The Official ChromaPure thread - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 258Likes
post #5671 of 7322 Old 08-27-2014, 04:47 AM
vincz's Avatar
Liked: 0
Hi
After auto calibration for a perfect chromaticity CIE94 you need to adjust manually in radiance colors output CMS with the post calibration color gamut from chromapure ?
i think the auto calibration is good but for a perfect result, you need to adjust after? i'm right
my post CIE is not 100% inside "reference"
If YES, it's not a problem with 9x9x9 3dlut autocal?
let me know
thank you
vincz is offline
post #5672 of 7322 Old 08-27-2014, 01:47 PM
TomHuffman's Avatar
Quoted: 746 Post(s)
Liked: 633
Originally Posted by simonk83 View Post
Sorry to butt in here with something you've probably seen a million times, but we all have to start somewhere
Completely new to calibration, but I'm passionate about my movies and want the display to be as good as I can get it (within budgetary reason of course ). So I bought this today and am currently tossing up between Calman Basic and ChromaPure Standard. I'm leaning towards ChromaPure but I just want to make sure that it's going to be suitable, both for a total beginner (I hear good things, so I assume it's noob friendly, but just triple checking), for the meter above and for my TV (currently a Samsung F9000, with a projector to follow in the next year or so).
I should say right now that I'm colourblind (not severely, but enough to muddle things up). There's an argument that I may not need calibration at all in that case, but this being an enthusiast board I assume you get it (I know it's currently wrong, I want it to be right ). So that being said, and with this really being an objective tool that's going to tell me if a colour is correct or not without my eyes factoring into the equation, am I still going to be OK to use the software etc properly?
Thanks for your time, appreciate the help!
EDIT: I'm going to be needing a calibration disc as well... I see there's a specific Chromapure one, but being in Australia it'd cost a bit to get one shipped over (not to mention the time). On CurtPalme for example, the shipping actually costs more than the disc itself Any suggestions there?
We can provide the disc as a digital download on request so long as you have the ability to burn Blu-rays from an iso image. Yes, ChromaPure works well with this meter. I don't know how anyone other than you can answer a question about your ability to get a satisfactory calibration given your color-blindness. If you have a rudimentary understanding of the vocabulary and main concepts of display calibration, ChromaPure shuld be quite straightforward to use. The included Help file is quite good.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #5673 of 7322 Old 08-27-2014, 01:57 PM
TomHuffman's Avatar
Quoted: 746 Post(s)
Liked: 633
let me know.
To provide some perspective, the result of your 729-color calibration is an average dE of 0.6, with over 90% of the colors below a dE of 1.0. This is just about as good as it gets. You are focusing on the wrong thing, which is the result of a very few colors at the very edge of the gamut.
As we discussed, I don't know why these particular colors are problematic for your installation. I couldn't reproduce the problem, nor has anyone else reported this. Has anyone else had an otherwise excellent result with 729 auto-cal EXCEPT RGBCYM at the edge of the gamut at 100% stimulus having higher than expected luminance?
EDIT: If your display has an auto-iris, turn it off for calibration. A fixed iris is fine.
Tom Huffman
Springfield, MO
post #5674 of 7322 Old 08-27-2014, 04:02 PM
simonk83's Avatar
Quoted: 28 Post(s)
Thanks Tom.
EDIT: Sorted out via email
simonk83 is offline
post #5675 of 7322 Old 08-28-2014, 05:04 AM
maximus74's Avatar
Quoted: 95 Post(s)
Liked: 32
Hi,simonk83
I strongly recommend ChromaPure,even if you are beginner in calibration science.
It is very straightforward,easy to use, friendly interface, very powerful and above all a fantastic customer support.
ConnecTEDDD and nhcrew6 like this.
maximus74 is offline
post #5676 of 7322 Old 08-28-2014, 01:16 PM
vincz's Avatar
Liked: 0
Originally Posted by maximus74 View Post
Hi,simonk83
not easy, very difficult to have a perfect CIE for new 4K projector (jvc x500) and i'm not alone to have this mistake
it's not a problem with chromapure, you need before to understand how VP can work better in autocal
i check for the moment only in 5x5x5
my problem is probably with the color profil in VP. not sure to use the good one
with my old VP (jvc hd350) all is most easy with autocal
i'm pretty sure if i find i will be happy
vincz is offline
post #5677 of 7322 Old 08-28-2014, 04:21 PM
simonk83's Avatar
Quoted: 28 Post(s)
Hi,simonk83
Thanks, ordered it yesterday. And yes, the support has been great so far (and a shoutout to Kal from CurtPalme too).
simonk83 is offline
post #5678 of 7322 Old 08-29-2014, 01:23 AM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Originally Posted by Pres2play View Post
Adjusting the main color control had no affect, but when I lowered the blue component, instead of green, the luminance dropped down.
BEFORE:
AFTER:
Even though blue component has greater error now and bar looks whacky, blue as a whole has lower dE. Is this final result common/acceptable for calibrators?
Edit: Tom, do you think the error in blue is due to the spectral difference between plasma and OLED displays and meters being set to plasma?
Maybe I get better gamut luminance for blue if I use the "Auto" color space, which is closer to Rec709. Will try tomorrow, and use the Mini3d to dial in the color points if I need to.
Still working on why the blue luminance is so high.
Regarding OLED , I came across this year-ago blog at NegativeSpace, which states the white target for OLED monitors is actually different from Rec.709. The article refers to Sony professional monitors, so don't know how much of this relates to consumer OLED TVs. The highlight is used in the article.
"An overview of the process, first input a 100% white test signal into the monitor and then use the probe to objectively measure the screen. It will tell where this white image is hitting in the gamut by way of x and y coordinates. From here, RGB gains are adjusted until the probe verifies that white is hitting the correct coordinates, x .313 y .329. If you're using an OLED monitor, you will use different coordinates than x .313 y .329 and you may need to adjust Bias as well to compensate for chroma cast in the dark tones of the picture. This process is very similar to adjusting White Balance, just using 20% neutral gray instead of 100% white."
And in a related article in the same blog...
"...When we white balance a monitor we start at D65 and then adjust Red, Green, and Blue gains to push 100% into the correct target white point in the gamut. As is exemplified in the above graphic, this is represented by a two dimensional chart with coordinates. For LCD's, CRT's, and other legacy displays the coordinates for white within Rec. 709 are x .313 y .329. It turns out however, these targets aren't well suited for today's OLED monitors."
http://www.negativespaces.com/blog/2...libration.html
https://negative-spaces.squarespace....e-balance.html
Pres2play is online now
post #5679 of 7322 Old 08-29-2014, 04:42 AM
TomHuffman's Avatar
Quoted: 746 Post(s)
Liked: 633
This issue is about white balance, not the color gamut. It is not that x0.3127, y0.329 are intrinsically incorrect for Sony OLEDs, rather it is that the 1931 standard observer equations used to calculate CIE coordinates may need to be updated. There has been some work on this, but as of now the 1931 data is still the official standard. Sony recommends x0.307, y0.318 for their Trimaster professional OLED displays.
Tom Huffman
Springfield, MO
post #5680 of 7322 Old 08-29-2014, 05:02 AM
buzzard767's Avatar
Quoted: 1649 Post(s)
Liked: 2426
OLED offset: http://www.spectracal.com/forum/view...hp?f=13&t=4993
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #5681 of 7322 Old 08-30-2014, 01:57 AM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Thanks for the clarification, Tom. Please know I'm very happy with CP and would recommend to all my friends.
post #5682 of 7322 Old 08-30-2014, 02:08 AM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Originally Posted by buzzard767 View Post
I'll register tomorrow. Are there instructions on how to set it up in the meter?
post #5683 of 7322 Old 08-30-2014, 02:18 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Just realized I've been using the wrong picture mode all this time. Instead of Movie, I've been using Cal Night. I measured each mode and in Movie mode the blue color point is outside the gamut triangle, while in Cal Night it's inside. Perhaps this is the reason I'm having issue with blue. Will run it tonight.
post #5684 of 7322 Old 08-31-2014, 06:28 AM
Quoted: 1513 Post(s)
Liked: 626
press2play
Might not be a bad idea to compare the different picture modes and see which one gets you closer to target.
Keep in mind that color temperature settings may be different depending on picture mode so you'll want to verify that they're at an optimum setting for that mode. Meaning that in movie, warm 2 might be closest while in standard warm 1 might actually be closer.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #5685 of 7322 Old 08-31-2014, 12:06 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Thanks, Jim. I thought as long as I stayed away from the "funny" modes (Dynamic, Relax, Standard), I'd be safe. I'm also learning just how important the combination of picture mode and temperature settings can be; in fact, coupled with grayscale/gamma, the color gamut controls and the levels adjustment I have come to the realization that a workflow chart might be in my best interest, LOL.
post #5686 of 7322 Old 08-31-2014, 08:09 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Jim, here are some results using two picture modes and the warm 1, 2 color temperatures. No WB, grayscale or color adjustments were made; these are out of the box measurements. In Movie mode (warm 2), the white point is on target and the blue luminance looks much better than the Movie mode using warm 1 or the Cal Night mode. This pretty much confirms that Movie mode, warm 2 is the way to go with this Samsung panel. I can move forward now, knowing I have the correct setting. Thanks.
Picture Mode: Movie
Color Tone: Warm 2
Picture Mode: Movie
Color Tone: Warm 1
Picture Mode: Cal Night
Color Tone: Warm 2
post #5687 of 7322 Old 09-01-2014, 06:50 AM
Liked: 626
If you are on a f8500, set gamma to +1 to approximate 2.2 gamma.
JimP is offline
post #5688 of 7322 Old 09-01-2014, 07:22 AM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
I have the Samsung OLED, but I think gamma is similar. I notice from 40 - 90 I must raise gamma, so makes sense to just raise the whole curve by +1.
post #5689 of 7322 Old 09-01-2014, 05:42 PM
simonk83's Avatar
Quoted: 28 Post(s)
Would you happen to know if the same applies for an F9000?
simonk83 is offline
post #5690 of 7322 Old 09-01-2014, 05:51 PM
Liked: 626
Can't say as I don't have first hand experience with the f9000. Sorry
JimP is offline
post #5691 of 7322 Old 09-01-2014, 05:58 PM
Liked: 626
Raising gamma should raise how fast it comes out of black.
Are you using an apl pattern for grayscale? Seems that I read that these oled have abl similar to plasma. If that's correct, then your gamma results will be affected by the type of grayscale pattern you use.
JimP is offline
post #5692 of 7322 Old 09-01-2014, 05:59 PM
simonk83's Avatar
Quoted: 28 Post(s)
No probs
simonk83 is offline
post #5693 of 7322 Old 09-01-2014, 06:48 PM
simonk83's Avatar
Quoted: 28 Post(s)
Right, I should be able to start my very first calibration tomorrow evening all going well (the wife is out, she'd have no patience for this otherwise ). I just want to double check that following this guide from start to finish is a good way to go:
http://www.curtpalme.com/forum/viewtopic.php?t=35322
simonk83 is offline
post #5694 of 7322 Old 09-01-2014, 07:14 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
I'm using the grayscale in the scaler. The top end is a bit high at 2.25, but you can see here what I'm taking about. Raising the curve +1 can save me some work.
Please explain on how to use the APL patterns. I'm sure the Mini3D has 'em as well. I heard the Samsung OLED has less aggressive ABL then LG models, but I'd still like to try using APL.
post #5695 of 7322 Old 09-01-2014, 07:41 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
BTW, selecting the Movie picture mode and Warm 2 color temperature made a difference. The blue error is now lower and I avoided maxing out any colors. Yippee!!!
post #5696 of 7322 Old 09-01-2014, 07:56 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
The Guide is superb. I found it an excellent source to get me started.
post #5697 of 7322 Old 09-01-2014, 08:48 PM
simonk83's Avatar
Quoted: 28 Post(s)
Awesome.
Now, another stupid (the first of many no doubt) question The guide mentions:
TIP: Some displays will offer the ability to adjust grayscale at 10 points, instead of simply the standard RGB HighEnd and RGB LowEnd. If you have such a display, then use the 10-point system.
The Samsungs do indeed have a 10 pt White Balance setting (10% through to 100%), so presumably instead of using the 80% and 20% slides on the calibration disc, I should use all of them (10% through to 100%) and adjust each setting accordingly?
Aside from having a 10pt White Balance setting, the TV also has a separate White Balance setting. What do I do with that?
Sorry, this is probably really obvious but I want to make sure I get it right
simonk83 is offline
post #5698 of 7322 Old 09-01-2014, 09:35 PM
Pres2play's Avatar
Quoted: 525 Post(s)
Liked: 284
Awesome.
Use both, the 2-point WB first. Then the 10p. The 2p will set the white point and the 10p will fine tune all levels from 10-100 IRE.
You want to bring red, green and blue lines together, as shown on this chart.
post #5699 of 7322 Old 09-01-2014, 09:46 PM
simonk83's Avatar
Quoted: 28 Post(s)
Ok, so here are some example settings from the 2point menu:
White balance submenu:
R-Offset: 0
G-Offset: -1
B-Offset: -3
R-Gain: -2
G-Gain: -1
B-Gain: +1
The guide mentions to tune the HighEnd using the 80% slide, and the LowEnd using the 20% slide. In this instance, is Gain considered HighEnd and Offset considered LowEnd?
simonk83 is offline
post #5700 of 7322 Old 09-02-2014, 12:28 AM
Gordon Fraser's Avatar
Quoted: 144 Post(s)
Liked: 164
R-Offset: 0
G-Offset: -1
B-Offset: -3
R-Gain: -2
G-Gain: -1
B-Gain: +1
yes that is correct
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
Reply Display Calibration
