The Official ChromaPure thread - Page 187 - AVS Forum | Home Theater Discussions And Reviews
 258Likes
Old 08-08-2014, 01:36 PM
chunon's Avatar
Quoted: 2237 Post(s)
Liked: 1954
Originally Posted by dunan View Post
That's what's driving me nutty, some scenes skin tones look great but some others they look completely pale or'off' if you know what I mean. There seems to be a little too much blue or green in the wb that is throwing them off I think, but within all the 10 point controls the rgb is matched almost exactly at 100% even. Maybe notch up the reds? Idk, I'm at a loss lol.
Now if I click the tint down a couple of ticks, cyan gets perfect but Magenta gets thrown off and no matter what I adjust it will not budge either.
What size patterns are you using and which meter ?
chunon is online now
Old 08-08-2014, 02:01 PM
dunan's Avatar
Quoted: 62 Post(s)
100% patterns and an iD3 meter. Also using the AVS709 disc.
Also this is the WB I have right now. They are all maybe 1% of each other for all 10 points but they look dominant in green, maybe that's the problem. Maybe increase the reds and blues so they are slightly above green? That's about as good as I can get I think.
Name:	precal wb080814.jpg
dunan is offline
Old 08-08-2014, 05:04 PM
chunon's Avatar
Liked: 1954
Do cms at 75 75. You also might want to try smaller windows . mascoir has a really nice disk optimized for chroma pure. I like the 6.5% windows
Old 08-08-2014, 05:28 PM
dunan's Avatar
Quoted: 62 Post(s)
OK i'll try it and see what i get
...mascoir? Is that a user or company?
dunan is offline
Old 08-08-2014, 05:33 PM
chunon's Avatar
Liked: 1954
Just do a search here on the forum he is a forum member that created his own calibration pattern disc
Old 08-08-2014, 05:53 PM
dunan's Avatar
Quoted: 62 Post(s)
ok, great
I'm seeing the problem with the white balance/greyscale. I'm adjusting the 100 point. I get 100 perfect, so I do 90. Get 90 perfect, it has tweaked 100 out of whack again. I fix 100, then move to 90. Get 90 and 100 right so move to 80. Get 80 right but 80 tweaked 90. Fix 90 but that tweaked 100 again. This is a revolving door of craziness.
I've been solely working on grayscale all day.
No wonder I cant get a good grayscale. I have no idea what to do from here if the tv itself will not permit me to make accurate adjustments.
dunan is offline
Old 08-08-2014, 05:59 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
ok, great
just do little changes and do a pattern run to see how it is affecting all the points.
you will get a feel for how the points interact with each other.
first find the points with the greatest error.
say 30 then 60 and 90 are high.
work a little on 60 and then rerun the scale.
you can not just hammer one point and expect others not to change.
kind of a dance.
Loving D65
CalWldLif is offline
Old 08-08-2014, 06:05 PM
chunon's Avatar
Liked: 1954
^^^^yes do a complete greyscale run make adjustments then do another run if you try to adjust just one or two points it is like chasing your tail
Also if you are using to large a window size your are fighting abl also
I really think the 6.5% patterns will do the trick for you
Old 08-08-2014, 07:49 PM
Quoted: 1462 Post(s)
Liked: 604
Originally Posted by TomHuffman View Post
Yes, you could certainly do that.
BTW, we will be releasing a firmware update for the AccuPel in the next few days that offers substantial improvements in speed when calling user colors from the PC (useful for LUT calibrations that require a large number of sequential colors) and enhanced abilities to display precision colors from the remote and OSD.
For those calibration programs that can access the AccuPel, will their code have to be rewritten?
Will the Accupel Desktop application also change?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
Old 08-08-2014, 08:31 PM
TomHuffman's Avatar
Quoted: 708 Post(s)
Liked: 623
They won't HAVE to be re-written because the existing codes will be retained. However, to get the speed increase, yes, they would have to be re-written.
No, neither change will affect the desktop application.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Old 08-08-2014, 09:21 PM
TomHuffman's Avatar
Quoted: 708 Post(s)
Liked: 623
New AccuPel Firmware
We have released new firmware for the AccuPel DVG-5000 video test pattern generator. This firmware is free to all DVG-5000 owners.
The new firmware allows for much faster calls of sequential colors via USB commands, which is useful for LUT calibrations. The firmware also adds support for the ability to define and display User Colors with the remote control and OSD in full 8-bit or 10-bit precision.
See the Support tab on the AccuPel page for a download link.
Tom Huffman
Springfield, MO
Old 08-09-2014, 08:12 AM
dunan's Avatar
Quoted: 62 Post(s)
The 6.5% patterns - are those size and for doing colors/grayscale? Also, I found a neat trick in chromapure - do the grayscale and gamma at the same time interactively - unless that's already known and I'm just figuring it out...lol
I completed the calibration for the most part, I'll go back later and do some minor tweaking to finish it up. Still am not able to get cyan under 2.6 dE and it's about 3/4 the way out of the reference box. Bugs me to no end because I went over and over the grayscale and gamma to get it as correct as possible. Yellow and Magenta are not nearly as out, they are close to being reference.
I'll post the charts later this afternoon, had to work today. The only thing I can't seem to fix is a bump in red between 40-60 in the gamma chart. I'll try to fix it but if not, I have all the settings written down, I can always revert back if it gets out of hand.
Overall it looks good, I didn't get to watch much other than a little bit of frozen (I have a 3 yr old) to test how it looked on and I'd say it passes, but CG is so different color wise, I have to see something like Pacific rim or blade runner to see if it's a good calibration.
Feel like I just wrote in an online diary... Lol
dunan is offline
Old 08-09-2014, 11:09 AM
chunon's Avatar
Liked: 1954
Yes 6.5% across the board
Old 08-09-2014, 01:15 PM
dunan's Avatar
Quoted: 62 Post(s)
What do the smaller size patterns do exactly? I didn't think it would matter?
dunan is offline
Old 08-09-2014, 01:59 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
It's a plasma thing. ABL - automatic brightness limiter. There's only a certain amount of power they let let the screen draw. So if you have too much bright stuff on the screen the whole picture gets dimmer. If you use full screen patterns to do greyscale, for example, as you go from 10% to 100% the total brighness of the screen varies from pattern to pattern because of the limiter. Patterns that take up 6.5% or so of the screen (or less) are generally considered "safe" because even a 100% luminance pattern isn't limited too badly by ABL. Of course, the exact effect differs by manufacturer.
Adjust your gamma with 6.5% patterns and then measure with full screen. You'll see it quite unmistakably. There will be a dogleg in your screen brightness.
rmongiovi is offline
Old 08-09-2014, 02:23 PM
dunan's Avatar
Quoted: 62 Post(s)
So is there an option in chromapure to use these patterns? I'm still not very familiar with the software yet.
Are the patterns only used for gamma/grayscale? Not for color or use them for color also?
dunan is offline
Old 08-09-2014, 02:50 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
If you're just using Chromapure to read the screen, it doesn't care how much of the screen the pattern fills up (as long as you aim the probe so that it only sees pattern and no blank screen). If you're using a pattern generator then you have to select what size patterns it generates. So either use a disc with smaller patterns (I like Mascior's) or set up your pattern generator to use smaller patterns.
You'd want to use the smaller patterns for everything. The correct luminance of the colors is based off of the luminance of white, and you want to take ABL out of the picture (pun intended) as much as possible for the entire calibration. ABL is an extra variable that you don't need when trying to calibrate to a standard that doesn't include it.
Old 08-09-2014, 03:17 PM
dunan's Avatar
Quoted: 62 Post(s)
So the size of the pattern itself makes for a better calibration? Lots of good info, thanks you guys. I'm downloading the pattern disc from mascoir's website later today, we'll see how it goes.
dunan is offline
Old 08-10-2014, 07:20 AM
dunan's Avatar
Quoted: 62 Post(s)
Tried mascoir's patterns, and the calibration came out slightly differently, a little more accurate in the cyan but now the yellow is of, but not as bad as cyan was in the previous calibration . It's still throwing the picture off some.
So can someone explain the importance of primary vs secondary accuracy in the CIE chart?
I want to really get the secondaries under control, so is it OK to sacrifice a little bit of primary accuracy to get the secondaries right or does it not work that way?
dunan is offline
Old 08-10-2014, 01:58 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
If you get the dE under 1.8 (I aim for 1.0 to 1.5), you will have a very good calibration. Allthough there is a difference of opinion on the matter, there are those who argue (and rightly so in my opinion) that, in actual video footage, you cannot differentiate a dE lower the 1.8. I mean you can aim for a lower number but you won't see the difference. The reason I tell you this is that you might want to try to let go of the overdone low dE on the primairies to see if that allowes you to do better on the secondairies.
Wouter73 is offline
Old 08-10-2014, 02:53 PM
buzzard767's Avatar
Quoted: 1648 Post(s)
Liked: 2424
If you don't profile the D3 to a spectro meter you may well be quite a ways off to begin with and you'll never know.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Old 08-10-2014, 03:17 PM
dunan's Avatar
Quoted: 62 Post(s)
Originally Posted by Wouter73 View Post
If you get the dE under 1.8 (I aim for 1.0 to 1.5), you will have a very good calibration. Allthough there is a difference of opinion on the matter, there are those who argue (and rightly so in my opinion) that, in actual video footage, you cannot differentiate a dE lower than 1.8. I mean you can aim for a lower number but you won't see the difference. The reason I tell you this is that you might want to try to let go of the overdone low dE on the primairies to see if that allowes you to do better on the secondairies.
That makes sense and that's great info, thanks. I'll try that later and see how it goes.
One question that I can never seem to get an answer on is - is there a particular order in adjusting the hue/sat/luminance? I just found an article online that said to adjust hue/saturation first, then tweak the lightness. Is that true? My method right now is to tweak whatever is farthest from 0 first which in my case here is always luminance, drop it, then go for the next farthest which depending on the color is either hue or saturation.
How would I do that?
dunan is offline
Old 08-10-2014, 03:25 PM
buzzard767's Avatar
Liked: 2424
In ChromaPure it's the Meter Correction tab, but you need a spectro device for the Reference meter.
Buzz
Old 08-10-2014, 03:42 PM
dunan's Avatar
Quoted: 62 Post(s)
I just found that out watching Micheal chan's video on YouTube.
I don't have one nor do I know anyone with one. If I remember right They were upwards of $600 US.
dunan is offline
Old 08-10-2014, 04:58 PM
buzzard767's Avatar
Liked: 2424
Don't sweat it. You're just starting out. You're far too concerned about that last half a dE. Your colorimeter will get you into the ball park and for a non professional job that should suffice.
One thing is for sure and that is your display(s) will look much better than stock, and you won't be too far from as good as your displays can get. Have fun.
Buzz
Old 08-10-2014, 07:37 PM
Pres2play's Avatar
Quoted: 479 Post(s)
Liked: 264
So is profiling the i1D3 to a Spectro meter complicated?
Edit: will it save me from having to mail back my meter for a re-calibration after a year?
Pres2play is offline
Old 08-10-2014, 10:15 PM
TomHuffman's Avatar
Quoted: 708 Post(s)
Liked: 623
It is very simple. Use the Meter Correction module to take WRGB readings with a reference spectro and then WRGB with your colorimeter, and then click Apply.
Tom Huffman
Springfield, MO
Old 08-10-2014, 10:19 PM
TomHuffman's Avatar
Quoted: 708 Post(s)
Liked: 623
An i1Pro 2 is about $1K.
Here's our video.
http://www.chromapure.com/movies/cor...orrection.html
Tom Huffman
Springfield, MO
Old 08-10-2014, 10:58 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
You can always look for used i1 pro's (the model before the i1pro 2) on ebay. Just look for Rev D. The i1 pro seems like a pretty robust device. Unless it's been mistreated you can pretty much expect it to work well.
Old 08-10-2014, 11:40 PM
Pres2play's Avatar
Quoted: 479 Post(s)
Liked: 264
Is the original i1Pro still available new? Read it's just as good for calibrating displays as the i1Pro2.
