The Official ChromaPure thread - Page 245 - AVS Forum | Home Theater Discussions And Reviews
 260Likes
post #7321 of 7331 Old 04-18-2017, 05:01 PM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2136
Originally Posted by spongebob View Post
Ted,
The link in your sig is not working.
bob
Hi Bob,
It's working here, very strange, can you retry please?
or use that link: http://www.displaycalibrations.com/r...ad_no_ads.html
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #7322 of 7331 Old 04-18-2017, 05:17 PM
spongebob's Avatar
Quoted: 97 Post(s)
Originally Posted by ConnecTEDDD View Post
Hi Bob,
This one works fine but not the other in firefox.
thx
bob
spongebob is offline
post #7323 of 7331 Old 08-06-2017, 05:53 PM
Pres2play's Avatar
Quoted: 679 Post(s)
Liked: 327
Which is best for taking measurement of 4K HDR displays, Chromapure or Chromapure 3? Or does it matter?
Pres2play is offline
post #7324 of 7331 Old 08-06-2017, 05:59 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 707
Only CP3 supports HDR and 2020.
Pres2play likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #7325 of 7331 Old 08-26-2017, 04:42 AM
Silver Serpent's Avatar
Hi,
I have an i1D3 pro with Chromapure V2.
I've recently purchased a LG OLED but do not have that mode to select when begining calibration.
What would be the best mode to select from what is available?
LG LED LCD?....Generic LCD maybe?
Perhaps its just time to update the meter and software.
Silver Serpent is offline
post #7326 of 7331 Old 08-26-2017, 12:15 PM
Liked: 2136
Originally Posted by Silver Serpent View Post
Hi,
Hi,
If you install the latest ChromaPure 2.x, you will see the OLED table, because it's something X-Rite added to their SDK's to operate the meter which coming with any CP installation.
i1Display PRO is using spectral calibration architecture which makes the meter field upgradeable to support future display technologies.
These available spectral characterization options are stored inside X-Rite's SDK (Software Development Kit) files using X-Rite’s EDR file format. New display technologies can be added with a newer release of X-Rite's SDK to software developers which can include the new display type selections to their future software releases.
So installing the latest CP 2.x you will see that option, but the problem is that the spectral correction for OLED of X-Rite i1Display PRO is not good for LG OLED's.
X-Rite used a Sony PVM-2541 RGB OLED Monitor to create the OLED spectral correction (at 1 nm internals using a Konica-Minolta CS-1000 spectroradiometer) for i1Display PRO which can be useful when you will measure the Sony or FSI (Flanders Scientific Inc.) RGB OLED Broadcasting Monitors and not a consumer LG WRGB OLED or the following brands which are using LG's WRGB OLED panel also: Sony, Panasonic, Toshiba, Loewe, Philips, Skyworth, Metz, Grundig, Vestel, Arçelik and Bang & Olufsen.
post #7327 of 7331 Old 08-26-2017, 12:35 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 707
If you have a Display 3 PRO, the only reason you are not seeing an OLED mode is that your license and its corrections were created before the OLED correction was available. You can send us your meter and we can add the OLED option for $50. Or, we can recalibrate the meter completely with all of the new corrections for $175. None of the older corrections really fit the OLED mode.
Tom Huffman
Springfield, MO
post #7328 of 7331 Old 08-26-2017, 12:37 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 707
Ted, we don't use X-Rite's EDR format for our corrections. We do this using our own proprietary approach, and we use an LG OLED for the OLED mode.
Tom Huffman
Springfield, MO
post #7329 of 7331 Old 08-26-2017, 12:40 PM
Liked: 2136
Hi Tom, I was talking about a normal i1Display PRO instrument, not for the enhanced by you meters which feature additional offset tables (not EDR).
post #7330 of 7331 Old 09-26-2017, 10:37 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
Can I calibrate a OLED tv with Chromapure version 2.5 and an i1 Display Pro 3?
sanderdvd is offline
post #7331 of 7331 Old 09-27-2017, 02:00 AM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 707
Sure. You can't do HDR or Rec. 2020, but you can certainly calibrate HD w/SDR.
Tom Huffman
Springfield, MO
Reply Display Calibration
