The Official ChromaPure thread - Page 194 - AVS Forum
 28Likes
post #5791 of 5793 Old 10-27-2014, 12:04 PM
ScottJ's Avatar
Quoted: 86 Post(s)
Liked: 66
Originally Posted by TomHuffman View Post
We have used 12 pt grayscale for several releases now. This is so users can go back and manually adjust the 5% point if this is needed. This isn't the source of your problem. My guess is that its just a bad installation.
I've had this kind of thing happen to me with CP, and a reinstall fixed the problem.
Tom, do you understand the root cause of this? Well-written software does not spontaneously (and subtly!) go "bad" and require reinstallation.
ScottJ is offline
post #5792 of 5793 Old 10-27-2014, 01:18 PM
TomHuffman's Avatar
Quoted: 71 Post(s)
Liked: 241
It has something to do with .Net. This only occurs for some people when new versions are released. Repairing .Net and reinstalling fixes the problem. I can't reproduce the problem here, so I can't be any more specific. Let me recommend some free software that might help with this.
https://www.piriform.com/CCLEANER
-TH
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #5793 of 5793 Old 10-27-2014, 03:27 PM
Chris5's Avatar
Thanks Tom for confirming 12 point is correct. I was using com1 which may not of helped. I will do as you suggest. Thanks again. Chris
Chris5 is offline
Reply Display Calibration
User Tag List
