The Official ChromaPure thread - Page 197 - AVS Forum
 46Likes
post #5881 of 5910 Unread 12-20-2014, 12:14 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Originally Posted by SteveWK View Post
Thanks for the 2.5.5 update.
Is it possible to set the APL % and window size % while using APLs during autocal with a Lumagen? If not, what is the default spec on the APL in autocal.
You can set the values that are available in the Lumagen setup window.
Fields
Windows (10%)
Medium Windows (5%)
Small Windows (2%)
APL Windows (Medium window, 25% APL)
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #5882 of 5910 Unread 12-20-2014, 12:21 AM
SteveWK's Avatar
Fields
Windows (10%)
Medium Windows (5%)
Small Windows (2%)
Ok, thanks. I was just wondering if there was a way I could customize the APL % and window size while using autocal.
SteveWK is offline
post #5883 of 5910 Unread 12-20-2014, 12:48 AM
maximus74's Avatar
Quoted: 50 Post(s)
Hello,Tom
What it means "reset the current settings" from auto-cal?which settings will reset?
maximus74 is offline
post #5884 of 5910 Unread 12-20-2014, 04:41 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Originally Posted by maximus74 View Post
Hello,Tom
I don't know what you are referring to.
Tom Huffman
Springfield, MO
post #5885 of 5910 Unread 12-20-2014, 04:45 AM
Chris5's Avatar
presumably the answer is the dvdo or lumagen device used for the calibration.
Chris5 is offline
post #5886 of 5910 Unread 12-20-2014, 04:51 AM
maximus74's Avatar
Quoted: 50 Post(s)
When i configure my chromapure with auto-cal on the last page where i have three box to check one of them(color-matrix,reset the Lumagen to default, and reset the current settings) if i remember correctly.
Sorry i am not at my home to say for sure.
post #5887 of 5910 Unread 12-20-2014, 04:52 AM
maximus74's Avatar
Quoted: 50 Post(s)
Orr....the previous settings in ChromaPure?
post #5888 of 5910 Unread 12-20-2014, 05:27 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
ColorChecker Reports
I have posted complete instructions for fixing the ColorChecker Excel reports on our Support page.
The upshot is that for XP and Win7 users, all that was required was an update to the Excel files, which are provided on our Support page.
For Win8 users it is also necessary to make some changes to avoid Win8 throwing a security violation. In fact, you can't even update the Excel reports until you do this because by default Windows 8 prevents the user from making changes to the necessary folder.
1. Right-click the ChromaPure icon on your desktop, and select Properties.
2. Click the Security tab.
3. Next to "To change Permissions, click Edit" click the Edit button.
4. Select your Windows name.
5. In the Allow column, select "Full Control".
6. Click Apply.
Now you can update the Excel files.
Tom Huffman
Springfield, MO
post #5889 of 5910 Unread 12-20-2014, 05:31 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
The first setting resets the color matrix to default, but leaves gamma/grayscale alone. You must adjust them manually.
The second setting resets both the color matrix and gamma/grayscale to default.
The third setting resets the Lumagen (and all settings) to the factory default.
I recommend the third reset option.
Tom Huffman
Springfield, MO
post #5890 of 5910 Unread 12-20-2014, 05:37 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Originally Posted by Plutotype View Post
@Jim
My previous computer had Win7 and Excel 2010. Color Checker worked there. But this is irrelevant, I need Win8 x64 and Excel 2013. Did Tom wrote that his SW is not comaptible with Win8 or Excel2013? No. They should test their software. No laptop is being sold with Win7 for the past year and Excel 2010 cant be purchased either.
The software is compatible with Windows 8. It is just that it introduced a lot of extra security features that makes certain tasks more difficult. I haven't tested the reports on Excel 2013, but it uses the same file format as 2007/2010, so there shouldn't be any problem.
Tom Huffman
Springfield, MO
post #5891 of 5910 Unread 12-20-2014, 06:07 AM
maximus74's Avatar
Quoted: 50 Post(s)
post #5892 of 5910 Unread 12-20-2014, 07:56 PM
Pres2play's Avatar
Quoted: 103 Post(s)
Liked: 116
Tom, I run CP on my laptop. How important is it for the laptop to be calibrated?
OLED Display: Samsung S9C
Pres2play is offline
post #5893 of 5910 Unread 12-20-2014, 08:25 PM
rmongiovi's Avatar
Quoted: 13 Post(s)
Liked: 27
Can you elaborate on why you might recommend that option? Suppose I want to have one Lumagen memory be a 2.2 gamma and another be BT.1886. Surely I want to use the advanced autocal for both. Resetting the entire box to factory default is pretty incompatible with that.... What are the other autocal requirements that need resetting?
rmongiovi is offline
post #5894 of 5910 Unread 12-20-2014, 09:47 PM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
I understand, and this is why we provide the first two options.
I have just found that clearing everything out and starting fresh provides the most consistent results. I can't provide any scientific explanation for this. It is just my experience. In particular, I would not attempt to do more than one auto-cal session without resetting to factory default. If you need to do more than one session back-to-back without resetting to factory defaults, for whatever reason, then I would close ChromaPure and restart between sessions.
Tom Huffman
Springfield, MO
post #5895 of 5910 Unread Yesterday, 02:12 AM
Chris5's Avatar
Hi Tom, I have a different query which you may not be able to answer, but anyway;
Using Lumagen XS up scaling to 1080p output
Set 1080i source. On CP I set up for rec709. Adjust White Balance on TV, do Autocal.
Come out of CP, go back in
Set 576i source. Setup up for EBU.
Check White Balance and it has changed.
Would you expect this change? Presumably I can't adjust the tv again as this would mess up my previous rec709 calibration. any thoughts? Thanks. Chris
Chris5 is offline
post #5896 of 5910 Unread Yesterday, 04:03 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Not based on the information here. In particular, I'd like to know what, exactly "changed" means. Changed a little, a lot, throughout the whole grayscale, only part? A pair of calibration reports would help.
Tom Huffman
Springfield, MO
post #5897 of 5910 Unread Yesterday, 04:05 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Not at all for the calibration of an external display. You might want to calibrate the white balance of the laptop, just because it looks better. You can use CP's Built-in test patterns and the video card's color temp adjustments for this.
Tom Huffman
Springfield, MO
post #5898 of 5910 Unread Yesterday, 07:49 AM
Chris5's Avatar
Hi tom, did not think to check greyscale, just the White balance. The White balance is not different by much, say red by a couple of clicks on the TV control, it's nothing major, just a bit surprised that's all. Thanks anyway. Chris
Chris5 is offline
post #5899 of 5910 Unread Yesterday, 03:14 PM
Pres2play's Avatar
Quoted: 103 Post(s)
Liked: 116
Thumbs up
post #5900 of 5910 Unread Yesterday, 03:37 PM
rmongiovi's Avatar
Quoted: 13 Post(s)
Liked: 27
I have a Lumagen mini rather than an XS, but I see the same thing with greyscale and advanced autocal. This is from an earlier version of Chromapure rather than the new faster autocal so your mileage may vary, but I do the greyscale on the Lumagen by hand and then run autocal using the setting that leaves greyscale alone. Post autocal my greyscale is noticeably worse than before.
I traded email with Jim Peterson at Lumagen and his comment was that the 5x5x5 matrix has points on the grey vector and so can affect greyscale. His recommendation was to go back and touch up greyscale if necessary after the autocal. That's what I do currently but it seems to me that if the 5x5x5 autocal affects greyscale then greyscale affects the autocal so I'm not really sure where I end up deltaE-wise across the gamut.
Of course, crosstalk like that between adjustments is the name of the game for calibration, so I tried "adjust grayscale, run advanced autocal, adjust grayscale, run advanced autocal again" but it was a lot of work and it wasn't apparent that it was converging so I reset to factory and contented myself with grayscale, autocal, grayscale.
Roy
post #5901 of 5910 Unread Yesterday, 06:50 PM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
All of the auto-cal modes: 5^3, 9^3, and 17^3 have adjustment points that overlap the grayscale, 4 points, 8 points, and 16 points. If you haven't used the faster method that we implemented a few releases ago, then you really need to upgrade. It uses a completely different method. It is not only faster, but it provides a much more precise method of adjustment because it is mathematical, rather than reiterative (that's why it is faster). What I see is that if I did grayscale first, then when the matrix adjustments get to the grayscale points it makes virtually no change because it is pre-adjusted.
Some post-matrix calibration grayscale adjustment is almost inevitable at the low end. The dE method we use--unlike other vendors--provides the maximum sensitivity at low light levels so getting a good white balance at 20% and below may require a little TLC. If you limit the post-calibration adjustments to that then it won't have any meaningful impact on the color calibration.
BTW, I want to encourage everyone to offer quantitative data in these posts as often as possible--a calibration report is easy to post. For example, it is hard to know what "noticeably worse" means. Is it measurably worse (by how much?) or visibly worse? It is always best to have hard numbers.
Tom Huffman
Springfield, MO
post #5902 of 5910 Unread Yesterday, 07:32 PM
SteveWK's Avatar
Tom,
It appears, to me anyway, that even after selecting Reset Color Calibration Settings Only and not selecting Grayscale/Gamma, 2.5.5 still calibrates grayscale, see data below.
Display Gamut
New Settings: 916, 902,911
Measured x: 0.3121, y: 0.3296, Y: 119.9237
213, 213, 213
New Settings: 812, 809,811
Measured x: 0.3148, y: 0.3298, Y: 93.0835
191, 191, 191
New Settings: 101, 96,107
Measured x: 0.3306, y: 0.3399, Y: 0.9320
38, 38, 38
New Settings: 912, 903,910
Measured x: 0.3120, y: 0.3295, Y: 119.7621
213, 213, 213
New Settings: 820, 810,810
Measured x: 0.3128, y: 0.3302, Y: 92.0709
191, 191, 191
New Settings: 107, 96,103
Measured x: 0.3025, y: 0.3172, Y: 0.9023
38, 38, 38
New Settings: 908, 904,909
Measured x: 0.3131, y: 0.3269, Y: 119.9638
213, 213, 213
New Settings: 817, 810,807
Measured x: 0.3115, y: 0.3276, Y: 92.5002
191, 191, 191
New Settings: 105, 96,107
Measured x: 0.3158, y: 0.3370, Y: 0.9120
38, 38, 38
New Settings: 914, 902,914
Measured x: 0.3122, y: 0.3296, Y: 120.0586
213, 213, 213
New Settings: 816, 810,811
Measured x: 0.3126, y: 0.3298, Y: 91.7917
191, 191, 191
New Settings: 104, 96,104
Measured x: 0.3013, y: 0.3172, Y: 0.8991
38, 38, 38
New Settings: 911, 903,913
Measured x: 0.3139, y: 0.3294, Y: 119.6982
213, 213, 213
New Settings: 812, 809,808
Measured x: 0.3145, y: 0.3295, Y: 92.6425
191, 191, 191
New Settings: 101, 96,108
Measured x: 0.3281, y: 0.3395, Y: 0.9223
38, 38, 38
New Settings: 914, 901,910
Measured x: 0.3121, y: 0.3295, Y: 119.8338
213, 213, 213
New Settings: 818, 809,806
Measured x: 0.3115, y: 0.3274, Y: 92.4722
191, 191, 191
New Settings: 106, 96,104
Measured x: 0.3028, y: 0.3174, Y: 0.8860
38, 38, 38
New Settings: 910, 902,909
Measured x: 0.3121, y: 0.3296, Y: 120.0055
213, 213, 213
New Settings: 817, 809,811
Measured x: 0.3128, y: 0.3298, Y: 92.4239
191, 191, 191
New Settings: 518, 505,508
Measured x: 0.3111, y: 0.3267, Y: 32.2883
126, 126, 126
New Settings: 416, 406,416
Measured x: 0.3134, y: 0.3314, Y: 19.8765
104, 104, 104
New Settings: 315, 306,310
Measured x: 0.3146, y: 0.3295, Y: 10.4243
82, 82, 82
New Settings: 103, 95,107
Measured x: 0.3131, y: 0.3369, Y: 0.9105
38, 38, 38
New Settings: 907, 903,908
Measured x: 0.3140, y: 0.3295, Y: 119.9126
213, 213, 213
New Settings: 816, 810,809
Measured x: 0.3128, y: 0.3299, Y: 92.4054
191, 191, 191
New Settings: 714, 703,705
Measured x: 0.3133, y: 0.3297, Y: 68.7203
169, 169, 169
New Settings: 623, 614,614
Measured x: 0.3128, y: 0.3278, Y: 48.2371
147, 147, 147
New Settings: 517, 504,509
Measured x: 0.3135, y: 0.3321, Y: 32.2642
126, 126, 126
New Settings: 416, 407,414
Measured x: 0.3141, y: 0.3310, Y: 19.6559
104, 104, 104
New Settings: 316, 305,309
Measured x: 0.3152, y: 0.3312, Y: 10.5056
82, 82, 82
New Settings: 210, 198,202
Measured x: 0.3147, y: 0.3328, Y: 4.2701
60, 60, 60
New Settings: 101, 96,105
Measured x: 0.3138, y: 0.3372, Y: 0.9158
38, 38, 38
New Settings: 911, 902,905
Measured x: 0.3123, y: 0.3301, Y: 119.8849
213, 213, 213
New Settings: 815, 811,807
Measured x: 0.3126, y: 0.3297, Y: 91.6366
191, 191, 191
New Settings: 715, 703,704
Measured x: 0.3117, y: 0.3308, Y: 68.1300
169, 169, 169
New Settings: 623, 612,614
Measured x: 0.3120, y: 0.3316, Y: 47.3755
147, 147, 147
New Settings: 515, 504,505
Measured x: 0.3098, y: 0.3302, Y: 31.9220
126, 126, 126
New Settings: 415, 406,411
Measured x: 0.3112, y: 0.3316, Y: 19.4323
104, 104, 104
New Settings: 318, 305,307
Measured x: 0.3093, y: 0.3308, Y: 10.2640
82, 82, 82
New Settings: 210, 198,200
Measured x: 0.3081, y: 0.3309, Y: 4.2846
60, 60, 60
New Settings: 100, 97,103
Measured x: 0.3139, y: 0.3373, Y: 0.9178
38, 38, 38
New Settings: 907, 903,903
Measured x: 0.3120, y: 0.3292, Y: 118.8368
213, 213, 213
New Settings: 811, 809,803
Measured x: 0.3107, y: 0.3265, Y: 89.4794
191, 191, 191
New Settings: 708, 703,700
Measured x: 0.3102, y: 0.3277, Y: 67.4781
169, 169, 169
New Settings: 614, 609,607
Measured x: 0.3098, y: 0.3278, Y: 45.9451
147, 147, 147
New Settings: 508, 503,503
Measured x: 0.3092, y: 0.3289, Y: 31.4427
126, 126, 126
New Settings: 409, 405,407
Measured x: 0.3109, y: 0.3313, Y: 18.7799
104, 104, 104
New Settings: 311, 304,305
Measured x: 0.3086, y: 0.3304, Y: 9.8387
82, 82, 82
New Settings: 206, 200,201
Measured x: 0.3070, y: 0.3304, Y: 4.1946
60, 60, 60
New Settings: 99, 98,101
Measured x: 0.3152, y: 0.3367, Y: 0.9504
38, 38, 38
Reference White -> x: 0.3135, y: 0.3296, Y: 151.5601
Blue x: 0.1484, y: 0.0581, Y: 10.9029
Green x: 0.2992, y: 0.6061, Y: 108.2792
Red x: 0.6555, y: 0.3303, Y: 30.7860
Starting Grayscale/Gamma Calibration
SteveWK is offline
post #5903 of 5910 Unread Yesterday, 09:58 PM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
I have been getting a lot of this lately, and I don't know why. You have a bad installation. Here are the instructions for a clean installation.
1. Uninstall CP.
2. Delete this file
C:\ProgramData\Display Calibrations LLC\ChromaPure\2\ChromaPure.config
(If you don't see the ProgramData folder, that's because it is hidden. To expose it, Control Panel, Folder Options, View, check "Show hidden files, folders, and drives". Then click OK. Now it will be visible.)
3. Repair Microsoft .Net Framework (Control Panel, Programs and Features, double-click Microsoft .Net Framework, and select the Repair option).
In Windows 8 you need to download the repair tool
http://www.chromapure.com/distribute...RepairTool.exe
A reboot may be required.
4. Reinstall CP.
5. If you are using a signal generator, you will have to set it up again in CP from scratch (use a Com port of 4 or higher). Click Options, Signal Generator.
I want to make sure that readers understand that the issue you encountered has nothing to do with the reset options. What you encountered is a grayscale calibration when none was requested.
Here's what you should see with a Lumagen matrix calibration only (no grayscale/gamma) with the reset grayscale/gamma and color settings checked. This reads in reverse with the last event being my cancelling the session. BTW, thanks for posting data.
Auto-calibration cancelled
New Settings: 195, 64,200
Measured: 0.3298, 0.1630, 3.5560
71, 16, 71
Target Gamma: 2.22
New Settings: 196, 64,87
Measured: 0.6360, 0.3426, 2.7250
71, 16, 16
Target Gamma: 2.22
New Settings: 64, 940,940
Measured: 0.2335, 0.3308, 90.5300
16, 235, 235
Target Gamma: 2.22
New Settings: 64, 940,676
Measured: 0.2476, 0.3813, 88.7200
16, 235, 180
Target Gamma: 2.22
New Settings: 64, 940,439
Measured: 0.2713, 0.4670, 86.7100
16, 235, 126
Target Gamma: 2.22
New Settings: 64, 940,221
Measured: 0.2942, 0.5501, 85.2400
16, 235, 71
Target Gamma: 2.22
New Settings: 64, 940,215
Measured: 0.3067, 0.6064, 86.0700
16, 235, 16
Target Gamma: 2.22
New Settings: 64, 663,940
Measured: 0.2207, 0.2832, 66.4700
16, 180, 235
Target Gamma: 2.22
New Settings: 64, 656,666
Measured: 0.2346, 0.3343, 65.2100
16, 180, 180
Target Gamma: 2.22
New Settings: 64, 650,433
Measured: 0.2615, 0.4309, 62.9100
16, 180, 126
Target Gamma: 2.22
New Settings: 64, 649,206
Measured: 0.2889, 0.5324, 61.0400
16, 180, 71
Target Gamma: 2.22
New Settings: 64, 641,177
Measured: 0.3071, 0.6103, 61.1100
16, 180, 16
Target Gamma: 2.22
New Settings: 64, 428,940
Measured: 0.1972, 0.1967, 36.7000
16, 126, 235
Target Gamma: 2.22
New Settings: 64, 424,660
Measured: 0.2089, 0.2386, 34.6400
16, 126, 180
Target Gamma: 2.22
New Settings: 64, 412,420
Measured: 0.2361, 0.3362, 32.8000
16, 126, 126
Target Gamma: 2.22
New Settings: 64, 410,194
Measured: 0.2745, 0.4757, 30.9200
16, 126, 71
Target Gamma: 2.22
New Settings: 64, 401,139
Measured: 0.3069, 0.6154, 30.6600
16, 126, 16
Target Gamma: 2.22
New Settings: 64, 198,940
Measured: 0.1744, 0.1121, 17.4800
16, 71, 235
Target Gamma: 2.22
New Settings: 64, 191,659
Measured: 0.1816, 0.1365, 15.4600
16, 71, 180
Target Gamma: 2.22
New Settings: 64, 192,420
Measured: 0.1970, 0.1935, 12.1900
16, 71, 126
Target Gamma: 2.22
New Settings: 64, 186,193
Measured: 0.2384, 0.3400, 10.4100
16, 71, 71
Target Gamma: 2.22
New Settings: 64, 187,102
Measured: 0.3086, 0.6204, 9.1960
16, 71, 16
Target Gamma: 2.22
New Settings: 64, 64,940
Measured: 0.1601, 0.0707, 9.3540
16, 16, 235
Target Gamma: 2.22
New Settings: 64, 64,682
Measured: 0.1600, 0.0710, 6.5660
16, 16, 180
Target Gamma: 2.22
New Settings: 64, 64,442
Measured: 0.1598, 0.0723, 3.1940
16, 16, 126
Target Gamma: 2.22
New Settings: 64, 64,195
Measured: 0.1610, 0.0765, 1.1290
16, 16, 71
Target Gamma: 2.22
White:0.3222, 0.3350, 125.9000
Blue:0.1599, 0.0708, 9.3740
Green:0.3066, 0.6063, 86.2600
Red:0.6424, 0.3352, 25.9500
Display Gamut
Magenta: xyY=(0.324,0.156,32.670) YNorm=0.261, dE=2.37
Cyan: xyY=(0.233,0.330,90.590) YNorm=0.722, dE=3.59
Yellow: xyY=(0.424,0.506,105.500) YNorm=0.841, dE=3.73
Blue: xyY=(0.160,0.071,9.391) YNorm=0.075, dE=2.04
Green: xyY=(0.307,0.606,86.090) YNorm=0.687, dE=2.06
Red: xyY=(0.642,0.335,25.880) YNorm=0.206, dE=1.90
0% Grayscale xyY=(0.269,0.641,0.094)
Measuring 0% Grayscale
10% Grayscale xyY=(0.323,0.338,4.055)
Measuring 10% Grayscale
20% Grayscale xyY=(0.321,0.331,9.082)
Measuring 20% Grayscale
30% Grayscale xyY=(0.322,0.334,16.080)
Measuring 30% Grayscale
40% Grayscale xyY=(0.323,0.336,27.460)
Measuring 40% Grayscale
50% Grayscale xyY=(0.323,0.335,41.350)
Measuring 50% Grayscale
60% Grayscale xyY=(0.322,0.333,57.340)
Measuring 60% Grayscale
70% Grayscale xyY=(0.323,0.335,76.920)
Measuring 70% Grayscale
80% Grayscale xyY=(0.323,0.335,100.500)
Measuring 80% Grayscale
90% Grayscale xyY=(0.322,0.335,124.000)
Measuring 90% Grayscale
100% Grayscale xyY=(0.322,0.335,125.700)
Measuring 100% Grayscale
PreCalibration Measurement ...
Resetting Grayscale
Resetting Advanced Gamut to factory defaults
Starting auto-calibration 10:43 PM
Tom Huffman
Springfield, MO
post #5904 of 5910 Unread Yesterday, 11:11 PM
SteveWK's Avatar
It now works as advertised. I'll keep the reinstall procedure in my hip pocket in case I have any future problems. On the plus side my measurements at lower IREs on my F8500 are stable within a few percent. By stable I mean they don't jump around 10-15% when measured continuously. And my skin tones are no longer orange/red in color. It looks fantastic now.
New Settings: 120, 122,927
Measured: 0.1485, 0.0581, 11.0230
16, 16, 235
Target Gamma: 2.22
New Settings: 96, 83,713
Measured: 0.1487, 0.0585, 5.8196
16, 16, 180
Target Gamma: 2.22
New Settings: 86, 64,502
Measured: 0.1492, 0.0602, 2.4072
16, 16, 126
Target Gamma: 2.22
New Settings: 64, 64,276
Measured: 0.1528, 0.0666, 0.6221
16, 16, 71
Target Gamma: 2.22
White:0.3136, 0.3300, 153.4832
Blue:0.1484, 0.0580, 10.9740
Green:0.2990, 0.6069, 109.8310
Red:0.6552, 0.3303, 31.1856
Display Gamut
Magenta: xyY=(0.316,0.148,43.083) YNorm=0.279, dE=1.08
Cyan: xyY=(0.224,0.329,120.126) YNorm=0.779, dE=0.39
Yellow: xyY=(0.423,0.510,144.518) YNorm=0.937, dE=0.92
Blue: xyY=(0.148,0.058,10.985) YNorm=0.071, dE=0.44
Green: xyY=(0.299,0.607,109.959) YNorm=0.713, dE=0.47
Red: xyY=(0.655,0.330,31.212) YNorm=0.202, dE=3.04
0% Grayscale xyY=(0.318,0.296,0.048)
10% Grayscale xyY=(0.303,0.316,1.018)
20% Grayscale xyY=(0.314,0.332,4.434)
30% Grayscale xyY=(0.313,0.330,10.772)
40% Grayscale xyY=(0.315,0.330,20.004)
50% Grayscale xyY=(0.311,0.326,32.825)
60% Grayscale xyY=(0.315,0.332,49.072)
70% Grayscale xyY=(0.312,0.327,68.657)
80% Grayscale xyY=(0.311,0.327,92.926)
90% Grayscale xyY=(0.314,0.330,121.111)
100% Grayscale xyY=(0.314,0.329,153.497)
Starting auto-calibration 1:58 AM
SteveWK is offline
post #5905 of 5910 Unread Yesterday, 11:33 PM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
Let me recommend some third-party software that is really useful for keeping a Windows installation running well.
https://www.piriform.com/ccleaner/download
I use this and I never have these problems with bad installations that have gotten more common as the program has gotten bigger and more complex.
Tom Huffman
Springfield, MO
post #5906 of 5910 Unread Today, 12:18 AM
SteveWK's Avatar
Ahh yes, CCleaner. I use to use that back in my Windows days. Thanks for the suggestion.
I do have a Lumagen question. As you may have noticed in the data I posted, the display is quite bright. Is it practical to lower peak luminance using the greyscale controls within the Lumagen? I'd rather do that than have different TV settings for day/night.
SteveWK is offline
post #5907 of 5910 Unread Today, 04:40 AM
TomHuffman's Avatar
Quoted: 93 Post(s)
Liked: 258
If it were me, I'd just lower the backlight settings on the display. If it has no backlight settings, then lower the contrast a few ticks.
Tom Huffman
Springfield, MO
post #5908 of 5910 Unread Today, 05:23 AM
maximus74's Avatar
Quoted: 50 Post(s)
Hello,Tom
If i check the last box"reset lumagen to factory default" will change my previous manual settings from YCbCr 4:2:2 to RGB video level,with auto-cal.
The results are very,very good.
But when i change back to YCbCr 4:2:2,will mess up my greyscale.
It is normal this behaviour?
post #5909 of 5910 Unread Today, 07:49 AM
Geof's Avatar
Quoted: 13 Post(s)
Liked: 34
I have not yet tried 2.5.5 but please clarify:
Does any resetting you discuss affect ALL CMS memories or just the CMS in use? (Particularly option 3 as you state it resets all setting to default).
Is it possible to run a greyscale/gamma auto cal and then manually tweak results (if needed) then run a color/gamut autocal only (if needed)?
Geof
Geof is offline
post #5910 of 5910 Unread Today, 10:50 AM
nebrunner's Avatar
Quoted: 17 Post(s)
What kind of test patterns or adjustments does Chromapure use for setting black and white levels?
nebrunner is online now
Reply Display Calibration
