ChromaPure v. CalMan - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 233 Old 07-08-2010, 11:20 AM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
Originally Posted by Bob Sorel View Post
Just as an update, as I promised, both of the 2 new USB to RS-232 adapters that I bought (the Sabrent FTDI and Keyspan USA-19HS work absolutely fine with all programs...
So to sum up, here are the results:
Accucal i1 Pro DCS - Works with PCM-CIA, Sabrent Prolific, Sabrent FTDI, and Keyspan adapters.
ChromaPure - Works with PCM-CIA, Sabrent Prolific, Sabrent FTDI, and Keyspan adapters.
CalMAN 4.0 RC4 - Works with Sabrent FTDI and Keyspan adapters, works sometimes with PCM-CIA, and never works with Sabrent Prolific.
Hopefully this weekend I will finally be able to set up a user preset on my RS-35 using CalMAN. When I am done I hope to post a detailed comparison between the two pieces of software.
Edit: Fixed typo
Why bother to compare? I do not sell that software today and my current software uses a completely different method for RS-232 communication along with other feature changes.
umr is offline
post #212 of 233 Old 07-08-2010, 12:49 PM
scooper750's Avatar
I wouldn't say that Prolific NEVER works with Calman V4. I'm actually using a sabrent Prolific right now to connect my VP403C and haven't had problems with it (or not yet at least).....
Edit: Fixed typo
Stephen Cooper
THX Certified Video Calibrator
Digital Video Calibrations LLC
scooper750 is offline
post #213 of 233 Old 07-08-2010, 01:33 PM
turbe's Avatar
Liked: 95
They key is which Prolific chipset is used and with what driver.. this applies to FTDI and TI as well.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #214 of 233 Old 07-08-2010, 01:41 PM
Super Moderator
Bob Sorel's Avatar
Quoted: 73 Post(s)
Liked: 126
Jeff, I was merely pointing out that 2 of the 3 software packages I have used had no issues whatsoever with ANY of the RS-232 adapters...only CalMAN seems to be finicky.
Ok, well that is more input. I could not get the particular Sabrent Prolific that I own to work even once with CalMAN 4, and I tried plenty of times on 2 different computers running 2 different OS's. YMMV.
Bob Sorel is offline
post #215 of 233 Old 04-03-2011, 05:51 AM
pers1's Avatar
Originally Posted by TomHuffman View Post
Not the standard Chroma 5s. It's the Chroma 5 PRO option that you refer to.
The reference meter is an Orb Optronics SP-100.
I use several displays:
  • 2 Sony LCDs, one CCFL and one LED
  • 2 Samsung LCDs, one CCFL and one LED
  • The generic LCD is just an average of the Sonys and Samsungs
  • 1 Sony CRT
  • 1 Pioneer plasma
  • 1 off-screen measurement from a Stewart StudioTek using a Sharp front projector with a UHP bulb.
Hey Tom
is it possible to get the 5 Pro optimized to my D-ILA projector, The JVC X7
I would like to buy the bundle but the List contains nothing I need and is not
even in the same picture / color bulb range.
PerS
pers1 is offline
post #216 of 233 Old 04-04-2011, 12:33 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Originally Posted by pers1 View Post
is it possible to get the 5 Pro optimized to my D-ILA projector, The JVC X7 I would like to buy the bundle but the List contains nothing I need and is not even in the same picture / color bulb range.
There is nothing about the JVC projectors that require a special meter calibration. They also use UHP bulbs.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #217 of 233 Old 04-04-2011, 07:44 AM
pers1's Avatar
Thanks, when do u think that the Autofeature with iscan Duo is comming
PerS
pers1 is offline
post #218 of 233 Old 08-14-2011, 11:34 PM
sellmejunk's Avatar
I need some advice.
I have a videoEq Pro, & looking at either calman or chrompure software.
Is Calman 4 is better suited for videoEQ or is chromapure standard a better choice or just as capable. I want to calibrate my projector. Ideally Chromapure would be my choice, but i may encounter some bugs? problems when used with videoEq pro.
If i was to use chromapure to gather the calibration results, how easy would it be to manually adjust VeqLutbuilder or VideoEq control. (i.e missing fields if any)
I realize calman4 has the autocalibrate feature so would be the main reason to get it for use with VideoEq Pro, but how accurate is the auto calibration in calman4 and how is each software limited to perhaps 11 points? when the the videoEq pro can do upto 1024 points, meaning manually inputting maybe the only choice pehaps. dunno.
sellmejunk is offline
post #219 of 233 Old 08-14-2011, 11:56 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The VEQ can be set to 11 or 21 point in CalMAN.
We support any gamma target you would want for it and we support you setting any level of accuracy.
So you can say I want a DE of less than 1, and if your display + the VEQ can do it, CalMAN will do it.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #220 of 233 Old 08-24-2011, 06:02 AM
Quoted: 1393 Post(s)
Liked: 587
sotti
Does the ChromaPure plus license allow me to use the Display 3 Pro colormeter to develop a correction file on my i1 Display (predates the i1Display2 but same design) and use the i1 Display on this same license or do I have to pay for an additional meter license?
JimP is offline
post #221 of 233 Old 08-24-2011, 07:47 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Originally Posted by JimP View Post
sotti
I can't speak for ChromaPure, but CalMAN doesn't restrict the use of the meter profiler. As long as you have a license to use both meters you can profile them.
Joel Barsotti
SpectraCal
sotti is offline
post #222 of 233 Old 08-24-2011, 07:55 AM
Liked: 587
sotti....sorry guy, keep getting the two softwares confused.
Maybe Tom can answer.
JimP is offline
post #223 of 233 Old 08-24-2011, 11:44 AM
samhain1's Avatar
If as a user you bought an oem i1 Display 3 for use with Chromapure (I know their software is only activated when you enter the serial number). However, if I was to suggest that you wanted the best of both worlds and had the ability to have a Chrompure licence and a Calman licence, would the oem i1 Display 3 be able to be used for Calman calibration as well as Chromapure.
I don't see the sense in having to buy two meters but I know that the i1 Display 3 has different restrictions but only retail versions not the oem one.
Stu
samhain1 is offline
post #224 of 233 Old 08-24-2011, 11:59 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
A standard i1 Display Pro III can be used with either program.
The Meter Correction feature is available to all users of ChromaPure.
Tom Huffman
Springfield, MO
post #225 of 233 Old 08-24-2011, 12:32 PM
samhain1's Avatar
Thanks Tom, I will contact Ricky in the uk
Cheers
Stu
samhain1 is offline
post #226 of 233 Old 08-26-2011, 03:46 PM
catmother's Avatar
Would you care to comment on this issue:
http://www.avsforum.com/avs-vb/showp...postcount=2727
http://www.avsforum.com/avs-vb/showp...postcount=2728
Certified HDTV junkie and AVS addict
U.S. Army FA WWII
catmother is offline
post #227 of 233 Old 08-26-2011, 05:45 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Originally Posted by catmother View Post
It's not officially supported.
It's not officially licensed that way.
We reserve the right to restrict autocal to the specific devices that are licensed by the PC-addon or Panasonic dealer add-on. But currently any of the add-ons that enable autocal do so for the entire application.
Joel Barsotti
SpectraCal
sotti is offline
post #228 of 233 Old 08-27-2011, 08:09 AM
catmother's Avatar
Thanks, but still not entirely clear to me
I have the home license with a Chroma 5 and DPT94 and the interactive and PC add on.
Your post implies that the PC add on enables auto-cal capability in the Duo workflow, correct.
Does this also affect other workflows like 'interactive' ?
Your comment here implies that that is the case.
U.S. Army FA WWII
post #229 of 233 Old 08-27-2011, 12:00 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Correct once license enables autocal it's available in any workflow.
Joel Barsotti
SpectraCal
sotti is offline
post #230 of 233 Old 08-27-2011, 09:44 PM
rachmat-d's Avatar
Sotti,
I have calman Enthusiast( Radiance with interactive ). if i buy the calpc , the autocal will be availiable to radiance workflow ?
So i can have the auto cal ( with one button ) for grayscale and color , not just interactive?
If i install the calpc on my notebook and later i decide to use the calpc for my HTPC , is it possible ?
rachmat-d is offline
post #231 of 233 Old 08-27-2011, 09:52 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
CalPC is a great product and works very well for HTPCs.
I can't recommend buying the CalPC add-on to enable autocal for a radiance. In the future we may plug the hole in the licensing format, so the CalPC add-on only enables autocal for the PC client as intended.
Joel Barsotti
SpectraCal
sotti is offline
post #232 of 233 Old 08-27-2011, 10:10 PM
rachmat-d's Avatar
Thanks for the thought.
About the Laptop and HTPC, is it possible later on to change the pc that are using the CALPC ?
I am planning to use the laptop until i familiar, and then after that i will move to my HTPC permanently.
post #233 of 233 Old 08-27-2011, 11:01 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Honestly I'm not entirely sure what additional clients cost. I do know they are available, but when you unlock the client on a machine it is locked to that machine.
Joel Barsotti
SpectraCal
sotti is offline
Reply Display Calibration
