Excel dE calculator for 10-pt grayscale? - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2010, 07:42 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Is there an excel calculator for grayscale that allows input of 10-pt grayscale xyY data and then returns dE's in various formulas (CIELUV, CIELAB, and CIE94)? I'd like to be able to calculate CIELAB and CIE94 dE's for grayscale data from ColorHCFR (xyY) without having to do one point at a time.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 02-15-2010, 05:18 AM
thomasl's Avatar
Tom H's spreadsheet attached to the end of his Basic Guide has this for 20%-100% white readings. I assume he left out 10% because for most folks readings at that level are not going to be considered reliable/accurate.
cheers,
--tom
thomasl is offline
Old 02-15-2010, 10:07 AM - Thread Starter
Liked: 562
Thanks, I was able to get CIELUV and CIELAB to work, but for some % stimulus values of CIE94, I got the #### (#NUM!) message. Not sure how to fix it, especially since the worksheet is protected. 20, 30, 40, 70, and 80 show this error message, while the remaining ones worked fine.
Old 02-15-2010, 10:49 AM
thomasl's Avatar
What are the xy coordinates that caused the errors?
--tom
thomasl is offline
Old 02-15-2010, 10:53 AM - Thread Starter
Liked: 562
0.314347, 0.330439 is one example.
Old 02-15-2010, 11:09 AM
TomHuffman's Avatar
Quoted: 690 Post(s)
Liked: 616
Fixed.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
Old 02-15-2010, 11:31 AM - Thread Starter
Liked: 562
Originally Posted by TomHuffman View Post
Fixed.
Nice, it works perfectly now. Is the minimal perceptible difference for CIE94 higher than 1.0 for grayscale? Using this formula, I get two points with 1.0 dE and one with 1.3 dE. Those same points are well below 2.5 and 2.0 for CIELUV and CIELAB, respectively.
Old 02-15-2010, 03:02 PM
TomHuffman's Avatar
Quoted: 690 Post(s)
Liked: 616
CIE94 and CIELAB should be the same for grayscale. CIELUV will be a little higher. What value did you test?
Tom Huffman
Springfield, MO
Old 02-15-2010, 03:12 PM - Thread Starter
Liked: 562
I tested 40%, 80%, and 100% using CIE94.
40% (0.312051, 0.327233) 1.0
80% (0.313477, 0.33081) 1.0
100% (0.311976, 0.330588) 1.3
I didn't initially notice that CIELAB and CIE94 were the exact same for grayscale. So, this means a dE under 2.0 for both formulas is ideal for grayscale? I was thrown off by the 1.0 MPD for CIE94.
Old 02-15-2010, 06:54 PM
TomHuffman's Avatar
Quoted: 690 Post(s)
Liked: 616
For grayscale 2.0 is about as good as it gets, visibly anyway. The MPD of 1.0 for CIE94 is for color only. This is because of the way CIE94 treats the relationship between lightness and chromatic errors. Since grayscale doesn't consider lightness, CIE94 and CIELAB are the same here.
Tom Huffman
Springfield, MO
Old 02-15-2010, 06:55 PM - Thread Starter
Liked: 562
Ok, that makes more sense.
