The Official ChromaPure thread - Page 227 - AVS Forum | Home Theater Discussions And Reviews
 169Likes
post #6781 of 6800 Old 08-23-2015, 01:32 PM
owtuv's Avatar
Originally Posted by TomHuffman View Post
The built-in test patterns are intended as a poor man's signal generator. For most enthusiast applications it is fine, but for more serious work I always recommend an external signal generator.
Tom,
Any plans for an IOS (and/or Android) pattern generator app which can be mirrored on the TV with ChromaPure selecting the correct patterns for the various tests, something similar to the app SpectraCal is providing?
owtuv is offline
post #6782 of 6800 Old 08-24-2015, 04:38 AM
Liked: 2
@ Tom, will ChromaPure 3 also have display calibration? (generate ICC profiles) Or will it be projectors and TV's only, like previous versions?
Editor TFT Central
Kid Jansen is offline
post #6783 of 6800 Old 08-24-2015, 10:14 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
In general, I am reluctant to respond to questions like the last two. I want to leave flexibility about what will or will not be in future releases. I will therefore treat these as feature requests.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #6784 of 6800 Old 08-25-2015, 04:00 PM
chunon's Avatar
Quoted: 644 Post(s)
Liked: 779
Tom,
In the meter correction screen how is the "Y" value derived ? I did a correction the other day and tried again today and am getting some bizarre reading in the 163 range from my I1D3 if I apply the correction luminance is way off almost like it is a levels mismatch, using Ryan's MCD disc as a pattern source.
65JS9500
55ST60
Dish Network Hopper/Oppo 103d/ Sony XT1 Soundbase/Harmony 650
Calman Enthusiast/I1Pro/I1D3/Lumagen 2143
chunon is offline
post #6785 of 6800 Old 08-25-2015, 04:36 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
What values were input in the reference and field and what values did you measure before and after the correction?
Tom Huffman
Springfield, MO
post #6786 of 6800 Old 08-26-2015, 04:46 AM
chunon's Avatar
Quoted: 644 Post(s)
Liked: 779
Tom what I was attempting to do was use Chad's reading off my set as the reference and then measure with my I1D3 as the field meter and apply the correction. My Y readings appear to be in-line. The screen shot Chad sent me has a Y value of 75 which is way off what my meter reads. My question is can I apply the correction and not populate the Y value ? I know this is something that was recently added to the meter correction screen.
65JS9500
55ST60
chunon is offline
post #6787 of 6800 Old 08-26-2015, 04:56 AM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
That's an impossible scenario. What if you are using different intensity test patterns? I wouldn't use Y correction in this case. Use the same values for test and reference.
Tom Huffman
Springfield, MO
post #6788 of 6800 Old 08-26-2015, 09:42 AM
owtuv's Avatar
Originally Posted by ConnecTEDDD View Post
Quote:Originally Posted by jmoakk
I plan on using chromapure to calibrate an epson 8350 soon. This will be my first time using chromapure. I was reading the manual to make sure I understood everything first. I have two question so far just from reading the manual. Which dE method should I use? From what I'm reading I believe I should use CIELUV? Also when using the color management module which color space should I choose? I will be using the CMS on my epson 8350. Any help would be greatly appreciated. Thanks
CIELUV for Grayscale
CIE94 for Color
REC. 709 for Color Space
Newbie here. Could you please explain the reasons for choosing different dE methods for Grayscale and Color? Is CIELUV more accurate for grayscale and CIE94 more accurate for color?
Ole
owtuv is offline
post #6789 of 6800 Old 08-26-2015, 10:37 AM
ConnecTEDDD's Avatar
Quoted: 303 Post(s)
Liked: 734
Ole
Hi, (not sure why you quote me, but no problem)
CIELUV is more tight dE method for Grayscale it will report to your larger dE number compared with CIE94.
ChromaPure is using the UV and counts the differences in Gamma to give you the dE number.
For example if you are targeting to calibrate your Grayscale with dE lower than 1.0.......If you measure your grayscale with CIE94, it will report to you 1.0, but if you re-measure it with
CIELUV it will report to you about 1.6-2.0, so using CIELUV for Grayscale you will see that you have more space for corrections.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #6790 of 6800 Old 08-26-2015, 11:16 AM
owtuv's Avatar
Quote:Originally Posted by dsinger
As I mentioned today in the Elite thread, check post 5486 on page 183. D-Nice posted his results on color tracking at various stim levels. Other than for cyan, the results look good to me.
I don't think the issue is poor tracking at different levels of stimulus, but at different levels of saturation.
I´m trying to understand the difference between levels of stimulus and levels of saturation, and how these levels relate to the ChromaPure patterns on the AVS HD709 disc:
- Is stimulus the same as luminance/intensity of the pattern?
- Are the patterns in the 75% Color chapter 75% intensity, 100% saturation?
- Are the 100/75/50/25% patterns in the Saturation chapter 100/75/50/25% saturation, 100% intensity?
- How and where in the ChromaPure workflow are these different patterns used?
- Is the 75% of Rec. 709 option in ChromaPure Options related with the use of 75% saturation patterns?
Ole
Bill Cruce likes this.
owtuv is offline
post #6791 of 6800 Old 08-26-2015, 09:07 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Ted, ChromaPure does not consider gamma when calculating dE values for white balance\grayscale.
Tom Huffman
Springfield, MO
post #6792 of 6800 Old 08-26-2015, 09:15 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Yes, stimulus is the same as luminance/intensity. Saturation is the distance from the white point independent of intensity. All else being equal, a color closer to the white point is less saturated and further from the white point is more saturated. The level of intensity is independent of distance from the white point.
You should direct the AVSHD questions to the AVSHD guys. I honestly don't know the answers to those questions.
You would use the saturation patterns in the Advanced Color Management module.
75% of Rec. 709 is the same as 75% saturation within the Rec. 709 gamut.
Tom Huffman
Springfield, MO
post #6793 of 6800 Old 08-26-2015, 11:42 PM
Quoted: 303 Post(s)
Liked: 734
Hi Tom, please look at your post here: Did grayscale with 94, worth 2nd pass with uv?
post #6794 of 6800 Old 08-27-2015, 02:05 AM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Yes, that's right. "We use the luminance element in dE calculations only for color. So, technically speaking we use uv for grayscale and Luv for color."
We treat color and grayscale/white balance different in this regard.
Tom Huffman
Springfield, MO
post #6795 of 6800 Old 08-28-2015, 02:32 PM
owtuv's Avatar
Quote:Originally Posted by HD-Master
If I want to use CIELUV for grayscale and then CIE94 for color...how do I do that? I see in the options that I can chose one or the other. Do I simply compete the grayscale section with CIELUV selected in the options, then change it to CIE94 in the options before doing color?
Currently, that's correct. The ability to use different dE formulas for grayscale and color--without switching in Options--is on our development roadmap.
I´m a new CP user using v. 2.5.8. Do we still need to manually switch dE setting in Options to use CIELUV for Grayscale and CIE94 for Color?
Ole
owtuv is offline
post #6796 of 6800 Old 08-28-2015, 02:36 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Currently, yes.
Tom Huffman
Springfield, MO
post #6797 of 6800 Old 08-29-2015, 01:18 AM
owtuv's Avatar
Jim:
You have to go VERY low to see difference between them. For example, the Klein can read the black level of a Pioneer Kuro. The D3 certainly cannot.
Tom,
What is the typical black level of the Kuros (I own a 600M)? What value should I set for Black Luminance in the BT.1886 options? Is the default 0.03 appropriate?
Ole
owtuv is offline
post #6798 of 6800 Old 08-29-2015, 09:56 AM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Although black is lower, I would leave it at the default value for BT.1886 purposes.
Tom Huffman
Springfield, MO
post #6799 of 6800 Unread Today, 04:04 AM
Liked: 2
@ Tom: a couple more feature request for CP3:
- Could you add a custom RGB option as pattern in de raw data module? Preferably with two radio buttons next to it to switch between the 16-235 and 0-255 ranges
- Could you make the CIE 1931 xy diagrams larger? Now I always make my own based on the raw data, because I find them a bit small for my reviews
- Could you also add a CIE 1976 u'v' diagram? As cherry on top it would be great to also have a 3D CIELAB graph (or two or three 2D graphs from multiple angles), but that would be a lot harder I guess
- Could you add a custom checkerboard pattern module for contrast tests, where you can set the number of zones in both horizontal and vertical direction?
- In a similar way as the checkerboard pattern module, could you also feature a uniformity test, where you for instance can measure a full screen pattern of 0, 25, 50, 75 or 100% grey in a custom number of zones (my last review for instance featured a 19x11 zones uniformity test on an Eizo ColorEdge CG277 display). The zones are displayed for meter positioning but turn off automatically once you start measuring that zone. Maybe also use the zones settings for raw data output. With that 19x11 zones test I exported every row as a separate CSV file, because your data is three dimensional: horizontal and vertical direction on display and xyY data on third axis, which is tricky to put in a single CSV file. With the checkerboard pattern you don't have that problem, because you only need the brightness, not the chromaticity.
- Last but definitely not least: support for European CSV format with semicolon as separator and comma as decimal point. Now I have to set my location settings to US English in Windows every time I want to use CSV output in ChromaPure (which is pretty much always), because if I leave it in Dutch both the separator and the decimal point are a comma. Or, second best, force the US CSV format, regardless of location settings in Windows, as long as the separator and decimal point don't end up using the same character.
Editor TFT Central
post #6800 of 6800 Unread Today, 12:43 PM
TomHuffman's Avatar
Quoted: 352 Post(s)
Liked: 400
Just to be clear, it is much too late to add new features to v. 3. It will be released fairly soon. I will add these to a list for future 3.x releases. BTW, you can get what you request now for the CIE diagrams by just running an Excel report on the data.
Tom Huffman
Springfield, MO
Reply Display Calibration
