THX Optimizer and picture/contrast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-06-2009, 10:43 PM - Thread Starter
dark scorpio's Avatar
on somebodys advice, i decided to throw in one of my daughters Pixar dvd's for the test. well it starts out with the calibration for contrast. ok so heres where im confused: i turned the contrast all the way up and could still see all four shades distinctly. i thought if it was too high youd just see all white. am i wrong?????
secondary dumb question: ok just in case i did it wrong, you dont adjust the picture when it shows the little white box up in the corner right? I did it when i clicked on "Play Test" and the big image of the shades of white were displayed. just makin sure
I want to shoot my TV
dark scorpio is offline
post #2 of 11 Old 09-06-2009, 11:36 PM
cavu's Avatar
You probably have some 'magic' automatic mode engaged on your TV set which makes such settings almost impossible.
What is the model number of your TV?
You did it properly.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 11 Old 09-06-2009, 11:48 PM - Thread Starter
magic?
im not on an HDTV (forgot to mention that if it matters)
its a Sony FD Trinitron Wega: KV-32FS120
post #4 of 11 Old 09-07-2009, 02:48 AM
cavu's Avatar
magic?
Page 22 of the TV manual says there is a "Vivid" video mode.
That setting should probably be set to "Movie".
Then try your calibration again.
You might also want to set the Color Temp to "Warm"and turn the "Clear Edge VM" to "OFF.
Without being there or having that set, these are best guesses.
" - MLK
cavu is offline
post #5 of 11 Old 09-07-2009, 05:24 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Contrast test on THX disc does not apply to CRT displays. You need a light meter for a CRT. 30 fL is the goal based on a 100% white window box pattern.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #6 of 11 Old 09-07-2009, 03:14 PM - Thread Starter
i dont use the vivid mode. i am on standard mode but i could try testing out movie. i have already turned off the VM. I have color temp set to off. What is the advantage to setting it to warm?
post #7 of 11 Old 09-07-2009, 04:28 PM
cavu's Avatar
"Warm" is usually closest to the D65 standard color temperature.
" - MLK
cavu is offline
post #8 of 11 Old 09-08-2009, 06:59 AM - Thread Starter
Originally Posted by Michael TLV View Post
Greetings
regards
light meter????
oh and does this also mean that the brightness test wasnt accurate?
post #9 of 11 Old 09-08-2009, 10:43 PM
Quoted: 40 Post(s)
Liked: 142
Greetings
The brightness test is fine with the drop shadow. The contrast test is designed for digital displays.
regards
post #10 of 11 Old 09-09-2009, 08:13 AM - Thread Starter
it just seems odd that the test is only for hdtv's but has been around since Toy Story 1 & 2, back when nobody had an hdtv.
post #11 of 11 Old 09-09-2009, 08:32 AM
Lee Gallagher's Avatar
You can see where not to set your contrast with the THX contrast pattern on a CRT. However, it isn't the ideal pattern to set contrast on these types of displays. If you see any blooming (the boxes become larger) then your contrast control is set too high.
Also remember that contrast and brightness are interactive. If you adjust one, be sure to check and re-adjust the other, if necessary.
Lee Gallagher
Imaging Science Professional
THX Certified Professional
Advanced Audio Visual
www.advancedaudiovisual.tv
Lee Gallagher is offline
Reply Display Calibration
