The Official ChromaPure thread - Page 223 - AVS Forum | Home Theater Discussions And Reviews
 160Likes
post #6661 of 6672 Old 07-21-2015, 05:15 PM
TomHuffman's Avatar
Quoted: 311 Post(s)
Liked: 395
Originally Posted by mskreis View Post
100% is 19 cd/m2 and I'm unable to read 0.
Place the meter close enough to the lens to get about 500 with the diffuser in place, then measure. What are the black and white readings? Contrast should be between 20,000-50,000.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #6662 of 6672 Old 07-22-2015, 08:53 AM
mskreis's Avatar
Quoted: 16 Post(s)
Have company visiting currently so had to put down the equipment. I do recall, though, that I got higher readings as I moved the sensor farther away from the lens. I got as close as about 8 inches but no closer.
mskreis is offline
post #6663 of 6672 Old 07-25-2015, 04:09 PM
atabea's Avatar
Quoted: 65 Post(s)
Liked: 83
I am having a peculiar problem with my Display 3 Pro when trying to calibrate my Sony TV. Am sure it's something really simple but I have tried everything and still no success. When I try to initialize the Meter, I get the attached message. I have done this before and everything worked fine, so not sure why it's a problem now. What's more peculiar is when I calibrate my Projector using my Lumagen and Autocal, everything works fine, using the same port. I am trying to manually calibrate my TV so no Lumagen in the chain. Any suggestions to get things working?
atabea is offline
post #6664 of 6672 Old 07-25-2015, 05:02 PM
TomHuffman's Avatar
Quoted: 311 Post(s)
Liked: 395
This is not a Display 3 PRO issue. This is a Lumagen issue.
Close CP.
Delete the configuration file
C:\ProgramData\Display Calibrations LLC\ChromaPure\2\ChromaPure.config
Restart CP.
Setup the Lumagen from scratch using the attached instructions.
Tom Huffman
Springfield, MO
post #6665 of 6672 Old 07-25-2015, 05:31 PM
ScottJ's Avatar
Quoted: 174 Post(s)
Liked: 92
Tom, I don't understand this. "Unhandled exception" refers to a bug in a program running on the PC. Is atabea running some Lumagen software on his PC that is causing this?
ScottJ is offline
post #6666 of 6672 Old 07-25-2015, 06:41 PM
atabea's Avatar
Quoted: 65 Post(s)
Liked: 83
Thanks, Tom, I will try what you recomend. I kinda mistated what was/is going on: My Display3 initializes fine!!. It's when I try to measure anything that the "message" pops up. This only happens when the Lumagen is not in the Chain. As soon as I plug in the Lumagen in another port the message no longer appears and everything works fine.
atabea is offline
post #6667 of 6672 Old 07-25-2015, 06:45 PM
TomHuffman's Avatar
Quoted: 311 Post(s)
Liked: 395
That simply means that the application is expecting a signal generator attached to Com 3 and none is there. When using CP WITHOUT the Lumagen, be sure to uncheck "Enable Signal Generator Support" in Options, Signal Generators. Check this again when the Lumagen is connected.
Tom Huffman
Springfield, MO
post #6668 of 6672 Old 07-25-2015, 07:05 PM
atabea's Avatar
Quoted: 65 Post(s)
Liked: 83
Tom, You are a genius! Works great now---after I unchecked enable signal generator. Thank you very much!!!.
atabea is offline
post #6669 of 6672 Old Today, 08:32 AM
hollisavrct's Avatar
Quoted: 17 Post(s)
Meter Profile
If I profile my I1D3 with my I1Pro 2 and I close out the calibration and I reopen it do I have to reprofile my I1D3? I've had Chromapure crash on me before and I have to reopen it to continue. Do I have to reprofile then?
hollisavrct
hollisavrct is offline
post #6670 of 6672 Old Today, 11:21 AM
TomHuffman's Avatar
Quoted: 311 Post(s)
Liked: 395
hollisavrct
Once you finish profiling your i1D3, click Save under Tools and save a calx file. You can then subsequently load that calx file to retrieve your profile. Just click Apply in the Meter Correction module.
Tom Huffman
Springfield, MO
post #6671 of 6672 Old Today, 07:53 PM
PowerWheels's Avatar
Total noobie here, I'm looking at Chromapure standard and a meter, do I need a tripod. I've got the Samsung f8500 plasma.
PowerWheels is online now
post #6672 of 6672 Old Today, 08:55 PM
TomHuffman's Avatar
Quoted: 311 Post(s)
Liked: 395
You don't NEED one. The meter can be hung on the plasma much like you would with a desktop PC monitor. However, tripods are cheap--you can get a decent one for $20-- and it is a good idea.
Tom Huffman
Springfield, MO
Reply Display Calibration
