A Question for the Pros about my TV being serviced - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-10-2009, 08:27 AM - Thread Starter
sperron's Avatar
I have a 70 XBR2 SXRD that is going to be serviced for the "yellow stain" problem. I previously calibrated my TV and am wondering if I should "center" the settings for things like the color decoder, gamma controls and color temperature before the tech replaces the light engine. What I don't want to have happen is being unable to calibrate the new light engine because the setting range is not large enough set it correctly. As it is now, the red tint control on my TV falls at the 0 setting of the range and actually ends up in just about the right spot. I don't want to need a setting below 0 for it, because obviously it would be impossible to do that.
Also, do you have any tips or recommendations about having my TV serviced? I am not sure what exactly will be involved with replacing the light engine.
sperron is offline
post #2 of 4 Old 11-10-2009, 12:27 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 143
Greetings
let the repairman do his job. don't try to monday morning quarterback this.
things will be messed up ... the tv will need to be recalibrated.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 4 Old 11-11-2009, 06:55 AM - Thread Starter
sperron's Avatar
I have no intention of interfering. I was merely concerned about whether service menu controls used for calibration that are currently near one of their end points should be moved further towards the center of their range, whether the new light engine will line up with the settings currently in use without a problem or whether the tech factory resets them anyway and it's a non issue.
sperron is offline
post #4 of 4 Old 11-11-2009, 09:25 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Just put all the controls back where they were before you calibrated it and let the service happen.
You are going to have to recalibrate anyway, so it doesn't matter that you are going to "lose" your existing calibration before the service.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Reply Display Calibration
