The Official ChromaPure thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 256Likes
Old 05-14-2012, 05:47 PM
lbosley's Avatar
Tom,
I have also seen these errors when using the 75% gamut ACM measurements. I e-mailed this info to you a couple of weeks ago. The error pops up but allows you to continue to the next reading. The graph may not update until all of the readings are completed, but the measurements do seem to function properly.
lbosley is offline
Old 05-14-2012, 07:22 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Right now, download the latest build. Uninstall CP. Reinstall using what you just downloaded. Try the 75% of Rec. 709 Gamut.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Old 05-15-2012, 08:55 AM
kjgarrison's Avatar
My D3 Pro arrived with the Certificate of Calibration, but only xy corrections are included. I was expecting to see Y correction also.
Don't I need to know all xyY corrections to figure out how to use this OEM probe with other software? And speaking of doing just that, can somebody provide a link or search term about how to use these corrections to create an XYZ correction table?
kjgarrison is offline
Old 05-15-2012, 08:57 AM
PlasmaPZ80U's Avatar
Quoted: 1987 Post(s)
Liked: 568
there are no Y corrections made
and while an XYZ correction table is used, it is not provided in the certificate
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 05-15-2012, 09:39 AM
kjgarrison's Avatar
So are you saying the corrections info is of no value or use?
Old 05-15-2012, 10:38 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
This probe--in fact, virtually all well-designed colorimeters--does not require and would not benefit from a Y correction. Its luminance readings are quite accurate to begin with. Color accuracy is where tristimulus meters need help.
Tom Huffman
Springfield, MO
Old 05-15-2012, 10:54 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Actually, we use xyz.
http://www.chromapure.com/FourColorCorrection.pdf
Tom Huffman
Springfield, MO
Old 05-15-2012, 10:57 AM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
It is for informational purposes only to document that the work has been done and to provide an idea of how large the corrections were.
Tom Huffman
Springfield, MO
Old 05-15-2012, 11:50 AM
Liked: 568
I'm curious, what's the difference? My profile matrix looks like this.
Old 05-15-2012, 12:01 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
XYZ and xyz are different ways to characterize the 1931 color space. xyz does not include luminance data.
Tom Huffman
Springfield, MO
Old 05-15-2012, 12:08 PM
Liked: 568
Interesting.
Based on my profile in CalMAN, that software package does include luminance data when profiling. I guess this explains why peak white is 2 fL higher with my profile vs. using the tables only. Gamma is unchanged.
Old 05-15-2012, 12:10 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
So you're saying they ship with perfect filters that physically match the Y curve of the CIE 1931 colormatching function?
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 05-15-2012, 12:44 PM
robobob's Avatar
Besides trying to engage Tom in technical arguments to validate the technical chops implied in your sig., why exactly are you participating in this thread for a competitor's product?
Do you actually own a copy of Chromapure, perhaps in order to gauge your competition? Or maybe you found the Chromapure calibration workflow to be more intuitive and productive than Calman's?
=>><<=robobob
robobob is offline
Old 05-15-2012, 12:57 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
I had a customer inquire about how to import their chromapure profile so I thought I'd try to brush up on how things worked on the other side of the fence.
Joel Barsotti
SpectraCal
sotti is offline
Old 05-15-2012, 01:24 PM
flint350's Avatar
Liked: 38
I reported this error earlier and I went back and re-downloaded CP (although the date of the file still shows early April - 2nd, if I recall) and even "repaired" NET 4. I still get the error in the 75% gamut. I followed the instructions for download repair in the order you originally gave me. I went ahead and performed a cal using 100% and no issues, 75% still errors but allows you to continue. Is it possible I am using an old link location, or are they updated and overwritten in the same url as the old one?
Ray
"You cannot reason a person out of a position he did not reason himself into in the first place." -Jonathan Swift
flint350 is offline
Old 05-15-2012, 02:01 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
I also have this error but I do not worry about safely use a program - it also works well what more could you want?
anta1974 is offline
Old 05-15-2012, 02:06 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
The latest build has a file date of 5/7/2012. The link is
http://www.chromapure.com/distribute...chromapure.zip
If you are installing an early April build, you are installing an older version where this problem did exist.
Tom Huffman
Springfield, MO
Old 05-15-2012, 02:11 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Thank you!
anta1974 is offline
Old 05-15-2012, 04:44 PM
flint350's Avatar
Liked: 38
No, the build date I have shows 5/7 as you state. I was referring to the date shown during the install of features that still has April 2 listed. I re-confirmed this with the current link you gave (which was the one I was already using). I guess this problem just exists on some systems and not others. I've only tried it on my laptop, so maybe I'll try the desktop as well and see if it repeats.
Ray
flint350 is offline
Old 05-15-2012, 04:53 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
I have tested this every way I know how, and it works fine here. So there's something mysterious going on that I am as of yet unable to diagnose.
http://www.chromapure.com/bugtest/75...75percent.html
Tom Huffman
Springfield, MO
Old 05-15-2012, 07:15 PM
flint350's Avatar
Liked: 38
Well, I just tried it on my desktop computer and got the same error message. I don't know what else to try. It's not that big a deal, since 100% works fine and I was just trying 75%. If it would help you in any way Tom, I can send the rest of the error message to you with all the module info, beyond what is on the main error window = "object reference not set to an instance of an object".
Ray
flint350 is offline
Old 05-15-2012, 10:30 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Copy and paste the details of the message and send it to me via e-mail.
Tom Huffman
Springfield, MO
Old 05-16-2012, 08:27 AM
flint350's Avatar
Liked: 38
Sent as requested. I used the support/incident page on Chromapure.
Ray
flint350 is offline
Old 05-16-2012, 09:30 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Tom! Why in matrix correction not Y correction also?
I have Spyder 4 and Colormunki Design.
With new CP mistake in 75% color management remained.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ChromaPure.Controls.Calibration.ColorManagementControl.Color RadioButton_CheckedChanged1(Object sender, EventArgs e)
at System.Windows.Forms.RadioButton.OnCheckedChanged(EventArgs e)
at System.Windows.Forms.RadioButton.set_Checked(Boolean value)
at System.Windows.Forms.RadioButton.OnClick(EventArgs e)
at System.Windows.Forms.RadioButton.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Mes sage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ChromaPure
Assembly Version: 2.2.13.40789
Win32 Version: 2.2.13.0
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/ChromaPure.exe
Win32 Version: 4.0.30319.269 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.276 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CpColorScience
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpColorScience.DLL
CpL
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpL.DLL
CpHw
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpHw.DLL
PresentationCore
Win32 Version: 4.0.30319.275 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
CpSettings
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpSettings.DLL
System.Management
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
WindowsFormsIntegration
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
PresentationFramework.Classic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll
CpIO
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpIO.DLL
CpSession
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpSession.DLL
System.Xml
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
rk3a4xux
System.Deployment
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
CpControlLib
CodeBase: file:///C:/Program%20Files/Display%20Calibrations%20LLC/ChromaPure/CpControlLib.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Data
Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
kj4hly0e
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
anta1974 is offline
Old 05-16-2012, 12:21 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
What I am saying is that I have tested several colorimeters, some very inexpensive, against a reference source and seen negligible differences in reported luminance. For example,
http://www.avsforum.com/avs-vb/showp...1&postcount=17
This reports absolute luminance. When you look at relative luminance, which is much more important for calibration, the differences are even smaller--in fact, virtually zero.
If I see any empirical data suggesting that a properly functioning colorimeter requires luminance correction, then we'll provide it. I haven't seen any yet.
Tom Huffman
Springfield, MO
Old 05-16-2012, 12:28 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
http://www.avsforum.com/avs-vb/showp...postcount=2527
http://www.avsforum.com/avs-vb/showp...postcount=2546
Since this occurs for some and not for others, this must be caused by some details in configuration. Send me your configuration file
C:\\ProgramData\\Display Calibrations LLC\\ChromaPure\\2\\ChromaPure.config
and I can investigate further.
Tom Huffman
Springfield, MO
Old 05-16-2012, 12:33 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Interesting.
This is just what you would expect. Gamma, dE color calculations, and contrast calculations all use relative luminance (grayscale doesn't use luminance at all). None of these would be affected by a Y correction. The only thing affected is absolute luminance, and this is used only for measurement of peak output and absolute black level, at least that's all I can think of that it would be used for.
Tom Huffman
Springfield, MO
Old 05-16-2012, 12:37 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
This reports absolute luminance. When you look at relative luminance, which is much more important for calibration, the differences are even smaller.
Hi Tom,
I consistently see a 3.3% offset in Y at all luminance levels between my new D3(uncorrected and in refresh mode) and my i1pro 2. Would you recommend scaling Y on the i1pro 2 to the D3 or vice versa?
zoyd is offline
Old 05-16-2012, 12:56 PM
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Excellent question. The D3 is almost certainly the more accurate in reading luminance.
Tom Huffman
Springfield, MO
Old 05-16-2012, 01:27 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
My file
ChromaPureconfig.zip 1.287109375k . file
anta1974 is offline
