The Official ChromaPure thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 255Likes
post #991 of 7270 Old 04-06-2011, 09:47 AM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
A Chroma 5 PRO or i1Pro. If you can afford it, both. If you can't, then the Chroma 5 PRO.
Originally Posted by pers1 View Post
Hey Tom
What Software/Meter Bundles would u reccommend for me doing calibration for my home setup :
My Setup
Projector: JVC X7
Processor: DVDO iScan Duo
Screen: Adeo grey 77"
Room has good light control
my cinema:
http://avforum.no/minhjemmekino/show.php//meridian861
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #992 of 7270 Old 04-06-2011, 09:50 AM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
ChromaPure 2.1.1 has been released and is available for download. Just go to our News page for a link and release notes. This is a maintenance release that provides some bug fixes that were discovered in 2.1.
If you have no issues with 2.1, you can skip this release. It has no new features.
Tom Huffman
Springfield, MO
post #993 of 7270 Old 04-06-2011, 11:12 AM
pers1's Avatar
Got a PM so I deleted the Q, Thanks Tom
pers1 is offline
post #994 of 7270 Old 04-06-2011, 08:12 PM
breadvan's Avatar
Tom, I suppopse 2.1 should be uninstalled before installing 2.1.1 ?
breadvan is offline
post #995 of 7270 Old 04-06-2011, 08:15 PM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2394
As always. The installer will tell you to remove the old version if you forget.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #996 of 7270 Old 04-07-2011, 10:19 AM
rachmat-d's Avatar
Tom, please advise what to do with my calibration ?
I am using Sony xbr 8 and radiance.
I am confused with delta E or Luminance is important with CMS ?
I can not get the blue right .
sony 7-4-11.zip 433.1611328125k . file
rachmat-d is online now
post #997 of 7270 Old 04-07-2011, 11:19 AM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
dE is a measurement of color error, so yes it is important. Luminance is just one component of dE.
Blue is undersaturated. Unfortunately, there is nothing you can do about this, unless the Sony has a Picture mode that moves the color points outwards. Then you could use the Radiance to bring them back to their proper location.
Tom Huffman
Springfield, MO
post #998 of 7270 Old 04-08-2011, 10:11 AM
rachmat-d's Avatar
Thanks Tom
post #999 of 7270 Old 04-08-2011, 11:10 AM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Tom, I sent a message to you through the Support page on the ChromaPure site requesting a license for a new i1 Display LT I purchased as a replacement for my old one. I included the serial number for both meters.
Kilgore is offline
post #1000 of 7270 Old 04-08-2011, 09:49 PM
Goosey's Avatar
How much better is the Chroma 5 Pro compared to the 2/LT. The Chroma 5 Pro package is quite a step up in price, although one benefit to getting the Chroma 5 Pro is that it can be recalibrated?
Goosey is offline
post #1001 of 7270 Old 04-08-2011, 11:17 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
New, it is considerably more accurate and, as you say, it can be recalibrated.
Tom Huffman
Springfield, MO
post #1002 of 7270 Old 04-09-2011, 01:48 PM
drapp1952's Avatar
Quoted: 14 Post(s)
Tom, Under CMS, could 25% and 50% Rec.709 reference gamuts be added as options under "Select Reference Gamut"? I like the simplicity of the graph for corrections there, versus toggling between measurement modes and charts in Advanced Color Management (which is a great addition to CP).
Finding the best overall correction for saturation levels more typical in video material (not just 100% sat) is more feasible now with CP's Advanced Color Management, assuming decent tracking or linearity in the correction hardware/software and viewing device. Fortunately the JVC RS10 and VideoEQ seems to respond linearly to saturation and brightness adjustments. Prior to this CP I couldn't monitor results so easily. (I'm not a spreadsheet expert or into inputting data manually.)
drapp1952 is online now
post #1003 of 7270 Old 04-09-2011, 03:41 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
Unless I misunderstand, this is really not necessary.
First, use ACM to diagnose how well your calibration has tracked using the standard gamut selections. If you see that 100% saturation does not yield good results, then you can go back to the Color Management module and recalibrate at 75% saturation. I do not believe that calibrating to 50% or 25% saturation instead would yield significantly different overall results.
Now, go back to ACM and remeasure to see the results at all levels. The Color Management module is not for reporting or diagnosis. It is strictly for calibration. Use the ACM module for diagnosis and reporting.
Tom Huffman
Springfield, MO
post #1004 of 7270 Old 04-10-2011, 11:05 AM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Tom, which concrete gamma formula does Chroma Pure use to calculate the gamma ? ITU/EBU, Power Function, L*, Dicom, sRGB ... ???
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: JVC-X7000 (Beamer), Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #1005 of 7270 Old 04-10-2011, 11:47 AM
buzzard767's Avatar
Liked: 2394
Question: If I profile a C5 from an i1Pro used for reference, then disconnect the C5 to use the i1Pro for color, if I once again want to use the C5 to check grayscale does the entire meter profiling procedure need to be repeated or can I just press the apply button in the Meter Correction module after re-initiating the C5?
Buzz
post #1006 of 7270 Old 04-10-2011, 01:39 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
Power function.
Tom Huffman
Springfield, MO
post #1007 of 7270 Old 04-10-2011, 01:45 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
If yoiu have corrected the C5 with the i1Pro, I can think of no reason you would want to then use the i1Pro for color. The whole point of meter correction is that the corrected meter emulates the reference device.
But to answer your question, I honestly haven't tested this scenario, so I can't say for sure. In any case you wouldn't have to do the correction again. Just export a session file after applying the correction. You can always import that session later on to reuse the corrections.
Tom Huffman
Springfield, MO
post #1008 of 7270 Old 04-10-2011, 01:46 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Power function.
Hm, I used the Power Function with CalMAN & Chroma Pure too with a gamma target value of 2.2. My room is completely optimized (= black stuff) and darkened. But the resulting picture is much too dark with details lost in the low IREs. I have to increase the brightness controler of the JVC-RS40 to compensate it. And that destroys the black level. The only solution is to choose a gamma value of 2.0.
Do you have any further solutions for that problem ?
post #1009 of 7270 Old 04-10-2011, 03:09 PM
buzzard767's Avatar
Liked: 2394
Thanks Tom. The question arose because of a PM exchange and neither of us knew the answer. Is there any case, any type of display, where the i1Pro would be preferable to the profiled C5? I'm calibrating a Runco 750i for a good friend on Tuesday and want it as accurate as possible.
Again, thank you. Your customer service via this thread and your site is second to none and I'm really glad I chose ChromaPure Pro.
Buzz
post #1010 of 7270 Old 04-10-2011, 03:46 PM
ConnecTEDDD's Avatar
Quoted: 1077 Post(s)
Liked: 1543
+1 For The Very Important After Sales Customer Support Of ChromaPure.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #1011 of 7270 Old 04-10-2011, 04:56 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
I just don't see this. If a projector's peak output is 14 fL, the the output at 10% input should be 0.084 fL, at 5% 0.018 fL. This is 2.22 gamma and looks good to my eyes.
Tom Huffman
Springfield, MO
post #1012 of 7270 Old 04-10-2011, 04:57 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
None that I can think of. After correction, for all intents and purposes you are using an i1Pro, except for the vastly better low-light sensitivity.
Tom Huffman
Springfield, MO
post #1013 of 7270 Old 04-11-2011, 09:26 PM
rachmat-d's Avatar
Tom,
What color setting in ChromaPure for your dvd test pattern ( Rec 709 or NTSC ) if i am using it with HTPC ( Media Player Classic ) and JVC RS 25 ?
post #1014 of 7270 Old 04-11-2011, 10:47 PM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
Tom,
I'm sorry, I don't understand your question.
Tom Huffman
Springfield, MO
post #1015 of 7270 Old 04-11-2011, 11:58 PM
rachmat-d's Avatar
Tom,
I like to calibrate JVC RS 25, source is HTPC (Player is Media Player Classic ) using RGB color pattern from your DVD file.
I assumed to use Rec 709 in Chroma pure or i use 601 ( NTSC ) , as the file is SD ?
post #1016 of 7270 Old 04-12-2011, 12:03 AM
TomHuffman's Avatar
Quoted: 692 Post(s)
Liked: 616
The pattern source has nothing to do with the gamut selection in CP. Select whichever gamut you want to calibrate to.
Tom Huffman
Springfield, MO
post #1017 of 7270 Old 04-12-2011, 04:27 AM
buzzard767's Avatar
Liked: 2394
Should a Hubble be profiled from a reference meter, in my case the i1Pro, or are the profiles already within the Hubble more than proficient?
Buzz
Buzz
post #1018 of 7270 Old 04-12-2011, 07:34 AM
anbjornk's Avatar
BUT, do we know for sure that the gamma at 5% and 10% is 2.2? Even though the average gamma is 2.2, there might be deviations from this in some areas. If thee gamma is 2.2 flat, there should be plenty of details in the darker areas.
anbjornk is offline
post #1019 of 7270 Old 04-12-2011, 08:53 AM
rowland.johnson's Avatar
It would seem that importing a previous session causes subsequent measurements to be either incorrect or to be displayed incorrectly. To see this do the following
1. Start CP and go to the Pre-Calibration Grayscale panel.
2. Take a measurement. I took one at 30% and RGB were each very close to 100%
3. Export to a file
4. Import that file
5. Observe that the RGB at that measurement are all now different. In my case R 110%, G 95%, B 110%
6. Taking other measurements shows R and B being higher and with G being lower than what they should be.
I'm using build 2.1.17629
rowland.johnson is offline
post #1020 of 7270 Old 04-12-2011, 01:23 PM
JoeFinn's Avatar
3. Export to a file
4. Import that file
I have noticed some weird behavior when trying to continue incremental work on a previous session. What I basically was trying to do was load previous session, save under new name and take new pre calibration measurements to follow progress. When I try to measure new pre cal, the results show like the program is calculating something wrong, results are not even close to the ones where I left of (Chroma 5 Pro). I close the program, start new session, init meter, take measurements and get the results I expect. I have seen this many times.
I think my problem might be related.
JoeFinn is offline
Reply Display Calibration
