The Official ChromaPure thread - Page 196 - AVS Forum
 44Likes
post #5851 of 5876 Old 12-11-2014, 05:47 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
Originally Posted by Chad B View Post
Hopefully Tom can chime in here if I need correcting, but it's pretty much the nature of the JVCs to have a drooping gamma at the high end.
If the gamma takes a nose dive at the top end--and he described it as falling completely off the chart--then that is almost certainly a symptom of a a too-high-contrast setting.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #5852 of 5876 Old 12-15-2014, 04:53 PM
Scott_R_K's Avatar
Well , it's been a while since anyone's bellied up to the Bar and asked...what's the latest word on a Version 3 of Chromapure ?
Is there a need ?
Scott.......................
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
post #5853 of 5876 Old 12-15-2014, 05:56 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
Is there a need ?
I am shooting for the first quarter of next year. It will have a lot of really cool new features--the biggest upgrade to CP since release--but whether there is a "need" will be up to users to decide.
Tom Huffman
Springfield, MO
post #5854 of 5876 Old 12-15-2014, 06:24 PM
Scott_R_K's Avatar
Thanks Tom , I look forward to supporting Chromapure in the New Year !
Merry Christmas ,
Scott.........................
dsinger likes this.
post #5855 of 5876 Old 12-16-2014, 09:32 AM
hollisavrct's Avatar
Tom will this also take care of the problem I was having with my DVG-5000 where I could not use the APL patterns?
hollis
hollisavrct is offline
post #5856 of 5876 Old 12-16-2014, 11:34 AM
mintakaX's Avatar
I haven't used CP in a while, but am trying to do an auto cal with my DVDO Iscan Duo. This is the first calibration I have attempted using this laptop (latest CP on a MacBook Pro Retina using bootcamp, Windows 7). I believe I have the I have the DVDO setup properly with Stop Bits=1, Baud=9600,but I can not get a test pattern to display. The USB->Serial converter does show up in the Windows devices . I have deleted and added the DVDO in the Signal Genrators and restarted CP several times to no avail. I'm not sure how to trouble shoot the connection or where to go next ?
Dan
EDIT: Nevermind-- I got it, the DVDO was set for a different Baudrate
mintakaX is offline
post #5857 of 5876 Old 12-16-2014, 03:20 PM
pdxfj's Avatar
My apologies for not getting back to everyone sooner. Was on a business trip in Europe and it took my brain a couple of days to solidify back to normal after returning home.
As Tom said contrast was too high, which I sure was causing a fair amount of issues. I took readings of several gamma settings and found one that was flat and close to 2.0, with the exception of falling nearly off the chart at the top end. I then reduced the contrast setting to -10 and this brought the top end more in line with everything else. Adjusted WB @ 20 and 80%. 100% was .7-.8 de off 80, so I left it alone.
Set to 70% of REC.709, 2.22 gamma, 125pt color for auto calibration off the screen.
Got a good calibration out of it and had to manually touch-up 10% grey (red too high). Was getting some funky readings off the meter and later realized I forgot to turn off the Darbee in my 2041 after all was said and done. I had spaced Tom’s earlier post of un-install Chromapure, fix .net and re-install Chromapure. My brain is still not back to 100%..... ummmm…. I’m not sure it’s ever 100%....
I stopped using the DI a while ago since it seems to have become a little buggy and do run “Grad Priority” which works great at pulling out shadow details without having to raise Brightness.
Things look a lot better now and I will see how stable it stays. Perhaps some evening when I’m bored, I’ll zero everything out and try again. Hopefully this time remember to turn off the Darbee and use a fresh install of CP.
Thanks everyone! This “hobby” is a never ending and sometimes frustrating learning experience. The reward for me is when friends and family come over for a movie and are blown away by the experience.
Looking forward to seeing what CP 3.0 has in store!
pdxfj is offline
post #5858 of 5876 Old 12-16-2014, 07:38 PM
mintakaX's Avatar
I just went through re-learning how to use CP's auto cal (with DVDO Duo) and doing it on a bootcamp retina MacBookPro was pure torture. I will not spend any more money on software that is not written for a Mac, but I will be one of the first in line to upgrade to a Mac version of CP. No disrespect intended, truly, but having to do two builds (PC and Mac) doesn't seem like a valid enough reason to eliminate the ever growing Mac faction.
mintakaX is offline
post #5859 of 5876 Old 12-17-2014, 05:13 AM
Plutotype's Avatar
Quoted: 16 Post(s)
Hi, Tom.
I see you posting here, but I would appreciate you to fix all the issues I have reported to you.
1. Win 8.1x64, Excel 2013. Creation of the ColorChecker report does not work. You have confirmed it per email, but this was couple of months ago. I cant generate reports for my customers.
2. Since updating to last version of I experience a communication freeze with Accupel DWG-5000 everytime I select a pattern ( for example checkerboard or black/white contrast patterns ) using the menu in Chromapure. The Accupel „stucks“ on the pattern and when I move for example back to the white balance module, it wont trigger the change of the pattern set. It basically stops there and I have to restart Chromapure/Session. This freeze happens also when I use the remote. Reported per email to you 2 weeks ago, reminded 4 days ago, no response.
You mention major upgrade in Q1, but sorry, that is way too late. The way Chromapure works today and measures for example gamut points ( ACMS ), how many small bugs were and are still there, how Chromapure generates reports, how all reports look and how the software logic works makes me seriously start considering Calman. After almost 2 years of usage Im disappointed.
Peter
Plutotype is offline
post #5860 of 5876 Old 12-17-2014, 05:51 AM
Originally Posted by Plutotype View Post
Hi, Tom.
Peter
I am also having the same problems with the DVG-5000 with windows 8.1 64. We paid good money for the DVG-5000 and it would be nice to be able to use it as intended. I love the software and the DVG-5000 but you meed to make them work correctly.
hollis
post #5861 of 5876 Old 12-17-2014, 06:20 AM
Quoted: 202 Post(s)
Liked: 204
Were you having this problem with windows 7?
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, VideoForge HDMI II, i1Display3pro, i1pro2, eecolor colorbox.
JimP is online now
post #5862 of 5876 Old 12-17-2014, 06:31 AM
I don't know because I was running 8.1 when I updated chromapure.
hollis
post #5863 of 5876 Old 12-17-2014, 06:37 AM
Plutotype's Avatar
Quoted: 16 Post(s)
@Jim
My previous computer had Win7 and Excel 2010. Color Checker worked there. But this is irrelevant, I need Win8 x64 and Excel 2013. Did Tom wrote that his SW is not comaptible with Win8 or Excel2013? No. They should test their software. No laptop is being sold with Win7 for the past year and Excel 2010 cant be purchased either.
post #5864 of 5876 Old 12-17-2014, 07:19 AM
bgoering's Avatar
Quoted: 48 Post(s)
That is interesting as I just ordered a Windows 7 laptop ( http://www.tigerdirect.com/applicati...986&CatId=2814 ) for one of my users. Office 2010, that includes Excel, is available from a number of places. For example: http://www.softwareking.com/home-stu...w&gclsrc=aw.ds
We are still on a Windows 7 / Office 2010 environment for desktops/laptops simply because we have some line-of-business applications that we are still testing on Windows 8.1. When there are issues it is best to work politely with your vendor to resolve any issues.
It may be something simple - like a .NET version downgrade - to get you up and running again. Or it may be something else. From what I have seen on this forum support from Tom on any number of issues has been exemplary.
Good Luck
maximus74 likes this.
JVC RS57, Denon 4520-CI, Lumagen 2041, SI BD 144" 2.35 1.4 Gain Screen
Triad Silver inRoom LCR, Triad 600 DSP Platinum Sub
Triad Bronze OnWall Surround. Bronze InCeiling LCR Back Surround
OPPO-103 + Roku Stick, Dune Base 3D, Dune 303D
DirecTV HR21, Apple TV, ~30 TB Promise iSCSI SAN Storage
Upstairs: Denon X3000, LGPN6500 TV, Polk 5.1 Speakers + Sub
bgoering is online now
post #5865 of 5876 Old 12-17-2014, 08:46 AM
Good Luck
Don't get me wrong I think Tom has done great with the software. I know that he will work these problems out once we tell him about them. I will stick with the software.
hollis
post #5866 of 5876 Unread Yesterday, 03:56 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
This is a security issue with Windows 8. I will provide information in a subsequent post how to transfer the ColorChecker Data to the Excel report under Windows 8. We are replacing this report completely in the next release so it doesn't make a lot of sense for us to spend much time fixing the current report for Windows 8, especially since there is a work around. Trust me, a permanent fix is coming soon.
This is a known bug that was just fixed with this release. See my next posts.
You need to be more specific. If you have specific reports of bugs (such as above) or wishes for feature additions or changes, we need to hear them. Please provide a specific list.
Tom Huffman
Springfield, MO
post #5867 of 5876 Unread Yesterday, 03:57 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
Just fixed. It has nothing to do with Windows 8.
Tom Huffman
Springfield, MO
post #5868 of 5876 Unread Yesterday, 04:00 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
ChromaPure 2.5.5 Released
ChromaPure 2.5.5 has been released. This upgrade is free for licensed users. The Release Notes and download link are available on the ChromaPure News page.
This release focuses primarily upon bug fixes and enhancements to previously-released features. See the Release Notes for details.
Tom Huffman
Springfield, MO
post #5869 of 5876 Unread Yesterday, 04:01 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
ChromaPure 3.0 Announced
ANNOUNCEMENT: ChromaPure 2.5.5 will be the last 2.x release. ChromaPure 3.0 will be released in the first quarter of 2015. It will provide the most substantial upgrade in ChromaPure's history. Starting today (12-18-2014), anyone who purchases a new ChromaPure license will be entitled to a free upgrade to v. 3.0 upon release. For existing customers, a ChromaPure 3.0 upgrade will be priced at $79.
Tom Huffman
Springfield, MO
post #5870 of 5876 Unread Yesterday, 06:00 PM
Scott_R_K's Avatar
So maybe I'm having a Senior moment but , if I purchase ChromaPure V2.5.5 today I'm eligible to upgrade to V3.0 for free when it is released ?
Sounds too good to be true........... but again , this is Chromapure and we're used to such respect . Cheers .
Scott........
post #5871 of 5876 Unread Yesterday, 06:04 PM
Tom did you fix the problem I was having with the DVG-5000 where I could not use the APL patterns in the generator setup?
hollis
post #5872 of 5876 Unread Yesterday, 08:14 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
Scott........
You got it.
Tom Huffman
Springfield, MO
post #5873 of 5876 Unread Yesterday, 08:22 PM
TomHuffman's Avatar
Quoted: 87 Post(s)
Liked: 256
Well, I have some good news and some bad news. The bad news is that, as it turns out, no. The good news is that the REASON it is not working is not due to a mysterious bug, but to a design choice we can easily reverse.
Some history. A few months ago we introduced a new fast command that greatly sped up the display of user colors. In fact, it was so fast that we decided to use this new command for ALL AccuPel color/grayscale requests. However, what I failed to consider at the time was that the APL patterns are only available for grayscale test patterns, not color. That includes user colors. Soooooo, when we started calling grayscale as just another user color (38,38,38 instead of GS10), this disabled the APL surrounds.
As I said, this is easy to reverse. We will put grayscale back to regular grayscale and that will make the APL windows work again. We should have this ready tomorrow.
Sorry for the oversight.
Tom Huffman
Springfield, MO
post #5874 of 5876 Unread Today, 07:19 AM
Thank for the info Tom sounds great.
Will this fix be included in the 2.5.5 update later today?
hollis
post #5875 of 5876 Unread Today, 09:29 AM
3ll3d00d's Avatar
Quoted: 327 Post(s)
Liked: 92
what will the key features in 3.x be?
3ll3d00d is online now
post #5876 of 5876 Unread Today, 09:36 AM
leemathre's Avatar
Does that $79 price apply to all license levels?
Lee Mathre
Las Vegas, NV
leemathre is online now
Reply Display Calibration
