about understanding gamma so I get the need for a consistent level for various output intensities but will probably want to experiment within a range to see if I have a preference.
Would targeting a different gamma for daytime cal. Vs. nighttime cal. have any benefits? Or is that just crazy talk?
Gaugster
Gaugster is offline
post #375 of 7331 Old 05-14-2010, 10:16 AM
bodosom's Avatar
Quoted: 280 Post(s)
Liked: 122
Originally Posted by Gaugster View Post
To automate the process some, I will be using a laptop via USB to HDMI. Will any ol' USB to HDMI converter work fine since it's all digital data?
I strongly recommend that you use a BD/DVD player unless your primary video source is the same laptop via USB. It can be challenging to get output levels perfect when using a computer.
Not to step on a landmine but; Gamma? Can someone describe the visual difference between an ideal HDTV with a flat 2.2 v.s. 2.35? ...
See the Wikipedia article on gamma correction for example images.
post #376 of 7331 Old 05-14-2010, 11:03 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Thanks for the information. My understanding of gamma is better now. I've always been inclined to try to adjust the complete video system. I.e. Environment, player & display so I will use the BD player& DVD. I guess digital doesn't fix everything. lol
Gaugster
Gaugster is offline
post #377 of 7331 Old 05-14-2010, 11:45 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Can someone describe the visual difference between an ideal HDTV with a flat 2.2 v.s. 2.35? I have read Tom's article about understanding gamma so I get the need for a consistent level for various output intensities but will probably want to experiment within a range to see if I have a preference.
Briefly, 2.35 might provide more depth and deeper blacks. 2.2 would provide better shadow detail.
My vote is with crazy talk. . . .
Tom Huffman
Springfield, MO
post #378 of 7331 Old 05-15-2010, 11:28 AM
buzzard767's Avatar
Liked: 2439
Tom - I recently sent you my Chroma 5 for the Pro upgrade. Which mode do I use for a Samsung HL67A750 DLP LED?
Buzz
Buzz
post #379 of 7331 Old 05-15-2010, 11:46 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Front Projection would be the best bet.
Tom Huffman
Springfield, MO
post #380 of 7331 Old 05-21-2010, 06:25 AM
rowland.johnson's Avatar
Tom - Which mode should I use for an LG 47LH90?
rowland.johnson is offline
post #381 of 7331 Old 05-21-2010, 07:23 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Generic LCD. This is an average of the Sony and Samsung corrections.
Tom Huffman
Springfield, MO
post #382 of 7331 Old 05-21-2010, 08:22 AM
I'm sure this has been asked and answered before. Maybe someone can point me to the right place. My question is why does a probe need to be calibrated to the display type. If the probe is measuring the quantity and wavelength of photons why does it matter how they were produced?
post #383 of 7331 Old 05-21-2010, 11:18 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
Tristimulus colorimeters read color by employing photo sensitive diodes that have filters between them and the light source. These filters simulate the response of the human eye. The problem is that this response is quite complex, so it cannot be mimicked precisely by filters, at least ones that are reasonably affordable. To solve this problem, manufacturers build calibration tables into the probes to improve their accuracy. These tables are based on readings from a spectroradiometer that does not use filters, but that reads the spectra of the light directly. Color is mathematically calculated from this spectrographic data using color matching functions established by CIE in 1931.
The Chroma 5 PRO builds on this strategy by creating calibrations for colorimeters that are specific to each unit and that are derived from a variety of display types, not just generic CRT and LCD. Also, we use a 5nm spectroradiometer, which is more accurate than the standard 8nm spectroradiometer used by manufacturers.
To understand why a filter-based colorimeter requires different calibrations for different devices, consider two displays: Display 1 and Display 2.
Assume that because of different design parameters, the light coming from each of these has a unique spectrographic profile. A spectroradiometer--if it is sensitive enough--will discern the difference between them, while a filter-based device whose internal calibration table is based on a third display with its own spectrographic properties may not.
If you are interested in learning more about this, see the following X-Rite white paper.
http://www.chromapure.com/xrite/Xrit...ionDevices.pdf
Tom Huffman
Springfield, MO
post #384 of 7331 Old 05-31-2010, 08:53 AM
catmother's Avatar
The ChromaPure PDF report size far exceeds the AVS upload limit, measuring over 2 MB.
I have been experimenting with the free version of PrimoPDF to convert the .xls to PDF with good results.
Using the Screen template in PrimoPDF to process the .xls (498 KB) to PDF results in a 142KB file.
There are several templates in PrimoPDF, screen, Ebook, Prepress etc. Give the program a try.
The attached is the calibration of my LG 55LH90, done in February, converted to PDF from .xls using the MS (free) xls viewer and then printing to the PrimoPDF printer installed under 'Printers and Faxes' in XP by PrimoPDF.
LH90 Corrected Gamma.pdf 141.296875k . file
Certified HDTV junkie and AVS addict
U.S. Army FA WWII
catmother is offline
post #385 of 7331 Old 06-02-2010, 06:38 PM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Wow, thanks for the tip!
Attached are the full results from my 60pk550.
CalibrationSummaryDetailed.pdf 127.1923828125k . file
slosvt is offline
post #386 of 7331 Old 06-04-2010, 06:00 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I will be another new Chromapure user! Made the purchase yesterday for the Chroma 5 Pro package. After looking at Calman 4.0 and then watching Toms demo's online plus having run my own cals with HCFR it was clearly obvious that Chromapure is the easiest, quickest and most informative way to calibrate. Continuous measure gamma calibration...that is so sweet! I have a VideoEq Pro and this should be quick and easy to run calibrations. The gui that comes with VEQpro is easy to use and the controls fall in line with Chromapure's adjustments for CMS. I know Calman can control the VideoEQ Pro to make it more automated but after reading it took one guy 4 hours to run a cal and he had to reset his VEQ a few times and start over I said forget that. I can run them much quicker in HCFR but with Chromapure it will cut that time down even more for sure. Then the Chroma 5 Pro and the ability to send it back in for a recalibration is a no brainer. One meter to do it all basically and piece of mind that the meter is pretty darn accurate too thanks to the Pro option. I am really looking forward to taking it for a spin!
Ron
Ronomy is offline
post #387 of 7331 Old 06-16-2010, 01:12 PM
kal
kal's Avatar
Quoted: 20 Post(s)
Liked: 77
Heads up:
Tom's now got a dedicated support forum for ChromaPure over at my site that he's going to be monitoring. See here.
It's probably not widely known, but I based my original 'Greyscale & Colour Calibration for Dummies' guide on Tom's original workflow process found here at AVS, so it's really nice to see him now have come up with calibration software that follows that same logical flow. Congrats Tom! Much easier to follow his on-screen steps than having to read my 20,000 word guide.
Kal
kal is offline
post #388 of 7331 Old 06-19-2010, 01:11 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
Originally Posted by kal View Post
Heads up:
Kal
Kal, are there any duties or taxes added for Canadians when ordering a ChromaPure calibration package?
Kilgore is offline
post #389 of 7331 Old 06-19-2010, 01:17 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 705
I think I can answer this. If you already have a meter and just want software, it is a digital download, so no extra costs. However, if you purchase a software/meter bundle, then this must be shipped from the U.S. to Canada, so standard shipping fees and whatever duties and/or taxes Canada requires would be part of the user's cost.
Tom Huffman
Springfield, MO
post #390 of 7331 Old 06-19-2010, 01:23 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
Thanks Tom, I figured that would be the case.
Are there any restrictions on the meter that is used or is ChromaPure useable with any of the supported devices? For example, if I have a Display 2, and later purchase an Eye One Pro, do I require different licensing?
Kilgore is offline
Reply Display Calibration
