The Official ChromaPure thread - Page 183 - AVS Forum | Home Theater Discussions And Reviews
 256Likes
Old 05-21-2014, 04:02 AM
thrang's Avatar
Quoted: 1624 Post(s)
Liked: 1394
Originally Posted by TomHuffman View Post
I have uploaded a short video of the new ISF Calibration Wizard to the ChromaPure Demos page.
Cannot view it on an ipad...drop flash....
thrang is online now
Old 05-21-2014, 06:00 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Originally Posted by 1forsnow View Post
the colorchecker module sure could use a measure all feature.....IMO
+1
Geof
Geof is offline
Old 05-21-2014, 06:36 AM
kwolfman's Avatar
I'm also +1 for this.
In addition, the before and after runs of the colorchecker should be added as optional choices in the Advanced Calibration setup. I'm always forgetting to run the "pre-calibration" colorchecker run when I do my automatic calibration run. Without that pre-calibration run, the post calibration run of the colorchecker is not as useful (nothing to compare to.)
kwolfman is offline
Old 05-21-2014, 08:52 AM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Never! Blame Apple for being too pigheaded to support Flash.
Kilgore is offline
Old 05-21-2014, 08:54 AM
thrang's Avatar
Liked: 1394
I've disliked Flash long before it was correctly banished by apple...there are better solutions...beyond that, given the number of iOS devices in use, and likely a high number by chromapure users, it is just a pragmatic decision to upload demos that are more universally playable.
Old 05-21-2014, 12:33 PM
stef2's Avatar
Quoted: 370 Post(s)
Liked: 226
I have been playing with the advanced color management module and it seems that calibrationg to 75% of rec709 is the way to go for me.
I am trying to understand what the charts mean when I generate an advanced color management report.
First, there is a CIE chart titled Saturations Chromaticity. This one I understand.
Then, there is a graph titled Saturation Luminance (vertical axis is a %). I dont know how to interprete this one. Does it have anything to do with the other graph I get, named Amplitudes dE (vertical axis is a dE value)?
stef2 is online now
Old 05-21-2014, 08:58 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Color is a 3 dimensional property: hue, saturation, and lightness. The CIE Chromaticity chart displays hue and saturation. That leaves the third dimension, lightness. The Luminance graph displays errors in lightness, though somewhat indirectly. Lightness is a perceptually-weighted measurement of luminance.
EDIT: dE incorporates errors in hue, saturation, and lightness and in such a way that presumably weights each according to its perceptual relevance. So, in theory all you need is dE. However, it is nice to see the errors broken out into their component parts.
anta1974 likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Old 05-21-2014, 08:59 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
It's on our development roadmap.
Tom Huffman
Springfield, MO
Old 05-22-2014, 06:30 AM
stef2's Avatar
Quoted: 370 Post(s)
Liked: 226
Thank you for the great support!
It seems like calibrating my RS57 with 75% of rec709 has helped my results quite a bit...I will post the results when I get home.
Just to make sure, when measuring amplitudes scale, I must first get baseline measurements (white) at 100% intensity, then I measure my primary and secondary amplitudes at 25-50-75 and 100% amplitudes for each of the 6 colors? If so, Can I do the same for each saturation level, or is it good for only 100% saturation?
stef2 is online now
Old 05-22-2014, 10:43 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
You need a 100% intensity reading for amplitude and you need a 100% saturation reading (at any intensity you choose) for the saturation sweep.
Tom Huffman
Springfield, MO
Old 05-26-2014, 02:05 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3197
http://www.avsforum.com/t/1533342/display-3-pro-for-use-with-chromapure-and-small-pelican-case
D3 pro for sale if anyone needs one.
LG 65E6P / Sony X800
Marantz AV7702II / Outlaw Model 7140
Klipsch RF7II's / RC64II / Dual Rythmik FV15HP's
gadgtfreek is offline
Old 05-26-2014, 11:52 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Lumagen Calibration Test
I posted this in a separate thread because I thought that it might have a more general audience. However, it is also of specific interest to ChromaPure users.
Tom Huffman
Springfield, MO
Old 05-27-2014, 07:33 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
When using the build in pattern generator, and measuring the color checker, the first click on a color patch reads the currently displayed pattern, with the patter generator updating the pattern, after the measurement. This requires two measurements, for a correct measurement.
It would be great if you could add automation to some other modules also, like Color Management, Advanced CM, Gamma. This would significantly reduce the measurement time, as after this automation, I can jump straight into manual calibration with the continuous measurement mode.
Audionut11 is offline
Old 05-27-2014, 12:07 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Yes. We are aware of this. Using the internal patterns requires two-clicks in the ColorChecker module. Fixing this is on our development roadmap, as is the other issue you mention.
Tom Huffman
Springfield, MO
Old 06-05-2014, 05:29 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Hi,
I want to try to calibrate my JVC X35 directly from the lens.
What i have to do, to have a reliable calibration as a result,taking into account also my screen (Da-lite JKP Affinity 1.1 ),because if i take the measurements for RGB at 100% stimulus from the lens,the values are different against the readings from the screen.
If i make the calibration from the lens ,is OK to make the all session in this way?
maximus74 is offline
Old 06-07-2014, 02:03 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Originally Posted by maximus74 View Post
Hi,
Use the meter correction feature, with readings from the screen as the reference and readings from the lens as the field meter.
Tom Huffman
Springfield, MO
Old 06-07-2014, 02:52 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Hi,
I can make the calibration at 100% stimulus from the screen as a reference meter,after that all the calibration session to calibrate from the lens as a field meter?
Old 06-07-2014, 08:07 AM
Gordon Fraser's Avatar
Quoted: 127 Post(s)
Liked: 156
Hi,
In meter correction measure REFERENCE pointing at screen. Then remeasure FIELD pointing at projector....then PRESS APPLY CORRECTION , then do all measurements pointing at projector
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
Old 06-07-2014, 10:09 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Old 06-07-2014, 06:07 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
FYI.
I had a chance this weekend to take some measurements in our lab with the $25,000 Minolta CS-2000 spectro, which many consider the gold standard. I compared those measurements with the measurements we have recorded from the instrument we use to create our PRO meter corrections, the $7,000 JETI 1201 spectro. The results were within 0.001 of one another. This just reinforces my belief that the JETI units are a great buy. $7-$9K is not inexpensive by any means, but in the world of reference spectros the JETIs are actually quite a bargain.
ConnecTEDDD likes this.
Tom Huffman
Springfield, MO
Old 06-07-2014, 07:41 PM
Quoted: 1418 Post(s)
Liked: 594
Tom,
Did you test plasma?
JimP is offline
Old 06-07-2014, 07:49 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Originally Posted by JimP View Post
Tom,
It was a Panasonic plasma I tested this on. The 1201 is fine with plasma if you are able to take multiple reads and then average to smooth out the variation. For this reason, the 1201 is really just useful for profiling. I would not recommend it for a standalone color analyzer. I wouldn't recommend the CS-2000 or 1211 for a standalone color analyzer either, but for different reasons.
Tom Huffman
Springfield, MO
Old 06-12-2014, 05:32 AM
stef2's Avatar
Quoted: 370 Post(s)
Liked: 226
I just want to say how happy I am with chromapure. I finally finished calibrating my JVC RS57 and I learned a lot. My grayscale looks better, I was able to fine tune my gamma curve and my colors now look more accurate, using the 75% saturation target helping a lot.
The only thing I would do differently is to buy a more accurate sensor, since with the one I have, an EyeOne Display Pro, the readings when I calibrate my gray scale fluctuate way too much...at 10, but even 20 and 30%, if I take readings with the projector on for 1, then 2,3 or 4 hours, the dE varies a lot, in no particular direction, for both red and blue, making any fine adjustment useless...I even tried averaging 12 readings: the result seems accurate for the moment I take it, but becomes inaccurate an hour later, then two, then three, without any sign of stabilization as time goes by.
Any idea what could be causing that?
Well, as long as I like my picture...
stef2 is online now
Old 06-12-2014, 06:36 AM
Liked: 594
That probably has more to do with your lower level readings being at the limits or below the limits of the i1d3. Front projectors aren't all that bright to start with.
JimP is offline
Old 06-12-2014, 07:06 AM
stef2's Avatar
Quoted: 370 Post(s)
Liked: 226
What puzzles me is the fact tht when I take multiple readings with short intervals of time between them, the results are usable and stable, down to 20%. 10% reading fluctuates a lot, and I understand thats my i1d3 limitation. But 20 and 30% being very stable when taking multiple readings within a short interval of time must mean my meter is quite accurate for those light levels? then, if three hours later, readings are significantly different at 20 and 30%, it should be because the projected picture has really changed?
Then, how shoud I calibrate at best if my readings for 20 and 30% are constantly changing? I have even tried readings every hour up to 6 hours, and saw no sign of stabilisation, just fluctuation, with no clear direction (sometimes 20% has too much blue, sometimes red is in excess, without me touching anything...) Do my eyes see a difference? I am not sure, readings being an hour apart...
stef2 is online now
Old 06-12-2014, 08:15 AM
Liked: 594
stef2,
What have you been doing about warm up times?
Also, consider the amount of time you're calibrating. An example of this would be if you're into your 2nd hour of calibrating and got your 20 and 30% where they look their best and they seem repeatable. Then the next day turned the projector on again (with little to no warm up) and find that these values have changed.
JimP is offline
Old 06-12-2014, 10:04 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
This is a JVC problem. They are notorious for this. The only thing you can do on your end is point the meter at the lens and use the diffuser. This will raise the measured light level and help with this somewhat. There's really nothing else you can do.
Tom Huffman
Springfield, MO
Old 06-12-2014, 10:33 AM
ScottJ's Avatar
Quoted: 310 Post(s)
Liked: 155
I believe the newer models (2012 and up -- RS46/X35 and newer) have a new bulb design which has helped alleviate this issue.
ScottJ is offline
Old 06-14-2014, 05:54 AM
stef2's Avatar
Quoted: 370 Post(s)
Liked: 226
stef2,
The fluctuation happen even after more than a four hours warm up...I get different results at 1, then 2, then 3,.. and so on...I have tested it up to 6 hours. And my JVC is one of the newest ones, a 2014 RS57.
Now, I am convinced it is my bulb that fluctuates and not the probe itself. As Tom said, there is nothing I can do.
stef2 is online now
Old 06-14-2014, 09:18 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
I don't mean to single you out, I really don't. However, this type of issue comes up often enough that I want to comment on the particular type of mistake going on here. Are meters sometimes defective? Yes, they are. However, the error rate for the measuring equipment is infinitesimal compared to the performance flaws in mainstream commercial displays.
When users observe some problem with a measurement there is often an almost reflexive tendency to blame the measuring equipment. But this gets everything backwards. You use the measuring equipment to evaluate the display. You don't use the display to evaluate the measuring equipment.
The vast majority of the time, when you see problems with readings that means there's some real problem with the display. Very rarely measuring equipment will fail. I have sold. . . well, I have lost count, but it must be over 1,000 i1 Display Pros. Among that batch I have had TWO that were returned as defective, one recently. In comparison, there are countless examples of commercial displays that are released with profound performance deficiencies. My favorite example is the high-end 2010 Panasonic plasmas that all had a rather large and nasty color decoding error. So too, sometimes the software has a bug that leads to an erroneous reading, but these are generally identified and fixed relatively quickly. In short, TRUST YOUR INSTRUMENTATION.
stef2 likes this.
Tom Huffman
Springfield, MO
