The Official ChromaPure thread - Page 239 - AVS Forum | Home Theater Discussions And Reviews
 243Likes
post #7141 of 7152 Old 08-19-2016, 09:32 AM
hollisavrct's Avatar
Quoted: 33 Post(s)
Cp3.1
Hay Tom anything yet on CP3.1 and the Accupel yet
Hollisav
hollisavrct is offline
post #7142 of 7152 Old 08-21-2016, 02:20 AM
TomHuffman's Avatar
Quoted: 598 Post(s)
Liked: 545
Hollisav
Both are close.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #7143 of 7152 Old 08-22-2016, 01:14 AM
chhanthony's Avatar
Quoted: 33 Post(s)
Originally Posted by TomHuffman View Post
Both are close.
Yeah!!!....Thank you Tom!
Anthony Chan
chhanthony is offline
post #7144 of 7152 Old 08-23-2016, 07:28 AM
Quoted: 817 Post(s)
Liked: 148
Test the available options and then use what works best.
It's easy enough to try different options, but how does a user, in particular a novice one, decide which result is the "best" (most accurate, in this context)?
Dominic Chan is offline
post #7145 of 7152 Old 08-23-2016, 08:03 AM
TomHuffman's Avatar
Quoted: 598 Post(s)
Liked: 545
I am not sure that I understand your question. Calibration software and a good meter will SHOW YOU which is best.
If you are looking at white balance, then whichever setting gets you closest to R100%, G100%, B100% or x0.3127, y0.329 or dE < 2.0 is, by definition, the "best."
If you are looking at color, then whichever setting produces the lowest average dE is, by definition, the best.
If you are looking at gamma, then whatever setting gets you the closest to the target gamma (2.22, for simplicity's sake) is, by definition, the best.
None of this requires any special expertise, beyond a rudimentary understanding of what white balance, color accuracy, and gamma mean. Even a novice can determine this right off the bat.
Tom Huffman
Springfield, MO
post #7146 of 7152 Old 08-23-2016, 08:33 AM
Quoted: 817 Post(s)
Liked: 148
I was referring to the part regarding "What is the best pattern size to use, 10% windowed, 6.5% windowed or 10% APL?"
The different settings will theoretically all give you the correct gamma when displaying the respective test pattern, as calibration is a "closed loop" system with the adjustments being made to achieve the correct white balance and luminance for each pattern.
However, my understanding that some TVs (e.g., plasma) may respond differently to actual program material, depending on the test pattern used during calibration.
post #7147 of 7152 Old 08-23-2016, 11:59 AM
TomHuffman's Avatar
Quoted: 598 Post(s)
Liked: 545
I don't think that there is any correct answer to this question. The only thing I would look at is which provides the most linear gamma response. This is one of those issues where the differences are very, very small that I think get a little more attention than they deserve. What is critical is that windows are used on plasma and OLED.
BTW, I did notice that some OLEDs may respond better with a 10% window than with a 5% window. The reason is that LG OLEDs will start to dim if it senses a static image on the screen. Changes in color and intensity are not a large enough change in overall APL for the TV to detect change, but with a 10% window this is not a problem. This is why I suggested starting with a 10% as the safest choice.
Tom Huffman
Springfield, MO
post #7148 of 7152 Old 09-15-2016, 01:28 PM
Quoted: 33 Post(s)
Cp3.1
Tom it has been almost a month sense I last asked about CP3.1 and the DVG-5000.
Hoping to hear some good news.
Hollisav
post #7149 of 7152 Old 09-17-2016, 01:46 AM
TomHuffman's Avatar
Quoted: 598 Post(s)
Liked: 545
Hollisav
All work on AccuPel hardware is complete. The only software issue remaining is supporting HDR, which is fairly straightforward. Then it is just a matter of ordering the parts for the case and assembling the final product.
CP 3.1 has completed all of the primary updates, except Duo auto-cal, which will be the last item. After that it is just clean-up, debugging, and documentation.
Tom Huffman
Springfield, MO
post #7150 of 7152 Old 09-17-2016, 03:07 AM
DaMacFunkin's Avatar
Quoted: 275 Post(s)
Liked: 103
So tomorrow then?
DaMacFunkin is offline
post #7151 of 7152 Old 09-23-2016, 02:10 PM
thrang's Avatar
Quoted: 1434 Post(s)
Liked: 1205
Hi Tom
Are you planning HDR support for the Radiance Pro?
FS: JKP Affinity .09 Fixed Frame 2.35 screen, 12.5 feet wide - PM for details, ad not posted yet
Thrang's Home Theater, For Now...
thrang is online now
post #7152 of 7152 Old 09-23-2016, 02:20 PM
TomHuffman's Avatar
Quoted: 598 Post(s)
Liked: 545
In 3.1 we have implemented an HDR gamma option that provides the correct gamma curve to calibrate to, but you'll have to put the Radiance Pro into HDR mode manually first. I have instructions for this in the CP3 thread. In the next version we'll had a software toggle for HDR mode.
Tom Huffman
Springfield, MO
Reply Display Calibration
