The Official ChromaPure thread - Page 236 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #7051 of 7096 Old 02-02-2016, 08:16 AM
hollisavrct's Avatar
Quoted: 29 Post(s)
Originally Posted by davehancock View Post
I am a Pro and frankly do mess up. I learned way back in my isf training that it is CRITICAL to be able to go back so would record that data on paper. I use my own paper form to write down the values.
Unfortunately, there is so much variation in the controls on displays these days that a pre-formated place to record those settings is essentially useless (for example: dealing with a 20 step grayscale).
I didn't mean to open a can of worms but maybe Tom could make up a form for 2, 11 and 20 point that we could keep on our desktops to record the settings.
Only a thought
hollisavrct
hollisavrct is offline
post #7052 of 7096 Old 02-02-2016, 09:37 AM
davehancock's Avatar
Quoted: 102 Post(s)
Liked: 59
Only a thought
hollisavrct
You could do that yourself (notepad). And it is not just 2. 11, 21 point, either: CMS settings, gamma settings, etc. lots of variations. Where does one stop?
Maybe it is that I have been doing this since 2002, long before ChromaPure came along and haven't given up on my clipboard!
Dave Hancock
davehancock is offline
post #7053 of 7096 Old 02-02-2016, 11:14 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
How about this?
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #7054 of 7096 Old 02-03-2016, 06:28 AM
Quoted: 29 Post(s)
Originally Posted by TomHuffman View Post
How about this?
Works for me. You the man.
hollisavrct
post #7055 of 7096 Old 02-03-2016, 06:28 AM
Quoted: 29 Post(s)
How about this?
hollisavrct
post #7056 of 7096 Old 02-07-2016, 02:29 AM
Plutotype's Avatar
Quoted: 62 Post(s)
Liked: 32
How about this?
Thanks for the excel template.Do you have accidentally also the non-locked version of it?
Plutotype is offline
post #7057 of 7096 Old 02-07-2016, 03:06 AM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
I made it non-editable so users could only add data in the provided fields. I am happy to edit it if I get a reasonable request.
Tom Huffman
Springfield, MO
post #7058 of 7096 Old 02-07-2016, 05:03 AM
Quoted: 29 Post(s)
Could you add customer info field.
Hollisavrct
post #7059 of 7096 Old 02-07-2016, 05:11 AM
Plutotype's Avatar
Quoted: 62 Post(s)
Liked: 32
Calibration includes usually additional set of display specific settings for picture options, like size, enhancements, motion, backlightning, etc.
These would require one additional field, where these settings can be entered manually by the calibrator.
Anyway, if v3 offers some kind of custom reporting, coding custom settings modules shouldnt be a problem. That would allow the calibrator finish the report for the customer by inputting all calibrated picture settings directly into one output pdf report file.
- Basic settings module ( Display make, model, mode, contrast, brightness, color... )
- WB module ( 2p/10p/20p selector )
- Gamma 10p module
- CMS module ( HSL/RGB/XYZ selector )
- Custom text module ( small/medium/big selector )
post #7060 of 7096 Old 02-07-2016, 08:28 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
Here's an updated version.
Tom Huffman
Springfield, MO
post #7061 of 7096 Old 02-08-2016, 07:33 AM
Quoted: 29 Post(s)
Thanks Tom
Looks good.
hollisavrct
post #7062 of 7096 Old 02-21-2016, 09:40 AM
svellinis's Avatar
Quoted: 32 Post(s)
Hi Tom . I did a clean install of windows 10 64 bit and will be installed the chromapure version 2.5.8
You must install a different version of the net framework ? The operating system has built-in version 4.6 .1
With version 2.5.8 should replace the excel report for the color checker module ?
svellinis is offline
post #7063 of 7096 Old 02-21-2016, 10:32 AM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
No, 4.6.1 is fine. Yes, replace the Excel files with the ones available on the Support page.
Tom Huffman
Springfield, MO
post #7064 of 7096 Old 03-03-2016, 04:29 PM
Pres2play's Avatar
Quoted: 444 Post(s)
Liked: 252
Tom, something's wrong with the Gamut Sweep. 25%, 50% and 75% saturation measurements not popping up on the chart. Only the baseline measurements dots appear on 100% targets.
Pres2play is offline
post #7065 of 7096 Old 03-03-2016, 06:32 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
Works fine here. What are you using as a test pattern source?
Tom Huffman
Springfield, MO
post #7066 of 7096 Old 03-03-2016, 07:18 PM
Pres2play's Avatar
Quoted: 444 Post(s)
Liked: 252
I'm using the Chromapure Bluray test disc.
I'll post an image shortly.
post #7067 of 7096 Old 03-03-2016, 07:27 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
After you take the baseline measurements are you then selecting Primary Color Saturations (take measurements) and then Secondary Color Saturations (take measurements)?
Tom Huffman
Springfield, MO
post #7068 of 7096 Old 03-04-2016, 01:08 AM
Pres2play's Avatar
Quoted: 444 Post(s)
Liked: 252
Hey, Tom. Here's what I mean. I measured Red saturation at 25% and 50% but there's no circle in the target box.
Name:	Gamut sweep.PNG
post #7069 of 7096 Old 03-04-2016, 02:30 AM
Pres2play's Avatar
Quoted: 444 Post(s)
Liked: 252
Looking at the 25% and 50% values again, they appear to be closer to the 100% target box. Both show high error.
I'm using a LUT box (eeColor) by the way. I get the same reading with and without the correction LUT enabled, however.
post #7070 of 7096 Old 03-04-2016, 03:52 AM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
It looks to me that you may be displaying the the Amplitude test patterns instead of Saturation. Select Full Field, Window, or APL Sat/75%A test patterns and make sure that you select 75% Intensity on the main Adv Color Management page.
Tom Huffman
Springfield, MO
post #7071 of 7096 Old 03-04-2016, 07:55 AM
Pres2play's Avatar
Quoted: 444 Post(s)
Liked: 252
Thanks Tom, that was it.
post #7072 of 7096 Old 03-15-2016, 01:11 PM
dunan's Avatar
Quoted: 56 Post(s)
I use chromapure for my TV, can I use it for my pc monitor also?
dunan is offline
post #7073 of 7096 Old 03-16-2016, 12:38 AM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
Sure. Just use the built-in test patterns on your PC and use your video card's color adjustments. Most include at least white balance.
Tom Huffman
Springfield, MO
post #7074 of 7096 Old 03-20-2016, 09:38 AM
Oilmanmojo's Avatar
Quoted: 34 Post(s)
Noobie question
Tom: Just got my license and program yesterday to start playing around. I have the calibration disk ordered, but in the interim will use my HD essentials disk to do a prelimary look at greyscale. But for front projector, the manual says to use a full full field patterns. I am assuming then, i should not use the grayscale patterns that have the smaller field in the middle and the Pluges to either side.
If that is the case, why? since i position the colorimeter 1-2 feet off the screen, was just curious why a full field was needed. As i said, noob question
thank
tomg
Oilmanmojo is offline
post #7075 of 7096 Old 03-20-2016, 12:48 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
thank
tomg
Full fields are not required. They just make aiming the meter easier.
Bill Cruce likes this.
Tom Huffman
Springfield, MO
post #7076 of 7096 Old 04-04-2016, 07:34 AM
SoulOfUniverse's Avatar
Quoted: 96 Post(s)
Liked: 33
Hi Thomas,
Yesterday spotted this issue or strange behavior. I've connected i1Display3 for taking readings and doing Sequential contrast I've managed to get 0.002 only in CRT Mode 1.0 seconds integration time for my 0 IRE pattern, if I select 0.5 integration time values are always 0.005, I know it should be much lower of JVC projector and close to 0.0001 also different integration time settings directly impact on the value of sequential contrast, can you please clarify that?
Thank you.
SoulOfUniverse is offline
post #7077 of 7096 Old 04-04-2016, 01:34 PM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
You are bumping up against the low-light capabilities of this meter. Longer integration times will give more accurate readings. To get accurate sequential contrast readings, place the diffuser in the light path and point the meter towards the lens. Get it close enough to the lens that black is at least 0.1.
Tom Huffman
Springfield, MO
post #7078 of 7096 Old 04-05-2016, 12:47 AM
Quoted: 96 Post(s)
Liked: 33
I meant when I was measuring with integration time equal to 1 second I was getting 0 IRE 0.002 value in fL, then I've changed integration time to 1.6 I was getting the same 0 IRE 0.002 fL however native contrast value increased, where 100 IRE remain untouched.
I've tested today with diffusor on and I'm getting 0 IRE 0.004 fL and 100 IRE 21.200 fL native contrast is still very low, am I doing something wrong?
post #7079 of 7096 Old 04-05-2016, 01:13 AM
TomHuffman's Avatar
Quoted: 547 Post(s)
Liked: 513
You don't have the meter nearly close enough to the lens. As I recommended in my previous post, get it close enough so that that black measures at least 0.1.
Without exact numbers I can't comment on the contrast figures. "native contrast value increased" by exactly how much? No contrast value will be accurate so long as the black level measures that low.
Tom Huffman
Springfield, MO
post #7080 of 7096 Old 04-11-2016, 08:18 AM
Oilmanmojo's Avatar
Quoted: 34 Post(s)
tom
Another couple noob questions: I am still working on precalibration data (yeah i move slow). But i wanted to make sure i have this done correctly before attempting a calibration
1. I was working on the greyscale calibration. after 100% white, the calibration calls for 5% and then at the end 95%. Am i missing something, or does the chromapure calibration disk not have these entries? I have a DVE disk that does, but was wondering why the chromapure does not.
2. There is a section for color calibration at 50% saturation. Again, i see the 100% and 75% but is there not a 50% saturation. How do i perform this on the chromapure disk
Thanks in advance for your reply. I will soon post my results. The red is looking funny on the first graph as it is low then jumps high at 50% white then stays high. Green and blue look very close. My color gamut is slightly off but i wanted to get an opinion on my precalibration before i attempt a move on any control
tomg
Reply Display Calibration
taboola here
