The Official ChromaPure thread - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 254Likes
post #5491 of 7266 Old 06-15-2014, 07:33 AM
stef2's Avatar
Quoted: 336 Post(s)
Liked: 213
I dont feel singled out...
My conclusion is the same as yours...
stef2 is online now
post #5492 of 7266 Old 06-16-2014, 03:20 AM
ConnecTEDDD's Avatar
Quoted: 1066 Post(s)
Liked: 1539
Originally Posted by TomHuffman View Post
FYI.
I had a chance this weekend to take some measurements in our lab with the $25,000 Minolta CS-2000 spectro, which many consider the gold standard. I compared those measurements with the measurements we have recorded from the instrument we use to create our PRO meter corrections, the $7,000 JETI 1201 spectro. The results were within 0.001 of one another. This just reinforces my belief that the JETI units are a great buy. $7-$9K is not inexpensive by any means, but in the world of reference spectros the JETIs are actually quite a bargain.
Using a Dolby Monitor with a quick comparison of 2x JETI 1211 meters the difference was about xy 0.0001. This shows that the unti-to-unit variations of JETI Spectro's are very tight.
PhotoResearch PR-740 (35.000$) vs. JETI 1211 on Dolby Monitor had xy 0.001 difference so they are measuring virtually the same if you count both meter's repeatability to that reported difference.
Synnove likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #5493 of 7266 Old 06-19-2014, 05:23 PM
TomHuffman's Avatar
Quoted: 687 Post(s)
Liked: 613
ChromaPure 2.5.3 Released
ChromaPure 2.5.3 is available for download on the ChromaPure News page.
This is a small maintenance release focused mainly on improving support for the built-in test patterns. See the Release Notes for details.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #5494 of 7266 Old 06-20-2014, 07:28 PM
TomHuffman's Avatar
Quoted: 687 Post(s)
Liked: 613
New Lumagen Firmware
I strongly recommend that all Lumagen users update with the latest firmware just released.
I previously measured a non-trivial difference between the Lumagen (and the Quantum Data) and the AccuPel. With this new firmware update that difference is gone. Comparing measurements between the two yields no more than a 0.001 difference, even at the low end of the grayscale.
ConnecTEDDD likes this.
Tom Huffman
Springfield, MO
post #5495 of 7266 Old 06-20-2014, 07:53 PM
thrang's Avatar
Quoted: 1605 Post(s)
Liked: 1382
Time for another calibration it seems...
thrang is offline
post #5496 of 7266 Old 06-20-2014, 09:32 PM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2393
Good timing!!! My Accupel 5000 is enroute to Light Illusion where they'll use it for integration with LightSpace so my only external generator is a Mini 3D. Thanks for the update info. Now I can calibrate confidently with my favorite 1D cal software, ChromaPure.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
post #5497 of 7266 Old 06-21-2014, 01:17 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Smile
Thanks,Tom
Last night i had a calibration seesion,a quick one...
I did a calibration from my JVC lens,profiling my Eye One Display 3 Pro, my Mini 3D with the latest firmware and my ChromaPure 2.5.3.
Wonderful result,and a way easier to calibrate in this way compared with "from the screen".
Now the calibration is so good just from the auto cal ,that i didn't need to make corrections after that.
Fantastic stuff...thanks ChromaPure and Lumagen,the timing for the latest firmware from both, was perfect.
maximus74 is offline
post #5498 of 7266 Old 06-22-2014, 02:39 AM
stefanelli73's Avatar
Originally Posted by maximus74 View Post
Thanks,Tom
Please, can you post the results?
stefanelli73 is offline
post #5499 of 7266 Old 06-22-2014, 01:09 PM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Sorry,i didn't saved the report from ChromaPure
post #5500 of 7266 Old 06-22-2014, 04:05 PM
Gamma: 2.3 or 2.4?
Space color: Normal or Wide?
Preset?
Color temperature?
Have you done also the grayscale (12 points) with auto-calibrate?
post #5501 of 7266 Old 06-22-2014, 10:22 PM
buzzard767's Avatar
Liked: 2393
No matter. The "new" AVS only allows 19.5KB pdf files - totally useless.
Buzz
post #5502 of 7266 Old 06-23-2014, 04:44 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Hi,stefanelli73
Color Temp:7000K
Gamma :Normal
Color Space: OFF
Yes,grayscale (12 points) with auto-calibrate,with one little adjustment (one click for red) at 10%,for a perfect greyscale from 10-100%.
Maybe i will test again with color Space:Standard at the next calibration.
Off course before to start auto cal i made the adjustment for greyscale at 100%.
I selected Gamma BT.1886 from ChromaPure and the result was fantastic with Gamma from 2.2 at 5% and 2.4 at 100%
I hope this will help you.
post #5503 of 7266 Old 06-23-2014, 04:04 PM
I do not really like using the GAMMA BT.1886, in some scenes of the movies seems to use dynamic iris, type in the scene of CASINO ROYALE, when Daniel Craig opens his eyes .... anyway thanks for the information.
post #5504 of 7266 Old 06-24-2014, 01:42 AM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Before using BT.1886,i already used variable gamma as i really liked.
I always believed that the JVC projectors will always benefit from this tehnique.
post #5505 of 7266 Old 06-24-2014, 03:32 AM
Quoted: 1394 Post(s)
Liked: 588
Tom
I recently built a desktop computer for calibration only and am installing Chromapure on it.
Does it matter where I put the license number as you have to install it the first time you launch Chromapure?
Seems that at one time I had instructions about putting the license file in the Chromapure program file. Can't find those instructions and want to clarify.
JimP is offline
post #5506 of 7266 Old 06-24-2014, 03:41 AM
Liked: 1539
Originally Posted by JimP View Post
Tom
Hi Jim, select to import your licence, it will bring you a window to Browse the location of the *.lic file and later ChromaPure will automatically save it.
post #5507 of 7266 Old 06-24-2014, 09:54 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
Well, I just got the thrill of my life. I went to update my CP with the latest update, just like I have 3 times before. It said CP installed sucessfully, Closed out and went to launch it. It said chomapure is no longer workable, windows will try and find a solution and report back. Closed out, Shut Down laptop and restarted CP . Same Thing. Tried checking for update to .Net and No updates needed.
I ended up Removing CP and reinstalling and it is now working. I have not tried it for a Calibration yet. I sure hope I have all my Lic. when I use it.
I am sure Tom would of come to the rescue, but this was nerve wrecking.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #5508 of 7266 Old 06-24-2014, 06:22 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
^ I think it's always been recommended that old CP versions need to be uninstalled before installing new versions.
Kilgore is offline
post #5509 of 7266 Old 06-24-2014, 08:32 PM
buzzard767's Avatar
Liked: 2393
True.
Glenee - if your meters show up your license is installed.
Buzz
post #5510 of 7266 Old 06-25-2014, 03:58 PM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
It was most likely Computer Operator Error. I only run Mac's now. The only windows machine I have is the laptop I have the Chromapure and stuff related to calibrations Sure wish someone would make this stuff to operate on a Mac. I know I can operate in parallels.
Don't you guys ever get tired of updating you windows machines. Every time I go to use it there are at least 20-40 min's of updating and I don't have a thing on it except Windows 8.1. With that kind of time at the Office my employee's would spend a lot of time just updating windows stuff. $$$$$$$$$$
thrang likes this.
Glenee is offline
post #5511 of 7266 Old 06-26-2014, 08:48 AM
mskreis's Avatar
Quoted: 49 Post(s)
Completely agree about windows. I'm ready for a Mac version of Chromapure.
thrang likes this.
JVC RS57; Marantz AV7702mkII; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni; SVS 20-39 PC+
mskreis is online now
post #5512 of 7266 Old 06-26-2014, 09:14 AM
thrang's Avatar
Liked: 1382
Absolutely...Windows is just a POS operating system...it will never be solid since there is a disconnect between OS and hardware development, unlike the mac.
Hopefully Chrompaure can develop an OS X version in the near future.
Brian Hampton and Glenee like this.
thrang is offline
post #5513 of 7266 Old 06-26-2014, 09:26 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
thrang,
Kudo's on your Audio set-up, I can see no expense spared. I have McIntosh MC-452, C-2300, MCD-500, MR-88, Linn Lp12 and Sonus Faber Guarneri Mementos.
Glenee is offline
post #5514 of 7266 Old 06-26-2014, 09:57 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
Hear, hear!!
millerwill is offline
post #5515 of 7266 Old 06-26-2014, 11:26 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
I have no problems whatsoever with my Windows machine. Absolutely none. Zero. Zilch. I love it.
Kilgore is offline
post #5516 of 7266 Old 06-26-2014, 11:29 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Never. Any updates happen automatically in the middle of the night while I'm asleep.
You do know that you can schedule Windows Update to work any automatically any time you want, right?
Kilgore is offline
post #5517 of 7266 Old 06-27-2014, 07:40 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
Yes Sir. My case is a unique one in that, I only use this machine when I want to do Calibrations. So in my case it's a hassle. I like many have been around Windows since the first one. Actually I have been around and used Dual Tape Wangs, TRS 80's, 5 1/4 Floppy's, 3.5, and the start of windows which was started from a little program that Microsoft didn't invent called GEM.
I am going to tell you that MS has never had a full working windows edition yet, since it started windows. The only reason they come out with a new version of windows is to fix the problems with the previous version, and then they don't do their Quality control and we start the frustrations all over again. What they need to do is just make the Base OS better and not try to reinvent the wheel every time.
We went all Mac about 5 years ago, and our Computer related problems ( Lost Time) dropped 90%.
This is just a opinion and everyone has one, but for what we do Apple works out for us so much better.
H Stevens likes this.
Glenee is offline
post #5518 of 7266 Old 07-02-2014, 08:34 AM
hollisavrct's Avatar
Quoted: 51 Post(s)
ColorChecker in MP4 format
Does anyone know if the calibration disc sold by ChromaPure is in MP4 format? I am using a WD TV Live Plus as my generator source and I have to use MP4 format. I have the GCD MP4 loaded onto my flash drive but the colors do not match up. I would buy the ChromaPure disc but I don't think it is in the right format. I own a Sencore VP403C but the colorchecker pattern is not on it.
Any ideas?
hollisavrct
hollisavrct is offline
post #5519 of 7266 Old 07-02-2014, 02:21 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Your mediaplayer can read iso files, so why not store the disc as an iso image for calibration?
Wouter73 is offline
post #5520 of 7266 Old 07-02-2014, 02:55 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Be careful with the WDTV. I believe RGB LOW is the only colour space which complies to standard. Even then, it can change between firmwares. I also had problems with an older display where luminance would go completely off the reservation after switching to a different HDMI input and then back to the WD again.
fahrenheit is offline
Reply Display Calibration
