The Official ChromaPure thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 260Likes
post #211 of 7329 Old 02-07-2010, 12:00 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
Originally Posted by p5browne View Post
But where do I stand with the CIE94 equalling 0.6?
Is it good, have to go up or down or sideways?
0.6 is a level of error that is essentially invisible. You can't do better than this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #212 of 7329 Old 02-07-2010, 12:02 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
Originally Posted by Dralt View Post
I am going to sound really dumb, but I still fail to see how I tweak the settings my HDTV offers in order to achieve proper calibration.
Nothing specific to ChromaPure.
With all that calibration witchcraft, it's very hard to figure out what to actually do during a calibration session.
You display test patterns on the screen. You measure those test patterns with a color analyzer and software. The software tells you the level of error the color analyzer sees relative to what it is supposed to see. You use the TV's controls to make those errors smaller.
This is a very general answer to a very general question.
Tom Huffman
Springfield, MO
post #213 of 7329 Old 02-07-2010, 12:44 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
ChromaPure is on CIE94 all IRE Values at Zero
100 IRE - x=0.299 y=0.307 Y=270.375 RGB Blu= 110 Red= 98 Green= 99
90 IRE - x=0.296 y=0.307 Y=214.177 Blu= 120 Red= 93 Green= 100
Gamma- At 90IRE= 2.1
Calman using D65, HD Rec 709 Gamma Target - 2.22 Formula DeltaE - 1994
100 IRE - x=0.3002 y=0.3005 Y=93.9174 RGB Blu= 115 Red=95 Green= 88
90 IRE - x=0.2982 y=0.3002 Y=74.1364 Blu= 117 Red=94 Green= 89
Gamma at 90IRE and 100IRE - Blu - Off bottom of scale
100IRE - Red=2.4 Green=2.0 90IRE - Red=2.1 Green=2.5
The only Big differences I see is the Value of Y - ie: Y=214.177 verus =74.136 and the Blue at 90 and 100IRE
It is likely that the large difference in Y is only because one is set to read in fL and the other is set to read in cd/m2 (270 cd/m2 = 79 fL). This still shows a discrepancy, but a much, much smaller one.
I think that the ChromaPure 100% stim (x0.299, y0.307) should be
R98
G99
B121 (not B110). Is this is typo?
The 90% reading (x0.296, y0.307) is almost the same, and you have this essentially correct at
R93
G100
B120
Since the white point target is the same for SMPTE-C, Rec. 709, and EBU, any differences in the RGB analysis between the gamuts will be very small. For example, x0.299, y0.307 in SMPTE-C is
R98
G98
B120
and in Rec. 709 it is
R98
G99
B121
which is negligible.
Tom Huffman
Springfield, MO
post #214 of 7329 Old 02-07-2010, 01:04 PM
rfbrown94's Avatar
Your chromapure Y values are in cd/m^2 and the calman Y values are in fL. Your contrast is likely too high and is causing a color shift which may be why your 90 and 100 IRE x,y are off. I'd suggest lowering contrast to the 45-50fL range for daytime viewing.
rfbrown94 is offline
post #215 of 7329 Old 02-07-2010, 01:40 PM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Again, both products have the ability to produce reports. Pick a set of adjustments, run a calibration with the same settings for each product and post them. Otherwise the prudent assumption about differences is operator error.
bodosom is offline
post #216 of 7329 Old 02-07-2010, 06:25 PM
p5browne's Avatar
Quoted: 3104 Post(s)
Liked: 2418
R98
G99
R93
G100
B120
R98
G98
B120
R98
G99
B121
Checked my notes and I wrote B=110 at 100IRE and B=120 at 90IRE.
Will have to find that setting and change lumination setting to be the same.
Did another calibration today and at 100IRE - Red hit the max adjust point of 50. Turned the BackLight off today since the ChromaPure is not setup for the Enhanced Chroma5 - someone else brought up this point. Still can't understand my getting the Yellow tinge on Calman and Red with ChromaPure. Nothing is changed except switching between Calibration software.. Results of todays calibration: CIE94=0.5 CCT=6494 Gamma=2.2
100IRE R50 G-4 B-40 90IRE R24 G-8 B-39 80IRE R26 G-8 B-41
70IRE R15 G-21 B-38 60IRE R12 G-16 B-34 50IRE R3 G-24 B-34
40IRE R-3 G-22 B-30 30IRE R-6 G-23 B-28 20IRE R-8 G-18 B-23
10IRE R-7 G-12 B-16
One of the other Forum members mentioned turning the colour setting right down to 0 before starting - I haven't heard of this one before.
Backlight is set at 69 (Turned off for this calibration)
Contrast is set at 90 Brightness is at 52 Colour is set at 48 and Tint at 0
Used to have Contrast set at 84 but recent checks on this put it now at 90
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is offline
post #217 of 7329 Old 02-07-2010, 07:19 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
It is impossible for x0.299, y0.307 to read B110 and x0.296, y0.307 to read B120. The difference between these two readings is in the red channel. Blue is virtually the same. The level of stimulus doesn't matter.
I really don't know what this means. If you use the backlight during normal viewing, then you should calibrate with it on. It is the same with the Color control.
I agree with a previous poster. Please run calibration reports or take screen shots of the grayscale run and then post them. For the purpose of diagnosing this discrepancy, dE, CCT, and gamma are not relevant. All we need to see is the xy and RGB data.
Tom Huffman
Springfield, MO
post #218 of 7329 Old 02-07-2010, 08:51 PM
catmother's Avatar
ChromaPure defaults to CD/m2. The first change I made in options is to set it to FL for easier comparison with most reports which use FL.
Tom, when using ChromaPure with a Spectracal LED modified C5, would Chromapure even see that, or if it did would it make a measurable difference.
The C5 you sent me is not modified but the one p5browne uses is. When he uses it with CalMan vs ChromaPure could that account for the differences he sees ?
Certified HDTV junkie and AVS addict
U.S. Army FA WWII
catmother is offline
post #219 of 7329 Old 02-07-2010, 10:08 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
You'll have to ask the CalMAN guys to be sure, but I believe that there is no modification to the meter itself. I think that the modifications are at the software level. A vendor is free to create any software-based mode for a meter they like. We are working on precisely this for version 1.3 as a way of improving the Chroma 5's accuracy, which is quite good already, but certainly has room for improvement.
Tom Huffman
Springfield, MO
post #220 of 7329 Old 02-07-2010, 11:47 PM
Rolls-Royce's Avatar
Quoted: 371 Post(s)
Liked: 543
The LED tables are loaded into the C-5 itself. I purchased one recently and use it with an existing CalMAN installation. No other software or data came with the probe.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #221 of 7329 Old 02-08-2010, 04:13 AM
p5browne's Avatar
Liked: 2418
In the Calman software, when it detects the meter, it comes up as a Chroma5 Enhanced and you select `LCD with LED' instead of `LCD' for monitor selection. So I turned Off the Local Dimming when calibrating with the ChromaPure since it's LCD only.
p5browne is offline
post #222 of 7329 Old 02-08-2010, 07:43 AM
stash64's Avatar
Quoted: 282 Post(s)
Liked: 100
As Tom said, you should set your display up for calibration in the same manner you intend to use it. Why turn off local dimming since it should improve black level performance ? Whether local dimming is on or off, it is still an LED backlit LCD display. Turning off local dimming is not the same as turning off the backlight.
Sean
stash64 is offline
post #223 of 7329 Old 02-08-2010, 07:52 AM
catmother's Avatar
Even with LD off, it is still an LED lit set so it would not matter.
The reason for having LD off is the effect it would have when using window patterns. I now calibrate with LD on but use full screen patterns so LD never gets an opportunity to mess with the windowed patterns due to the adjacent dimmed areas. This seems to work well for me but rests on the unproven theory that an LD set should be calibrated with LD on.
U.S. Army FA WWII
post #224 of 7329 Old 02-08-2010, 07:59 AM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
I just looked at the SDK for the Chroma 5 and, yes, I had forgotten that the C5 includes the ability to load custom calibrations into the EEPROM. However, you would still need software support to call those calibrations. Without that they would be unused.
Tom Huffman
Springfield, MO
post #225 of 7329 Old 02-08-2010, 08:11 AM
rowland.johnson's Avatar
I'll try later with full screen patterns. But, with field patterns and local dimming on, what I've seen is that luminance INCREASES when a calibration subpanel (e.g. the Red adjustment for one of the IRE levels) is being displayed. The luminance decreases when the calibration subpanel is removed. Toggling local dimming on and off has no effect if there is no calibration subpanel.
rowland.johnson is offline
post #226 of 7329 Old 02-08-2010, 08:22 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Under typical circumstances window patterns are for plasma displays. Any device that can deliver full output should use fields or constant APL windows.
bodosom is offline
post #227 of 7329 Old 02-08-2010, 08:26 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Some displays are just annoying. That's one reason why people buy external video processors.
bodosom is offline
post #228 of 7329 Old 02-08-2010, 08:38 AM
Quoted: 371 Post(s)
Liked: 543
True that, Tom. I had thought that by "software", you meant an external table or file loaded by the program when the C5 was used.
...Royce...
post #229 of 7329 Old 02-08-2010, 09:17 AM
derekjsmith's Avatar
Liked: 116
Yes the Chroma5 has the ability to store 4 internal calibration tables. From the factory they only use two of them. In our calibrations lab we add support for LCD/LED and UHP lamped projectors. We called it the Enhanced Chroma5.
CalMAN has three types of calibration tables for the meter itself. Profiling where a user uses a reference and target meter to create a calibration matrix for a specific display. External for meters like the Spyder3, i1Pro and ColorMunki where they don't have the ability to store internal tables. The external tables are downloaded from our website on demand as needed. And finally internal for meters that have onboard storage of tables like the Chroma5, K-10 and Hubble.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #230 of 7329 Old 02-08-2010, 09:20 AM
Liked: 116
To be able to compare CalMAN and ChromaPure numbers you need to be using the same internal tables within the Chroma5 itself. So with CalMAN you need to select 'LCD Direct View' so both applications are using the same table. Otherwise you are comparing apples to oranges or in this case LCD' vs. LCD/LED'.
Derek
post #231 of 7329 Old 02-08-2010, 10:39 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
I had some concerns about this so I fiddled a bit. You also need to have CalMAN in the default state. There are options that will cause CalMAN and ChromaPure to engage in spirited debate.
bodosom is offline
post #232 of 7329 Old 02-08-2010, 10:52 AM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
For the record, I can think of no reason--so long as both are using the same modes for the Chroma 5--why the two programs would report different numbers for the same meter on the same display using the same test patterns.
They should be the same, within reasonable tolerances.
That is why I have asked p5browne to post calibration reports. I am particularly skeptical of some of the RGB values that were reported.
Tom Huffman
Springfield, MO
post #233 of 7329 Old 02-08-2010, 11:48 AM
Liked: 116
Agreed, both CalMAN and ChromaPure use the same XYZ/xyY numbers from the meter and then run various formulas on the raw meter data to display the xyY, RGB, DeltaE, etc... So those numbers should be very close if not the same.
Derek
post #234 of 7329 Old 02-08-2010, 11:57 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Just in case it wasn't clear, there are a lot of knobs on CalMAN. Some of those effect the presentation of data. If you can't readily compare the raw meter output you need to be sure the cooked numbers are subject to identical transforms. I think it's sufficient to use the defaults and select the same dE calculation.
bodosom is offline
post #235 of 7329 Old 02-08-2010, 01:38 PM
p5browne's Avatar
Liked: 2418
Being an old fart, will see what I can do in regards to last night's calibration report. I still much prefer the flatlined Green PQ (100IRE to 10IRE - set to Gamma 2.22 and the Reds and Blues left at Zero - despite the critics out there that I don't do things by the book) to either of the Calman (Yellow Tinge) and ChromaPure (Red Tinge) full calibrations. Trying to compare Green only between Calman and ChromaPure - Calman will calibrate the Green only - ChromaPure, you have to do the Complete individual calibration on every IRE from 100IRE down to 10IRE - won't let you do any individual IRE. You also have to do the startup part of 10IRE to 100IRE or it won't let you calibrate anything. With Calman I can do it any way I feel like. The Green settings were not even close to each other between Calman and ChromaPure.
Oh yeah now I remember my methods are Unorthodox! Guys, I'm just trying to get a full Calibration that looks great. I'll get on the reports tonight when I get home. It will be my New thing us seniors have to learn everyday!
p5browne is offline
post #236 of 7329 Old 02-08-2010, 01:58 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
Sorry, I really don't comprehend what you are trying to say here. Once you initialize the meter, you can begin with any module you like and calibrate whatever level of stimulus you like. For example, just open the White Balance module, display the desired level of stimulus, and then you can calibrate one level, multiple levels, or all of the levels. It is entirely up to you.
The Pre and Post-Calibration Grayscale modules are not for the calibration process at all--that is, changing values to meet targets. They are for reporting the initial state of the display and then the success of your efforts once the calibration is complete.
Tom Huffman
Springfield, MO
post #237 of 7329 Old 02-08-2010, 04:28 PM
p5browne's Avatar
Liked: 2418
Sorry, the Before is the After - BackLight 69 Contrast 90 Brightness 52 Colour 48 Tint 0 White Balance Warm Gamma Low BL Low
ChromaPure Calibration Report
Technician: ChromaPure User
Company: ChromaPure Video Calibration Software
Greyscale Before Greyscale After
% Stimulous X Y CCT dE % Stimulous X Y CCT dE
20 % 0.313 0.331 6,491 0.9 20 % 0.000 0.000 2,021 NaN
30 % 0.313 0.329 6,506 0.1 30 % 0.000 0.000 2,021 NaN
40 % 0.312 0.330 6,518 0.8 40 % 0.000 0.000 2,021 NaN
50 % 0.313 0.330 6,462 0.5 50 % 0.000 0.000 2,021 NaN
60 % 0.313 0.330 6,485 0.4 60 % 0.000 0.000 2,021 NaN
70 % 0.313 0.329 6,503 0.3 70 % 0.000 0.000 2,021 NaN
80 % 0.313 0.329 6,461 0.4 80 % 0.000 0.000 2,021 NaN
90 % 0.313 0.329 6,476 0.2 90 % 0.000 0.000 2,021 NaN
100 % 0.312 0.329 6,548 0.4 100 % 0.000 0.000 2,021 NaN
2/8/2010 7:11:27 PM Page 1 of 2
Color Gamut Before Color Gamut Before
Color X Y Yy Delta E Color X Y Yy Delta E
Red 0.000 0.000 0.000 NaN Red 0.000 0.000 0.000 NaN
Green 0.000 0.000 0.000 NaN Green 0.000 0.000 0.000 NaN
Blue 0.000 0.000 0.000 NaN Blue 0.000 0.000 0.000 NaN
Yellow 0.000 0.000 0.000 NaN Yellow 0.000 0.000 0.000 NaN
Cyan 0.000 0.000 0.000 NaN Cyan 0.000 0.000 0.000 NaN
Magenta 0.000 0.000 0.000 NaN Magenta 0.000 0.000 0.000 NaN
White 0.000 0.000 0.000 NaN White 0.000 0.000 0.000 NaN
2/8/2010 7:11:27 PM Page 2 of 2
Before gives the values with Red, green and Blue IREs set at Zero - The After Green Only Calibration
20 % 0.297 0.321 7,520 5.5 20 % 0.299 0.297 7,832 9.9
30 % 0.296 0.321 7,582 5.8 30 % 0.297 0.304 7,844 8.4
40 % 0.297 0.320 7,561 5.7 40 % 0.298 0.311 7,642 6.8
50 % 0.296 0.321 7,636 6.0 50 % 0.296 0.315 7,673 6.2
60 % 0.297 0.321 7,527 5.6 60 % 0.297 0.322 7,512 5.6
70 % 0.297 0.319 7,564 5.7 70 % 0.297 0.323 7,475 5.5
80 % 0.297 0.317 7,585 5.8 80 % 0.297 0.325 7,473 5.8
90 % 0.299 0.317 7,450 5.5 90 % 0.299 0.330 7,258 5.9
100 % 0.302 0.319 7,261 4.8 100 % 0.302 0.330 7,087 5.1
p5browne is offline
post #238 of 7329 Old 02-08-2010, 07:36 PM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
I am still not sure what this data refers to. You have posted two sets of grayscale data. The first set has one grayscale run and a bunch of zeros. The second set has two grayscale runs--I assume that this is Before/After or After/Before.
Stimulus x y R G B CIE94
20 0.313 0.331 99% 100% 99% 1.2
30 0.313 0.329 100% 100% 100% 0.2
40 0.312 0.330 99% 100% 100% 0.9
50 0.313 0.330 100% 100% 99% 0.6
60 0.313 0.330 100% 100% 99% 0.6
70 0.313 0.329 100% 100% 100% 0.2
80 0.313 0.329 100% 100% 100% 0.2
90 0.313 0.329 100% 100% 100% 0.2
100 0.312 0.329 99% 100% 100% 0.4
% Stimulus x y R G B CIE94 x y R G B CIE94
20 0.297 0.321 87% 103% 111% 7.5 0.299 0.297 105% 96% 129% 18.2
30 0.296 0.321 86% 103% 111% 8.0 0.297 0.304 97% 98% 124% 13.6
40 0.297 0.320 87% 103% 111% 7.5 0.298 0.311 94% 100% 118% 9.9
50 0.296 0.321 86% 103% 111% 8.0 0.296 0.315 89% 102% 115% 8.8
60 0.297 0.321 87% 103% 111% 7.5 0.297 0.322 86% 103% 110% 7.5
70 0.297 0.319 88% 102% 112% 7.6 0.297 0.323 86% 103% 109% 7.6
80 0.297 0.317 89% 102% 114% 7.9 0.297 0.325 84% 104% 108% 7.9
90 0.299 0.317 92% 101% 113% 7.3 0.299 0.330 84% 104% 103% 8.2
100 0.302 0.319 94% 101% 110% 5.9 0.302 0.330 87% 104% 103% 6.5
Other than some change on the low end, the second set of data shows very little change between the two grayscale runs. They both show too much blue and too little red. The first single set is as close to perfect as a grayscale run is going to get.
Not sure what conclusions, if any, should be drawn from this.
Tom Huffman
Springfield, MO
post #239 of 7329 Old 02-08-2010, 08:00 PM
p5browne's Avatar
Liked: 2418
The second set of tables were to show the Before, what the system looked like with with all IREs and and CMS Zeroed that was missing in the first table.
I know the results look A-OK, but, I've ended the exact same with the Calman calibration as well. I'm just trying to figure out why, when nothing has changed, my PQ is Red tinged with ChromaPure and Yellow with Calman? But the values all point to the ideal PQ? Will have to find what setting is affecting both calibration final out comes.
p5browne is offline
post #240 of 7329 Old 02-08-2010, 10:13 PM
Liked: 116
Because you are using two different calibration tables within the Chroma5, you will get two different results. Within CalMAN use the LCD Direct View display type and you will get the same results as ChromaPure.
Derek
Reply Display Calibration
