The Official ChromaPure thread - Page 191 - AVS Forum
 21Likes
post #5701 of 5705 Unread Today, 12:28 AM
Gordon Fraser's Avatar
Liked: 26
Originally Posted by simonk83 View Post
Ok, so here are some example settings from the 2point menu:
White balance submenu:
R-Offset: 0
G-Offset: -1
B-Offset: -3
R-Gain: -2
G-Gain: -1
B-Gain: +1
The guide mentions to tune the HighEnd using the 80% slide, and the LowEnd using the 20% slide. In this instance, is Gain considered HighEnd and Offset considered LowEnd?
yes that is correct
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is online now
post #5702 of 5705 Unread Today, 12:59 AM
Pres2play's Avatar
Quoted: 45 Post(s)
Liked: 54
That's right, 80% high-end, 20% low. Adjust the two levels in the white balance module, and go back and forth a few times to check that the RGB values haven't strayed, because the two levels are interactive.
Edit: Oops, Mr. Fraser answered you.
Pres2play is online now
post #5703 of 5705 Unread Today, 01:59 AM
magicj1's Avatar
Quoted: 12 Post(s)
Originally Posted by Gordon Fraser View Post
yes that is correct
Is it correct to use both - & + adjustments on the Gain?
magicj1 is online now
post #5704 of 5705 Unread Today, 02:25 AM
simonk83's Avatar
Awesome, thanks to you both
simonk83 is offline
post #5705 of 5705 Unread Today, 02:42 AM
Liked: 26
yes i dont see that as being an issue...however, i tend to try to avoid adjusting G. As R G and B are relative to each other you should not actually need to adjust G. The G component is large so making adjustments to it on some displays can affect your contrast and brightness settings. If your adjustments get you where you need to be with no "consequences" elsewhere then go for it....
magicj1 likes this.
Convergent-AV
Reply Display Calibration
User Tag List
