My Calibration for Samsung Plasma PN50C7000YF - AVS Forum | Home Theater Discussions And Reviews
Old 11-22-2010, 11:24 AM - Thread Starter
El Jorgistador's Avatar
So this is my calibration settings for my tv, using the free AVS HD 709 patch from the forums. I played the patch on my PS3 and my TV is in a living room environment. I calibrated it on Movie mode, and just ended up using the same setting for the other modes, and looks a lot better in all modes which helps when the light settings change.
Cell Light : 15
Contrast : 85
Brightness : 60
Sharpness : 30
Color : 50
Tint : G50/R50
Then under Advanced Settings
Black Tone : Off
Dynamic Contrast : Off
Gamma : 0
Expert Pattern : Off
RGB : Off
Color Space : Auto
White Balance : I did no changes just left it at 25,
10p White Balance : Off
Flesh Tone : 0
Edge Enhancement : 0
xvYCC : Off
Then Under Picture settings
Color Tone : Warm1 (w/ the exception on Dynamic I can only go as warm as Normal)
DNF : Off
MPEG : Off
Also if you have a PS3 I would follow this IGN video on the there youtube channel labeled: Optimizing Your PS3 for Blu-ray
El Jorgistador is offline
Old 11-22-2010, 11:38 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
You realize that sharing calibration numbers is not calibration at all? What works on your set up may look awful on someone else's set up.
Should set your Size from 16:9 to screen fit/just fit ...
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
