Projector color 62-100, no difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-13-2010, 09:42 AM - Thread Starter
lars.egarots's Avatar
I ran the TXH Optimizer with my HD20 projector. When using the blue glasses, once the color gets up to about 62, then I see no change in the letters of COLOR between settings 62 - 100. Is this normal? Should I use 62 or 100?
(Tint seems normal - it's dialed in at 47, so the letters in TINT are the same, but aren't in 46 in 48.)
lars.egarots is offline
Reply Display Calibration
