Consumer Level Disney World of Wonder (WOW) vs. DVE Blu Ray - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 451 Old 04-21-2012, 11:14 AM
PlasmaPZ80U's Avatar
Quoted: 2208 Post(s)
Liked: 663
Originally Posted by fokker01 View Post
The backlight setting is now at +3 (Max is +16) and the blacks are good but I think the overal picture is too bright even when I set the tv with the WOW disc. So I will give it a try to lower the backlight a little bit.
if the image looks too bright or hurts your eyes, lowering backlight is a good idea
this holds true even if you have a meter since there is no one right setting for light output, though generally it may fall somewhere in the 30 to 50 fL range
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #362 of 451 Old 04-21-2012, 11:15 AM
Liked: 663
Originally Posted by PlasmaPZ80U View Post
the gamma response pattern doesn't seem to really work on my LCD, my display is set to 2.2 from 10% to 90% gray in 10% increments with my C6 colorimeter but the pattern shows gamma being around 1.9
how is this pattern supposed to work and is it even possible to accurate evaluate gamma with a test pattern only (no meter)?
anyone get good results with this pattern?
post #363 of 451 Old 04-22-2012, 02:23 PM
hifi59's Avatar
I noticed the exact same thing on my Umr calibrated Pioneer kuro elite 151.
If you're talkin, you ain't learnin.
hifi59 is offline
post #364 of 451 Old 04-22-2012, 02:26 PM
hifi59's Avatar
I noticed the exact same issue with my Umr calibrated Pioneer Kuro Elite 151 that I know has a gamma of 2.21.
hifi59 is offline
post #365 of 451 Old 04-22-2012, 02:41 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
ditto. on the WOW disc i also show 1.9, but with calman im at razor flat 2.22 with my krp500m.
1forsnow is offline
post #366 of 451 Old 04-22-2012, 04:00 PM
Liked: 663
I wonder why that is. I know such patterns are no replacement for measuring/setting gamma with a meter but why does everyone have the same offset when using this pattern?
2.2 appears to be 1.9 (-0.3 offset)
post #367 of 451 Old 05-19-2012, 10:52 AM
adrift's Avatar
I have a question about the advanced brightness pattern. What does it mean that ideal black should be on the verge of being visible? Does it mean I should see something faint there or that if I was to bump up brightness one click, it would be visible. Using the brightness setting I get from the AVS disc, I see +1% but nothing at +0%.
Very faint and barley visible at all...you almost have to squint to see it there. If you can see it visible, go one click down until it is barely visible. If it is totally gone, go one click up until it is barely visible.
I have a question about this. Is it normal to not be able to see the "ideal black" star at all on some displays, no matter how much you turn up the brightness?
I'm barely able to see the darkest star on the left of the brightness pattern, but nothing on the right (no matter how bright I go), and same is true in reverse for the contrast star pattern (no matter how dark I go). I'm assuming that part of this may have to do with a no clip governor that I've seen mentioned on this thread and the other one (or at least I hope so), and I'm hoping that also explains why I can't see any bars on the right side whatsoever on the contrast test for the Beginners test pattern.
If it matters I'm calibrating with an Optoma HD20 (with an aging lamp) to an Onkyo Receiver to an HTPC.
adrift is offline
post #368 of 451 Old 05-19-2012, 11:16 AM
Liked: 663
sounds like you're clipping BTB and WTW
post #369 of 451 Old 05-19-2012, 11:47 AM
adrift's Avatar
Hmm. Well if clipping is the issue, I don't know what else to do. I've messed with the projector's brightness and contrast for hours trying to get things just right, and no matter what I do I can't see the ideal stars. Any recommendations? Could the source be an issue? I'm running 2 Nvidia GTX 460s in SLI and Windows 7.
adrift is offline
post #370 of 451 Old 05-19-2012, 12:45 PM
Liked: 663
it could be the receiver or it could be your HTPC's graphics card settings
post #371 of 451 Old 05-19-2012, 01:29 PM
adrift's Avatar
Oh. Well that sucks. :P
I guess I'll start by bypassing the receiver and see if that helps any. Thank you.
adrift is offline
post #372 of 451 Old 05-19-2012, 07:20 PM
adrift's Avatar
Well, I bypassed the receiver, and the picture doesn't really look any different. My setup is my living room, and though I have black out curtains I was trying to calibrate in what I considered pretty much "typical" lighting conditions this afternoon. Now that its night, and pretty much pitch black in my living room, when I run the disk I think maybe I can almost sorta make out the ideal star for the brightness pattern, but I don't know if its in my head or if I'm actually seeing it (no matter how high I turn up the brightness). I still can't see the ideal star for the contrast pattern.
I still haven't ruled out the possibility that clipping could be due to the graphics card settings, but the WOW manual does state that I can expect "'white clipping' behavior in...projectors with modest light output expectations", and though this is my second bulb in less than 2 years, maybe that's the issue.
adrift is offline
post #373 of 451 Old 05-19-2012, 07:42 PM
Liked: 663
can you connect a BD player to the projector to see if the issue is display or source related?
post #374 of 451 Old 05-19-2012, 08:00 PM
adrift's Avatar
I don't own a standalone blu-ray player outside of my PC's blu-ray drive, but yeah, it makes sense that would be the next logical step. I'll grab my parent's blu-ray player tomorrow and experiment. Again, thanks for your help.
adrift is offline
post #375 of 451 Old 06-25-2012, 08:17 PM
Liked: 663
When looking at the scaling and advanced scaling 2 patterns on the Disney WOW BD, I notice a pink tint on the top third of the screen and a greenish yellow tint on the remainder of the screen. The advanced scaling 1 pattern looks b/w only, like it should. What could be causing this and is it normal for a CCFL-LCD (that has been fully calibrated with meters/software)?
post #376 of 451 Old 06-26-2012, 09:55 AM
djams's Avatar
No idea if its normal, but I see the same thing on this pattern. I wondered the same thing when I did my initial run through the disc. I seem to remember that the manual states the pattern MAY appear as a solid gray screen (caps mine). And in the observation section, it said to look for artifacts (I think with an example). I saw no artifacts - and when I switched resolution from 1:1 pixel mapping, there were artifacts, so I called it good.
djams is offline
post #377 of 451 Old 06-26-2012, 12:39 PM
Liked: 663
good to know I'm not the only one who noticed this
post #378 of 451 Old 07-19-2012, 10:20 AM
Gas0linE's Avatar
Can The pixel flipper really fix stuck pixels? What would you say the success rate of it is? My first panel had a stuck pixel (green) and I returned it and got a new one that is flawless. I never knew these pixel flippers actually work.
Gas0linE is offline
post #379 of 451 Old 07-20-2012, 10:51 AM
RBFilms's Avatar
The pixel flipper will work pixels and if they are stuck ... this often helps bring them back. It will also help with Burn-In.
However, it will not always fix a stuck pixel and it will not bring pixels back from the dead.
The Pixel Flipper is NOT random noise encoded on the disc ... as t might appear.
Pixel Flipper is an actual BD Java Application that works each and every pixel individually.
Give it a try and let us know if it works.
Richard J. Casey
Disney WOW - World of Wonder
Producers Guild of America, New Media Council
(BD Industry Insider)
RBFilms is offline
post #380 of 451 Old 07-22-2012, 05:32 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 123
@RBfilms
Does Disney WOW come with Fleshtone test material? Thanks.
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #381 of 451 Old 07-22-2012, 06:50 PM
Liked: 663
Originally Posted by PeterLewis View Post
@RBfilms
it does, in the basic calibration section for adjusting color/tint
post #382 of 451 Old 01-08-2013, 12:26 PM
SeekerOne's Avatar
I had about 6 "stuck" pixels in my lg 47lm7600 grouped together near the right edge of the screen about halfway down when I first got my TV. I haven't used a pixel flipper, but they seem to have worked themselves out. They currently look nearly as good as the rest. So Id say just keep using your TV and any pixels that can be "fixed" will probly work themselves out over time. Or if you've got the flipper, give it a run and see if it speeds up the process.
SeekerOne is offline
post #383 of 451 Old 01-10-2013, 05:15 PM
RiverSide's Avatar
Quoted: 59 Post(s)
Liked: 37
Originally Posted by rsilvers View Post
Really, patterns like this should be built into the TV. But they are not.
But they are.. My LG LM7200 has built in expert patterns to set white level, black level, color and tint.
Insert pithy comment here
RiverSide is offline
post #384 of 451 Old 01-11-2013, 07:22 AM
SeekerOne's Avatar
Do you need a service remote to access those? I have the LM7600 and I got more than acceptable PQ with the CNET settings, but fi there's more I can get it even better prior to buying one of these DVDs... why not.
post #385 of 451 Old 01-11-2013, 09:58 AM
RiverSide's Avatar
Quoted: 59 Post(s)
Liked: 37
They are available in the Expert Control user menu, no service mode access required.
I don't think you can do more than what the CNET settings do; they provide the full calibration settings used to bring their LM 7600 within spec. Copying those specs is a good starting point.
I only use the LG patterns to adjust for OTA viewing; unfortunately channels do not broadcast HD test patterns to allow us to set according to their programming. For other inputs, simply use the free AVSHD patterns. If you have money burning a hole in your pocket then buy a test pattern DVD. I'll buy the first one that comes up with some novel solution to approximate correct grayscale and CMS with patterns without needing a meter.... I can dream right?
post #386 of 451 Old 01-12-2013, 04:51 PM
avswilier's Avatar
Is there a way to replace the blue filter card which I have lost(stupid I know)?
avswilier is offline
post #387 of 451 Old 01-13-2013, 06:13 AM
RBFilms's Avatar
Send me a PM...I can help you.
RIch
Richard J. Casey
RBFilms is offline
post #388 of 451 Old 02-23-2013, 08:57 AM
i8abug's Avatar
Hi all. I just got the WOW Blu ray and ran into something I have to ask about. When I run the speaker ID test on my 7.1 system the voice stays at the right front speaker when announcing the right surround and right rear surround then when it gets to the left surround speakers, they are announced through the front left speaker only. I can run the test tone on the receiver and all is well with all the speakers and I can play a movie through the same Blu ray player that this WOW disc is in and the surround speakers are functioning as they should. I checked the sound settings in the Blu ray player tools and even tried a different coax cable from the blu ray to the receiver. No difference. Is there something weird with the speaker ID function on my disc? I am not sure what to think of this. Below is a list of the components used. Thanks in advance for any answers.
Samsung BD-E5900 Blu ray player
Samsung UN55EH6000 55-Inch 1080p 120Hz LED HDTV
Onkyo HT-R530 7.1
i8abug is offline
post #389 of 451 Old 03-01-2013, 02:49 PM
limitz's Avatar
Quoted: 55 Post(s)
Liked: 24
Hello,
I have a question: I just ordered Disney WOW Calibration (2-discs) in the DVD format and am wondering if the format and its contents suitable to calibrate my HDMI Sources, such as:
My TV is Samsung UN46ES7500 and is less than one week old.
1) HTPC - DVI > HDMI
2) Xbox 360 - HDMI
3) PS3 - HDMI
The reason I chose the DVD format over Bluray is simply because out of all of my HD sources, the only one that is Bluray capable is the PS3, the other two are only DVD capable.
I do own DVE HD Basics in Bluray; it feels dated so I wanted to try something more current such as WOW.
What are the major differences between the Disney WOW DVD vs Bluray contents and their compatibilities for calibrating HD sources with HDTV, when using either DVD, Bluray format types?
Is the WOW DVD format strictly for non-HDTV's and SD sources?
What should I expect to miss out on when I receive the WOW discs in DVD compared to buying the Bluray version?
Any help is greatly appreciated.
Best regards
limitz is offline
post #390 of 451 Old 03-03-2013, 05:36 AM
RBFilms's Avatar
Basic calibration such as brightness, contrast, color, and tint will work fine. I am not sure how well sharpness will work with the upscaling / up-converting artifacts you will see when going from from DVD / SD to Blu-ray / HD.
You will also get scaling and errors on many of the test patterns. The patterns will indicate you are scaling or up converting and show a fault. This is true and the disc is working as designed. However, you will get scaling / up-conversion errors what you up-covert from DVD / SD to Blu-ray / HD.
Make sure you calibrate your DVD and BD Players as well. Look online for the best way to do that.
Here is a link for the PS3 calibration settings.
http://news.cnet.com/8301-17938_105-10022389-1.html
Hope that helps.
Originally Posted by limitz View Post
Hello,
2) Xbox 360 - HDMI
3) PS3 - HDMI
Best regards
Richard J. Casey
RBFilms is offline
Reply Display Calibration
