The Official ChromaPure thread - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 156Likes
post #961 of 6627 Old 03-31-2011, 11:36 AM
pers1's Avatar
Thanks. Well I will wait untill JVC releases a firmware.
PerS
pers1 is offline
post #962 of 6627 Old 03-31-2011, 11:49 AM
Geof's Avatar
Liked: 37
PerS
That is what I decided as well but that'll depend on when they release it versus when I get the bug to get it done.
Geof
Geof is offline
post #963 of 6627 Old 03-31-2011, 05:32 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
Originally Posted by anbjornk View Post
With all due respect, Tom, your package would not work with the X7 either. The problem is not the software, but the color filters used in the projector. Due to the fact that the filters "transfer" light from the green spectrum in to green and blue, no meter will read correctly. This also means that the "traditional way" of measuring grayscale will not work.
I am reluctant to comment on something I haven't experienced for myself, but I am very skeptical that a projector's output is such that "no meter will read correctly". I have been reading stuff like this for years for various display technologies and I have never been able to confirm anything like this. Also, if "no meter" can read it how would you know? What's the reference against which it is being compared?
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #964 of 6627 Old 03-31-2011, 06:18 PM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
Originally Posted by lbosley View Post
Tom - Maybe it's just my configuration, but I think I found an error in the green calibration of the latest ChromaPure release. I was excited to see the 75% Rec. 709 Color Management capbilities because my display is much more accurate when calibrating to the 75% saturation points first. But when I put this to the test this morning it appears to me that the green measurements with this gamut selection is still looking for a 100% saturation pattern. I used the Advanced CM measurments to verify this. Please take a look.
Love the product!!
Tom, did you see this post? Can you verify if what lbosley is saying is true or not? I've got a DVDO DUO on the way and I was hoping to calibrate my setup on the weekend.
Kilgore is offline
post #965 of 6627 Old 03-31-2011, 06:24 PM
davehancock's Avatar
Quoted: 77 Post(s)
Liked: 55
I am not intimately familiar with the particular projector referred to here, but I don't understand what you are saying here. Filters can ONLY reduce certain parts of the spectrum. There is no way that a filter can move energy from one part of the spectrum to another (which your statement seems to imply).
Now it is possible to have sharp cut-off filters which might make measurement difficult (though I doubt it) - but there is no "transfer" of light going on.
Dave Hancock
davehancock is offline
post #966 of 6627 Old 03-31-2011, 07:25 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
I just tested this and I see no problem. I measured 75% green in Advanced Color Management and standard Color Management
Color Management
x y Y CIE94
ACM 0.280 0.595 0.744 5.9
CM 0.280 0.591 0.746 5.7
If color management were expecting 100% saturation, then what is essentially the same measurement would have a much higher dE than what is measured in advanced color management, but they are virtually identical.
Love the product!!
Tom Huffman
Springfield, MO
post #967 of 6627 Old 03-31-2011, 11:19 PM
anbjornk's Avatar
I did not do the calibration, so I cannot say anything for sure, but i trust my colleague when he says it's "impossible". I will make him aware of this thread, so that he can comment on this (if he wants to).
anbjornk is offline
post #968 of 6627 Old 03-31-2011, 11:27 PM
anbjornk's Avatar
I'm no expert on filters, so I cannot really comment more on this. What I do know though, is that there is way to much green energy in red and blue, which makes the X7 nearly impossible to calibrate correctly.
anbjornk is offline
post #969 of 6627 Old 04-01-2011, 05:06 AM
lbosley's Avatar
Tom - Like I said, maybe it's my configuration or something that I am doing wrong. I looked at this again this morning and I come up with the same issue. All of the other colors are consistent except for green.
See the attached document showing my measurements. The graph indicated the pattern is 8.5% under-saturated. The data shows otherwise.
I am using the latest AVSHD pattern windows for the test. 100% white for the white reference, and 75% saturation patterns for the colors.
- Larry
Green.doc 106k . file
lbosley is offline
post #970 of 6627 Old 04-01-2011, 06:15 AM
lbosley's Avatar
Tom - Doesn't your measured saturation values of almost .6 put your green measurement values at the 100% point on the chart, as well? And your graph shows it 1.2% under-saturated. What am I missing here?
lbosley is offline
post #971 of 6627 Old 04-01-2011, 08:31 AM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
- Larry
What's your Y reading for White?
Kilgore is offline
post #972 of 6627 Old 04-01-2011, 08:40 AM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
You know, you are absolutely right.
We will be releasing a version with a few bug fixes in a few days. This will be in it.
Tom Huffman
Springfield, MO
post #973 of 6627 Old 04-01-2011, 08:44 AM
lbosley's Avatar
White luminance is somewhere around 120 cmd2. But as far as I know it shouldn't have any effect on the xy coordinates of a particular reading. Don't worry about my luminance measurements I show in the ACM readings. I didn't measure white first. I admit there may be something that I don't understand, but it looks cut and dry to me. I suspect that the "reference" 75% green that Tom has been using for the software is actually at 100% saturation. Just look at the values he lists in his own test:
x y Y CIE94
Plot this "75%" saturation color on the gamut chart and tell me where it ends up.
I apologize in advance if I'm wrong. But somebody please enlighten me about my numbers.
lbosley is offline
post #974 of 6627 Old 04-01-2011, 09:36 AM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
This is just a problem with the Color Management module when using 75% Rec. 709, correct?
I could just use the Raw Data module and calibrate to the right xyY values for 75% Saturation, and the White Balance and Gamma modules are still working fine...is that right? My new DUO will arrive any minute and I'm dying to play with it!
EDIT: My Duo is here!
Kilgore is offline
post #975 of 6627 Old 04-01-2011, 10:34 AM
lbosley's Avatar
Yes, the complete set of saturation measures in the ACM group seem accurate to me. I am also using a Duo for my calibrations, so I understand your enthusiasm. This was only a big deal for me because my 100% saturation values are probably the worst points in the gamut for my set in terms of accuracy. I found that using the 75% targets as the primary reference greatly improved my satisfaction with the resulting calibration. I was VERY excited to see the shortcut method of CM included in this new version for the 75% saturation points. Then I stumbled over the green bump...
Best of luck with your Duo.
lbosley is offline
post #976 of 6627 Old 04-01-2011, 10:38 AM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
Thanks...nice catch on the CMS bug.
Kilgore is offline
post #977 of 6627 Old 04-03-2011, 11:31 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
We'll be releasing 2.11 later this week containing some bug fixes that have been caught. Since it was discussed here, I wanted to mention that it will include setting all Lumagen test patterns to Adjustable. I discovered that it resets to Reference every time you save changes.
Tom Huffman
Springfield, MO
post #978 of 6627 Old 04-04-2011, 08:48 AM
MurcielagoSV213's Avatar
Tom, I emailed you guys but figured id drop the question here. For a home user, what package of yours would you recommend for LED LCD and Plasma? CMS/Gamma/Grayscale
MurcielagoSV213 is offline
post #979 of 6627 Old 04-04-2011, 10:18 AM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
PM sent.
Tom Huffman
Springfield, MO
post #980 of 6627 Old 04-05-2011, 11:00 AM
Thanks Tom, just ordered my I1/LT combo. Looking forward to reading this thread.
post #981 of 6627 Old 04-05-2011, 11:29 AM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
Tom, if I buy a 2nd i1 Display LT, do I have to pay an additional fee to license it, or is the fee waived because I'm buying the same meter I'm already licensed for?
EDIT: according to the Curt Palme site, there's no fee if I'm getting the same meter.
Kilgore is offline
post #982 of 6627 Old 04-05-2011, 11:36 AM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
The issue isn't the type of meter, but the intended use. If you are replacing an old D2 with a new D2, then there is no licensing fee because you are still only using one meter. However, you wish to have both meters on the same license, then there is a fee.
Tom Huffman
Springfield, MO
post #983 of 6627 Old 04-05-2011, 12:06 PM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
I'd be replacing my old meter. I'm suspecting there's a problem with the one I have. I'm getting bizarre results with the one I have. I was having the same problem before.
Before calibration, the image is perfectly watchable. I even had comments about how awesome the picture looks. However, my initial grayscale readings showed Red to be at +130-140% across the board, Green was at 100%, and Blue was so low it wouldn't even show up on the chart. Yet, the resulting image was fine. If I checked out the AVSHD color clipping chart (the 3rd pattern under miscellaneous A), I could see R,G, and B all flashing up to 235.
I have 1100 hours on the lamp. Using the Living Room setting, I'm getting around 14 cd/m2, (brand new it was 35, so the light output has certainly diminished) but the PJ is still plenty bright. The settings I'm using now are ones I used when the lamp was fairly new, and the image looks pretty darned good, yet CP is showing this wacky grayscale.
I just got a DUO, and was able to get the grayscale pretty dead on from 70% down, but the resulting image is decidedly bluish.
Is it possible that the meter is to blame? Maybe it's having a hard time reading accurately now that the light output has lessened. It seems to work ok on my computer monitor.
Kilgore is offline
post #984 of 6627 Old 04-05-2011, 02:31 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
However, my initial grayscale readings showed Red to be at +130-140% across the board, Green was at 100%, and Blue was so low it wouldn't even show up on the chart. Yet, the resulting image was fine. . . .
That's what it sounds like.
Tom Huffman
Springfield, MO
post #985 of 6627 Old 04-05-2011, 07:17 PM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
Ok, Tom...I'm going to get a new i1 Display LT to replace the old one. When I get it, do I get in touch with you with the serial number and you give me a new license? I have no desire to use the old meter at all. How do I arrange this?
Kilgore is offline
post #986 of 6627 Old 04-05-2011, 07:21 PM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
BTW, with readings like I got above, what would you expect the resultant image to look like?
Kilgore is offline
post #987 of 6627 Old 04-05-2011, 08:07 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
Just send ChromaPure Support a request.
Tom Huffman
Springfield, MO
post #988 of 6627 Old 04-05-2011, 08:09 PM
TomHuffman's Avatar
Quoted: 303 Post(s)
Liked: 392
If you mean these readings
"Red to be at +130-140% across the board, Green was at 100%, and Blue was so low it wouldn't even show up on the chart. "
I would expect an image to be unwatchable.
Tom Huffman
Springfield, MO
post #989 of 6627 Old 04-05-2011, 08:21 PM
Kilgore's Avatar
Quoted: 466 Post(s)
Liked: 336
That's what I would expect to see too. Yet I'm watching with those very same settings as we speak and the image is a tad warm, yet very watchable. It must be the meter.
Kilgore is offline
post #990 of 6627 Old 04-06-2011, 03:35 AM
pers1's Avatar
Hey Tom
What Software/Meter Bundles would u reccommend for me doing calibration for my home setup :
My Setup
Projector: JVC X7
Processor: DVDO iScan Duo
Screen: Adeo grey 77"
Room has good light control
my cinema:
http://avforum.no/minhjemmekino/show.php//meridian861
PerS
pers1 is offline
Reply Display Calibration
