The Official ChromaPure thread - Page 185 - AVS Forum | Home Theater Discussions And Reviews
 255Likes
post #5521 of 7283 Old 07-02-2014, 02:59 PM
ConnecTEDDD's Avatar
Quoted: 1082 Post(s)
Liked: 1561
Originally Posted by Wouter73 View Post
Your mediaplayer can read iso files, so why not store the disc as an iso image for calibration?
Check if you Media Player can play Blu-Ray ISO files with Full Menu Navigation.... If it can play them with full menus then ask from Tom if he can provide you the Blu-Ray ISO Download instead of sending you the actual Blu-Ray Disk Copy.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #5522 of 7283 Old 07-02-2014, 03:03 PM
Liked: 1561
Originally Posted by hollisavrct View Post
Does anyone know if the calibration disc sold by ChromaPure is in MP4 format? I am using a WD TV Live Plus as my generator source and I have to use MP4 format. I have the GCD MP4 loaded onto my flash drive but the colors do not match up. I would buy the ChromaPure disc but I don't think it is in the right format. I own a Sencore VP403C but the colorchecker pattern is not on it.
Any ideas?
hollisavrct
Hi, I have seen that ChromaPure Calibration Disc contains the ColorChecker Patterns and not the ColorChecker Skintones Patterns that came as a measuring feature of ChromaPure after the initial disk release.
post #5523 of 7283 Old 07-02-2014, 04:32 PM
hollisavrct's Avatar
Quoted: 51 Post(s)
So the disc does not have the correct pattern which means the only pattern that works is the built in one?
hollisavrct
hollisavrct is offline
post #5524 of 7283 Old 07-02-2014, 04:40 PM
Liked: 1561
hollisavrct
ChromaPure software has 2 ColorChecker type of measurements:
ColorChecker Classic (24 Patches)
ColorChecker Skintones (16 Patches)
ChromaPure Calibration Disc has the required patterns for the ColorChecker Classic measurement.
Currenly, ColorChecker Skintones are not available inside that disk according to current version features list.
Of-course it has the correct RGB Triplets for each pattern in the ColorChecker Classic Chapter.
post #5525 of 7283 Old 07-02-2014, 08:51 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
We released the Skin Tones update to ChromaPure AFTER we had released the disc. However, the disc has been subsequently updated. Existing users can get a new version on request.
ConnecTEDDD likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #5526 of 7283 Old 07-02-2014, 08:57 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
In fact, the Sencore does not support any custom colors. That is, it only supports RGBYCMW at 21 levels of intensity. You'll need a more modern signal generator for this.
The disc is a standard Blu-ray.
Tom Huffman
Springfield, MO
post #5527 of 7283 Old 07-03-2014, 03:44 AM
Quoted: 51 Post(s)
Can I use the GCD disc?
hollisavrct
post #5528 of 7283 Old 07-03-2014, 04:25 AM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
You'll have to ask the author.
Tom Huffman
Springfield, MO
post #5529 of 7283 Old 07-04-2014, 11:41 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
I bought the Chromapure package with a i1 Display 3 Upgraded (Pro) meter. I m going to use a 'HTPC CMS' solution (http://www.avsforum.com/forum/139-display-calibration/1471169-madvr-argyllcms-57.html#post25501642) but I need a ''meter correction file''. Did my Chromapure package came with a meter correction file? I can t find anything about this. All I have is a license file for Chromapure.
sanderdvd is offline
post #5530 of 7283 Old 07-05-2014, 12:53 AM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
The corrections are built-in to the ChromaPure license file. You should have also gotten a calibration report that documents the corrections made. Presumably the information in this document can be used to generate a correction file for ArgyllCMS, but you'd have to ask them about this.
Tom Huffman
Springfield, MO
post #5531 of 7283 Old 07-12-2014, 03:14 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
Which of the next 9 calibrations is the best when I want the best compromise between Greyscale, Gamma and Color Gamut?
CALIBRATION 1
CALIBRATION 2
CALIBRATION 3
CALIBRATION 4
CALIBRATION 5
CALIBRATION 6
CALIBRATION 7
CALIBRATION 8
CALIBRATION 9
post #5532 of 7283 Old 07-12-2014, 03:55 PM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
gamma is really high but i think 8 is the best of them "low" DE and pretty steady gamma of ~2.46 did you aim for 2.5?
did you select random settings or why did you get so weired readings?
mightyhuhn is offline
post #5533 of 7283 Old 07-12-2014, 04:08 PM
Quoted: 1397 Post(s)
Liked: 589
sanderdvd,
Which display or projector are you calibrating?
JimP is online now
post #5534 of 7283 Old 07-12-2014, 05:04 PM
Liked: 1561
Originally Posted by JimP View Post
sanderdvd,
sanderdvd,
use 4-Point Saturation + ColorChecker of ChromaPure next time you will measure, it will makes you easier to decide between different post-calibration reports.
post #5535 of 7283 Old 07-12-2014, 10:42 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
Aimed for 2.4 gamma. What do you think about CALIBRATION 6?
post #5536 of 7283 Old 07-12-2014, 10:43 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
Originally Posted by jimp View Post
sanderdvd,
which display or projector are you calibrating?
jvc rs-49
post #5537 of 7283 Old 07-12-2014, 10:43 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
sanderdvd,
Where do I do this in CP?
post #5538 of 7283 Old 07-13-2014, 02:31 AM
Gordon Fraser's Avatar
Quoted: 118 Post(s)
Liked: 149
You use the ADVANCED COLOUR MANAGEMENT tab to see the multiple saturation levels and to set the luminance they are measured at. The reality is the colour gamut charts you post are pretty meaningless. They show accuracy of a handful of points at maximum saturation and stimulus levels. Put on a disc or tv and press pause and see how much stuff is on screen that is actually BOTH maximum saturation and stimulus...i suspect that there will be nothing. What is much more important is the accuracy of the stuff in the middle of the colour cube, not the stuff at the extremes.
On the bottom section of the tabs on left of screen on chromapure is where the colour checker tab is. That allows you to check around 80 isH separate colours and it is more useful but again, it's just a small subset of the colours your display can show. It is an "industry" reference though. You will find when you investigate this more that there are LOTS of displays where the outer edges of the cube can look great but the inside is a non linear mess with all sorts of errors...and sometimes those errors are actually made worse by using the internal tools of the display to fix the outer edge.
As for the greyscale and gamma. Well, I would suggest that if you have an error in the greyscale you don't want it to be that there is too much red or green, too much blue is nicer to look at. So I quite like 3...but as has been pointed out 8 has better numbers and they are very low...but the error is in the wrong direction...so if you had the ability I'd be doing a visual comparison of them both to see which I actually preferred.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #5539 of 7283 Old 07-13-2014, 04:45 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
dE
<1 very good
<2 good
<3 not good
>3 bad
5.3 very bad...
so i think it's pretty bad
post #5540 of 7283 Old 07-15-2014, 02:37 PM
Quoted: 51 Post(s)
chromapure Pattern Source
Can the calman VPS-2000 USB stick be used as a pattern source for chromapure?
hollisavrct
post #5541 of 7283 Old 07-16-2014, 05:41 PM
flargosa's Avatar
I bought Chromapure Standard, I got a Paypal receipt but no license. I called support but no answer, how long does it usually take before they email the license file?
flargosa is offline
post #5542 of 7283 Old 07-16-2014, 07:01 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
I think it took about a week to 10 days - they have to check the meter and put corrections for the meter into the license file (I think)
bgoering is offline
post #5543 of 7283 Old 07-16-2014, 10:17 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
E-mail notification of your purchase didn't arrive until 7:13PM. I sent you a license 20 minutes later.
Tom Huffman
Springfield, MO
post #5544 of 7283 Old 07-17-2014, 08:00 AM
flargosa's Avatar
I received the license yesterday. Thanks.
flargosa is offline
post #5545 of 7283 Old 07-20-2014, 08:03 PM
colleycol's Avatar
Quoted: 21 Post(s)
I am thinking of buying ChromaPure to have in contrast to Calman. I need to weight my alternatives.
I have two meters for the Calman software, a i1Pro and a Display 3.
I want to profile the meters.
So first question, will I be able to use these meters? And if yes, do I have to buy an additional meter license to profile?
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #5546 of 7283 Old 07-20-2014, 09:21 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
Yes, we support both meters. No, ChromaPure Standard includes a license for up to two meters for precisely this purpose, so no extra purchase is required.
Tom Huffman
Springfield, MO
post #5547 of 7283 Old 07-21-2014, 01:46 PM
Chris5's Avatar
Quoted: 43 Post(s)
Liked: 29
Hi Tom
Sorry if this has been asked before re calibrating LG OLed TVs. Have you done any testes on them re which existing I1d3pro meter setting works best with them e.g. LCD mode and how far off it will be from a yet-to-be-implemented oled mode.
Many thanks
Chris
Chris5 is offline
post #5548 of 7283 Old 07-23-2014, 02:43 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
Originally Posted by Chris5 View Post
Hi Tom
Not yet. I am waiting for the price to come down to a more reasonable level.
Tom Huffman
Springfield, MO
post #5549 of 7283 Old 07-23-2014, 02:47 PM
TomHuffman's Avatar
Quoted: 699 Post(s)
Liked: 621
Help needed for project
We are working on a ChromaPure-related project for which we need some assistance.
We are looking for a native German speaker who is also fluent in English.
We are also looking for a native Italian speaker who is also fluent in English.
We can pay a modest sum for the assistance we require.
If qualified and interested, please contact us at support@chromapure.com
-TH
Tom Huffman
Springfield, MO
post #5550 of 7283 Old 07-25-2014, 05:03 PM
Liked: 589
Tom,
On the Accupel 5000 signal generator, does the 100 and 75 in the "Color 100 Group" and "Color 75 group" refers to stimulus or saturation?
JimP is online now
Reply Display Calibration
