ColorMunki - How Good or How Bad? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 252 Old 01-11-2010, 06:49 AM - Thread Starter
jimwhite's Avatar
Amazon has the ColorMunki Photo for $295 after $50 MIR. Sounds like a great price, but I'm interested in comments from anyone who has used one, especially the CalMan guys (Derek ?) since I'll be using CalMan Enthusiast.
Jim White
St. Petersburg, FL
jimwhite is offline
post #2 of 252 Old 01-11-2010, 07:29 AM
derekjsmith's Avatar
Liked: 116
Well the ColorMunki Photo/Design is a Spectrophotometer so that in itself is a plus. It is also designed by the same guys that do the i1Pro. All of its accessories are built in like the dark offset, ambient diffuser, just turn the dial to the mode you want. The downside currently is the ColorMunki does not have a tripod mount we are working on a design.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #3 of 252 Old 01-11-2010, 10:58 AM
ev666il's Avatar
How does it compare to the i1 Pro? Any notable differences in accuracy?
ev666il is offline
post #4 of 252 Old 01-11-2010, 11:19 AM
kokap's Avatar
ColorMunki Photo/Design spectral range in the emission mode (display/projector calibration): 400-700 nm.
i1Pro: 380-730.
I've compared the ColorMunki Photo and the i1Pro for several CCFL displays (with standard and wide gamut): max dE00=1.24, avr dE00=0,71
kokap is offline
post #5 of 252 Old 01-11-2010, 12:40 PM
ev666il's Avatar
ev666il is offline
post #6 of 252 Old 01-11-2010, 01:46 PM
PlasmaPZ80U's Avatar
Quoted: 2289 Post(s)
Liked: 705
Does it work with ColorHCFR?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #7 of 252 Old 01-11-2010, 01:59 PM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Could you provide some more detail about your comparisons?
Were those numbers supposed to be 1.24 and 0.71 (i.e. 1,24 and 0,71) or do I completely misunderstand?
bodosom is offline
post #8 of 252 Old 01-11-2010, 06:41 PM
kokap's Avatar
OK.
I have tested my i1Pro, ColorMunki Photo and Spyder3Elite on several computer monitors: NEC LCD2490WUXi2 (standard gamut) and NEC LCD2690WUXi2 (wide gamut).
See the table below represented one test (with the worst results).
P.S. My Spyder3 is very inaccurate for wide gamut displays.
kokap is offline
post #9 of 252 Old 01-11-2010, 06:43 PM
turbe's Avatar
Liked: 97
not supported
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #10 of 252 Old 01-11-2010, 08:18 PM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
OK.
Those numbers look promising. Particularly after you discard 0.
bodosom is offline
post #11 of 252 Old 01-12-2010, 07:27 AM
glaufman's Avatar
CAn it be re-certified?
What's the resolution?
-Greg
glaufman is offline
post #12 of 252 Old 01-12-2010, 08:49 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
The ColorMunki is designed to be both re-certification and repair free (they only seem to be concerned about lamp drift which the CM should resist). They do not come with a calibration certificate.
I've seen the specs somewhere at X-Rite but at the moment all I can find is this at SpectraCal.
bodosom is offline
post #13 of 252 Old 01-12-2010, 09:55 AM
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
You aren't kidding. The Spyder is a mess, especially for white, yellow, and cyan. Those are huge errors.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #14 of 252 Old 01-12-2010, 10:07 AM
turbe's Avatar
Liked: 97
Unlike the I1 Pro, the ColorMunki's do not come with a NIST certificate as bodosom as posted. However, SpectraCal will re-certify the ColorMunki's for $175 (less at Calibration Forums).
Meter Recertification does not mean the meter is repaired if needed (most cases, it would be cheaper to buy a new one if repair is needed).
ControlCAL™
turbe is offline
post #15 of 252 Old 01-12-2010, 10:21 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
In this case what would that mean?
bodosom is offline
post #16 of 252 Old 01-12-2010, 10:31 AM
turbe's Avatar
Liked: 97
They check it's accuracy using their CS-2000 on the reference displays in their lab and provide a certificate (and the tables for CalMAN).
This is the same thing X-Rite does with the I1 Pro's (minues the tables). If the meter isn't/can't get into spec, repair is needed at an extra cost.
EDIT: See: http://www.avsforum.com/avs-vb/showt...7#post17965727
ControlCAL™
turbe is offline
post #17 of 252 Old 01-12-2010, 10:56 AM
kokap's Avatar
Offtopic:
Yes, my Spyder is very inaccurate. My i1Display 2 is much better, but it isn't superb for wide gamut monitors as well.
But I am not astonished with these facts: maybe you have read http://lists.apple.com/archives/colo.../msg00175.html
P.S. J.Raimar Kuhnen-Burger is a well-known Color Science specialist.
kokap is offline
post #18 of 252 Old 01-14-2010, 05:23 AM
heckheck's Avatar
Sounds like a pretty good endorsement given the cost of the ColorMunki vs the i1Pro. A question, however, there is another thread http://www.avsforum.com/avs-vb/showt...php?p=17190865, which talks about the UV filter in the ColorMunki being a problem for CalMAN. Is that filter a problem? Is it used when the device is in projector mode?
Also, will either version of the ColorMunki work with the CalMAN software, I'm interested in getting the Design version (instead of the photo), since it comes with the Pantone information, which I would find useful in my artwork. The specs look very similar.
Will you be offering a home version of the CalMAN software for the same standalone price (I don't see ColorMunki listed)..
CalMAN Home Edition - Software Only
For Spyder2, Spyder3, EyeOne Display2, DisplayLT, DTP-94, ColorPro II.
3v100
Also, when can we expect V4 of the software to be available, and would people purchasing V3 now get an upgrade or would we have to pay more? The Amazon price of the ColorMunki + the standalone software price has my trigger finger itchy.
-Jim
heckheck is offline
post #19 of 252 Old 01-14-2010, 06:12 AM
bodosom's Avatar
Quoted: 221 Post(s)
Liked: 72
Originally Posted by heckheck View Post
... UV filter in the ColorMunki being a problem for CalMAN. Is that filter a problem?
Since SpectraCal is selling the CM we can presume there's no problem. I don't know if that's because, as noted, the filter is for the lamp (LEDs in a CM) or if something has happened in the intervening months.
The two packages contain the same device. One's white the other is black. The current build of CalMAN 3 supports the CM.
People are talking about Spring.
bodosom is offline
post #20 of 252 Old 01-14-2010, 06:25 AM
turbe's Avatar
Liked: 97
3v100
CalMAN for the EyeOne Pro - Software Only (now CalMAN Home Spectrophotometer) will work with the I1 Pro and/or ColorMunki Spectrophotometers.
ControlCAL™
turbe is offline
post #21 of 252 Old 01-14-2010, 01:17 PM
kal
kal's Avatar
Quoted: 20 Post(s)
Liked: 77
CalMAN 4 is expected to beta in Feb 2010 and then released in March 2010.
The upgrade policy is: Free upgrades for one year from time of purchase. So anyone purchasing CalMAN 3.x today will automatically get a free upgrade to version 4.
Kal
kal is offline
post #22 of 252 Old 01-15-2010, 06:47 AM
spinmar's Avatar
To calibrate professional plasma (kuro or panasonic vx100), do you suggest i1pro or CM?
spinmar is offline
post #23 of 252 Old 01-15-2010, 09:13 AM
kal
kal's Avatar
Quoted: 20 Post(s)
Liked: 77
I suggest you read me FAQ "Which meter is right for me?" and decide for yourself as there are pros and cons to each. There's no "right" answer.
I'm not sure either what you mean by "professional" plasma. The ones you mention are consumer brand types.
Kal
kal is offline
post #24 of 252 Old 01-15-2010, 12:54 PM
turbe's Avatar
Liked: 97
D-Nice will be testing the ColorMunki (compared to the I1 Pros) on his 9G Kuros and the results will be posted.
ControlCAL™
turbe is offline
post #25 of 252 Old 01-15-2010, 05:16 PM
SteveMo's Avatar
I temporarily disabled my user account in Vista X64 and attempted an installation and got an error message.
Microsoft .NET Framework 3.5 SP1 Setup
Setup Error
An error has occurred during setup. Installed files have been removed from your computer. For known issues and troubleshooting information, see the online Readme. For error information, see Error Log.
It will be a two hour drive to get the required internet connection.
SteveMo is offline
post #26 of 252 Old 01-15-2010, 09:42 PM
SteveMo's Avatar
I tried everything including to disable the NET Framework in services.
Fingers crossed.
Looks good right about now.
SteveMo is offline
post #27 of 252 Old 01-15-2010, 09:47 PM
SteveMo's Avatar
I still get the same error with the full install.
SteveMo is offline
post #28 of 252 Old 01-16-2010, 01:27 AM
SteveMo's Avatar
After some fighting with Windows update (for which NET framework would also not install) I was able to get it recognized by CalMAN 2.62 for a short period after a rollback of the NET Framework install, but it stated that the meter was not registered. I did a system restore then reinstalled instead everything and CalMan will not recognize the meter. I tried each of the meter positions thinking that might help and used the refresh but there was still no change. I decided to try the included software was does seem to work. In about 5 minutes I had created a profile for my laptop and color seems to look closer to my LED backlit monitor which will also get calibrated. I'll try also setting a profile for the projector (laptop is the HTPC) and see what that is like and give my impressions. I would like to see it working in CalMAN so I could have some verifiable results but it looks like that may have to wait.
SteveMo is offline
post #29 of 252 Old 01-16-2010, 02:58 AM
spinmar's Avatar
Well done
Could you post the results or where we can find them?
spinmar is offline
post #30 of 252 Old 01-16-2010, 02:59 AM
spinmar's Avatar
Kal
Vx100 is not consumer but business professional monitor....
Please see panasonic web site....
spinmar is offline
Reply Display Calibration
