The Official ChromaPure thread - Page 217 - AVS | Home Theater Discussions And Reviews
 136Likes
post #6481 of 6491 Unread 05-18-2015, 07:57 PM
TomHuffman's Avatar
Quoted: 238 Post(s)
Liked: 366
Originally Posted by davehancock View Post
First, it is not necessary that a display has a 10 (or 20 point) Gamma Adjustment for BT 1889. If you only have RGB controls, Green has the largest impact on Luminance, so, for a given point, adjust G to bring the point to the proper Luminance, then tweak Red & Blue to restore balance. The ChromaPure gamma screen makes this easy.
Yes, I have used this technique many times, especially on Samsungs. BTW, this has nothing to do with BT.1886 per se. It is a valid technique for any gamma target.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #6482 of 6491 Unread 05-18-2015, 08:07 PM
oliverlim's Avatar
Quoted: 14 Post(s)
Tom,
Does your software include some "wizardry" that will enable one to calibrate a LG OLED with agressive ABL on auto mode with a lumagen? It seems like many are saying its not possible to do autocalibration on the LG OLED as it will drop light output after seeing the same patterns for a while. I am exploring my options on calibration.
oliverlim is online now
post #6483 of 6491 Unread 05-18-2015, 09:02 PM
TomHuffman's Avatar
Quoted: 238 Post(s)
Liked: 366
I have an LG OLED and I have not seen this behavior. It will start gradually dropping light output if you leave the same test pattern on the screen, but if the test pattern changes (as it does with auto-cal) this doesn't occur. I have some clear data on this.
Can you point me to a discussion of this?
Tom Huffman
Springfield, MO
post #6484 of 6491 Unread 05-18-2015, 09:18 PM
oliverlim's Avatar
Quoted: 14 Post(s)
Do you have the 9300 or the older one? Chad B seems to confirm this and another user here seem to suggest the same.
http://www.spectracal.com/forum/view...hp?f=94&t=5689
See post 263 and 264 for Chad B saying this as well.
Calibration Anomaly on Newest of the New LG OLED!
I cannot find it now but it seems like folks at a UK forum is also saying the same thing. Most ended up doing manual adjustments.
I am getting my display delivered tomorrow. It just seems a waste to not be able to do autocal on these units. Not that its the fault of the calibration software makers.
post #6485 of 6491 Unread 05-18-2015, 10:11 PM
TomHuffman's Avatar
Quoted: 238 Post(s)
Liked: 366
I have the EA9800.
I just ran a 125-point auto-cal and the starting value for 100% was 96.53 and the ending value was 95.52, which is a negligible difference. I see no problem with changing luminance in an auto-cal sequence in which the pattern color and intensity is constantly changing.
I just read Chad's post
He says he was disappointed with the results and seems to assume that the fault with with ABL. I don't think it was. The numbers I see show that the patch intensity remains essentially the same throughout the process. However, I have also verified that, after about a minute, the same patch will start to decline in luminance. This is easy to test.
1. Put up a white test pattern and note the luminance.
2. Start cycling between pri/sec colors, changing about every 5 seconds.
3. After a couple of minutes of this measure white luminance again.
Now, compare this with a before/after measurement of white luminance when the test pattern remains fixed. I find that in the first case white changes very little, if at all. In the second case it charges substantially.
I have seen cases where auto-cal didn't improve the image in any substantial way with this display, but that was only because it was quite good to begin with
Tom Huffman
Springfield, MO
post #6486 of 6491 Unread 05-18-2015, 10:41 PM
oliverlim's Avatar
Quoted: 14 Post(s)
I have the EA9800.
I think this aggressive ABL came about in the 9300 2nd gen series onwards. Chad also said somewhere else that as long as the size stays the same, the different colors and luminance changes is still taken as a static pattern and LG will start to reduce luminance of that window after mins. this was done to reduce the chance of burnin or retention as it seems the 1st gen OLED could be prone to with static display. So much that chad says he tried to use the pause button? every 30 secs to prevent the agressive ABL from kicking in and it did not work. I guess I will know in the coming days.
post #6487 of 6491 Unread 05-18-2015, 11:51 PM
Toadus's Avatar
Quoted: 40 Post(s)
Hi Tom. Being a Chromapure user, I have my set calibrated using gamma @ 2.22. I can't do any other gamma as the Chromapure's advanced colour section only expects the gamma @ 2.22. It might not seem like much, but my ColourChecker results go from an average dE of about 0.7 to dE of about 3.5 when I switch from 2.22 to 2.4. I'm anxiously waiting for the new version of Chromapure to come out!
Toadus is offline
post #6488 of 6491 Unread Yesterday, 12:12 AM
TomHuffman's Avatar
Quoted: 238 Post(s)
Liked: 366
It's coming. . . .
Tom Huffman
Springfield, MO
post #6489 of 6491 Unread Yesterday, 04:07 AM
maximus74's Avatar
Quoted: 80 Post(s)
Liked: 29
Tom,
The new ChromaPure V3 will have a redesigned post calibration report that will include full CMS saturation chart and color checker report?
I would love to know when "It's coming"
Regards
maximus74 is offline
post #6490 of 6491 Unread Yesterday, 04:46 PM
TomHuffman's Avatar
Quoted: 238 Post(s)
Liked: 366
Yes, it will.
I have been mistaken about when we will be ready for release a couple of times now, so I won't repeat the mistake. As soon as it is ready, I assume sometime this summer is the best I can do.
Tom Huffman
Springfield, MO
post #6491 of 6491 Unread Today, 07:48 AM
AVS Club Gold
Glenee's Avatar
Quoted: 63 Post(s)
Liked: 74
Yes, it will.
That a Boy. Get it right.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is online now
Reply Display Calibration
