New AccuPel owner and product - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 50 Old 05-16-2012, 04:10 PM
h2c
h2c's Avatar
No nothing works on the desktop pc it works but not on my laptop !
h2c is offline
post #32 of 50 Old 05-16-2012, 04:40 PM
gregr's Avatar
Quoted: 12 Post(s)
It works on your desktop PC, is that correct?
But it doesn't work on your laptop, is that correct?
Are both desktop and laptop running the same version 7 of Windows?
Greg Rogers
Video Engineer/Product Designer
gregr is offline
post #33 of 50 Old 05-21-2012, 05:18 AM
h2c
h2c's Avatar
Yes,still nothing !
h2c is offline
post #34 of 50 Old 05-21-2012, 12:48 PM
gregr's Avatar
Quoted: 12 Post(s)
Try starting the program without any USB devices connected to your laptop and see if it comes up working in demo mode.
Greg Rogers
gregr is offline
post #35 of 50 Old 05-22-2012, 06:56 AM
h2c
h2c's Avatar
i have try an other laptop and the result is the same !
h2c is offline
post #36 of 50 Old 05-22-2012, 12:45 PM
gregr's Avatar
Quoted: 12 Post(s)
Did you try it with no USB devices connected?
Greg Rogers
gregr is offline
post #37 of 50 Old 05-30-2012, 07:33 AM
h2c
h2c's Avatar
yes, it does not matter !
h2c is offline
post #38 of 50 Old 05-30-2012, 11:16 AM
gregr's Avatar
Quoted: 12 Post(s)
Tom sent me your email address so I will contact you.
Greg Rogers
gregr is offline
post #39 of 50 Old 05-30-2012, 02:22 PM
h2c
h2c's Avatar
h2c is offline
post #40 of 50 Old 09-05-2012, 06:24 PM
ConnecTEDDD's Avatar
Quoted: 1078 Post(s)
Liked: 1546
Free Firmware update is available for the AccuPel DVG-5000 Owners (New Version 09/01/2012)
See the Support tab below for information about a new firmware update.
http://www.chromapure.com/products_accupel.asp
The latest firmware (09-01-2012) includes two new features.
• First, the levels of the surrounds in window test patterns are now user-defined. By default, windows are black, but the user can now define them for any level desired.
• Second, users can now apply a single color (RGBCYM) to any of the gray test patterns in the AccuPel, effectively creating hundreds of new test patterns.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #41 of 50 Old 02-14-2013, 12:59 AM - Thread Starter
TomHuffman's Avatar
Quoted: 696 Post(s)
Liked: 618
New Firmware available for the AccuPel DVG-5000
This firmware adds support for user-defined window sizes and checkerboard test patterns.
See the Support tab on the AccuPel page for details.
This firmware is a free download for all AccuPel DVG-5000 users. Support for the new feature will be available soon in ChromaPure.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #42 of 50 Old 03-02-2013, 06:24 AM
Koperfild's Avatar
Tom, do you ever plan to add support for 4K resolutions to DVG-5000?
Koperfild is offline
post #43 of 50 Old 03-05-2013, 09:01 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Given the processing power of an existing chassis for a VP or signal generator plus output bandwidth limitations, I would suspect any existing 2K video processor or signal generator regardless of the manufacturer could not be upgraded to 4K but would require a new chassis.
mark haflich is offline
post #44 of 50 Old 03-05-2013, 04:43 PM - Thread Starter
TomHuffman's Avatar
Quoted: 696 Post(s)
Liked: 618
We cannot simply upgrade the DVG-5000 to support 4K. That requires new hardware. So if we ever do this, then it will be a successor to the DVG-5000.
Tom Huffman
Springfield, MO
post #45 of 50 Old 03-06-2013, 12:23 PM
Liked: 1010
This sounds like a plant post, but it isn't. If AccuPel comes out with a 4K signal generator some day, do you expect that there might be a trade in program for those owning the existing 2K generators?
post #46 of 50 Old 03-06-2013, 02:33 PM
gregr's Avatar
Quoted: 12 Post(s)
Greg Rogers
gregr is offline
post #47 of 50 Old 03-06-2013, 02:49 PM - Thread Starter
TomHuffman's Avatar
Quoted: 696 Post(s)
Liked: 618
This is way too speculative and too far in the future to even consider right now. I will consider this if and when we ever release such a product.
Tom Huffman
Springfield, MO
post #48 of 50 Old 03-06-2013, 03:10 PM
Liked: 1010
That sounds like a yes. smile.gif Obviously, for people buying right now up to release if any of a 4K product they might seek some asurance that they will not be harmed by not waiting.
post #49 of 50 Old 03-07-2013, 09:03 AM
Koperfild's Avatar
Oh, i thought any 1.4 hdmi equipped device is able to output 3840×2160 signal. It`s in hdmi spec.
post #50 of 50 Old 03-07-2013, 11:32 AM
Liked: 1010
No one said it wouldn't. But it is fps limited currently. It will do 24 and 30, but if I remember correctly the bandwidth of the existing HDMI chips is not wide enough to handle more. The processing power of the generator is not sufficient to generate a 4K pattern. One needs a much more powerful chip.
Reply Display Calibration
