Need help saving settings for sony KDL 32M3000 service menu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-19-2009, 03:09 PM - Thread Starter
Highlen's Avatar
I was just checking around with ther service settings but knowing my stupidity, I wrote down default numbers just in case for ITU 709, ITU 601, and VGA, I hit auto calibration by mistake and just need to know how to save the values I know what they are just need the remote code to save them.
thanks in advance for the help
Highlen is offline
post #2 of 2 Old 09-19-2009, 04:16 PM
lcaillo's Avatar
I doubt that it changed anything as these sets are not supposed to have anything that you can change in the service menu. You can restore the factory settings by pressing the center button in the ring twice.
Yes, calibration is important...every user should be calibrated.
Need electronics repair? A great place to start looking for a shop in your area: http://www.tvrepairpros.com/
lcaillo is offline
Reply Display Calibration
