i1Pro Dark Readings - I Don't Get It - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-22-2011, 06:14 AM - Thread Starter
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
I have an X-Rite i1Pro, REV D model.
Last night in a light and temperature controlled room I took a series of grayscale and chromaticity measurements:
1. After dark reading
2. After 1 hour
3. After 2 hours
4. After 3 hours
5. After 2nd dark reading
Other than for the initial measurements I took no further dark readings until after the "after 3 hours" reading. In the attached jpg file I found it unnecessary to display the "after 1 hour" and "after 2 hours" results as they are essential the same as the "after 3 hours" results.
I took a few random readings just to exercise the meter a bit after the initial reading until the "after 2 hours" reading. Because no differences appeared in the readings I thought perhaps meter usage might have an effect. Between the "after 2 hours" and "after 3 hours" reading I had the meter do continuous readings throughout the hour utilizing various patterns. The end result was still no change.
As a final step I took a second dark reading. The resulting readings were the same as the rest - no significant difference.
Is the REV D model different from earlier models? Why am I supposed to be taking dark readings if no difference in accuracy can be detected?
Why the term "dark reading" when it is actually accomplished on a white tile?
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #2 of 15 Old 03-22-2011, 08:43 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
It is a dark reading, because there should be a total absence of light.
It's against the white tile, because in reflectance mode it also takes a reading with it's internal lamp turned on.
The one thing I don't see in your data is the big Y value. You are starting to see more drift down at the low end , and that is typically were you see the most drift.
If I was using a i1Pro to do grayscale, I'd stop probably every 10-15 minutes. If I was doing CMS, I might not do a dark cal for 30min or more.
Any general recommendation are for people who don't dig into the specifics. If you know how it works, then you can determine what's right for you.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 15 Old 03-22-2011, 11:56 AM - Thread Starter
buzzard767's Avatar
Liked: 2393
I see what you mean about the lower end but how significant are the differences in the before and after? Also, for what it's worth, grayscale was for test purposes. When I calibrate I profile a C5 from the i1Pro and calibrate grayscale with the C5 and color with the i1Pro. At this point a question comes to mind: Would I be just as accurate if I did color as well as grayscale with the profiled C5?
On the attached calibration report it can be seen that color dE average remains the same and the largest individual deviation is .3. Blue is .3, Red .2 and the other 4 (5 including white) is only .1 dE.
My goal is to eliminate taking down the i1Pro for dark readings if it can be avoided and with the small amount of error would it make any difference? In fact, the second attachment, "i1ProAfterDarkReadingReduced" pretty much backs me up. The before is just after the intial dark reading and the after is the result of a dark reading I took when finished after three hours. The drift is every bit as large as that with no repeated dark readings.
i1Pro Check Plus 3 HourReducedSize.pdf 251.615234375k . file
i1ProAfterDarkReadingReduced.pdf 256.3388671875k . file
File Type: pdf i1Pro Check Plus 3 HourReducedSize.pdf (251.6 KB, 77 views)
Buzz
post #4 of 15 Old 03-22-2011, 12:20 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
if you're just using the i1 for CMS, I wouldn't worry too much about doing extra dark readings.
Also you don't need to do the dark reading on the white tile, simply affixing the cap to the meter would suffice.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 15 Old 03-22-2011, 12:41 PM - Thread Starter
buzzard767's Avatar
Liked: 2393
That is music to my ears, sotti, and I thank you for the information. It's not that I'm lazy but rather just trying to avoid a PITA.
Steve Shaw of LightIllusion.com gave me the same sort of answer on the LUT thread.
Originally Posted by Light Illusion View Post
X-Rite don't actually give a time figure for recalibration of the probes, but do say they can 'vary' due to temp and other changes...
We always say to re-cal before a calibration run, after a good warm-up period, but not during a calibration run. The best is to keep temperature stable.
Buzz
post #6 of 15 Old 03-26-2011, 11:20 AM
stereomandan's Avatar
There is a general rule (not sure where it started) that the i1pro has more difficulty with accurate readings below 1 ftL.
This can easily come into play when using the i1pro for CMS work, not just grayscale. Remember that blue is only 7.2% of the 100% white reading. This means that your 100% gray reading should be 13.8 ftL or more if you want to have more confidence with your blue readings with the i1pro. It is very easy for projectors to have difficulty reaching 13.8 ftL once fully calibrated.
So the low light accuracy of the i1pro can easily come into play with CMS, not just grayscale.
Now, having said that, this is what I did to resolve that issue. I got a nice size sample of my screen material and hung it much closer to my projector, roughly 3-6 feet away. (a 12" x 12" sample is plenty big). This raises the light output significantly reflecting off the screen material. Then, use your i1pro to read off the small screen material sample. Just make sure to keep the 100% white reading below 300 cd/m2 (87.5 ftL) to prevent oversaturating the meter. This allows for accurate readings, even with 10% grey readings and blue readings. (both of which can be problimatic with the i1pro).
Since the small screen material is the same as your large screen, the results will be spot on for the large screen as well.
I'll probably post this information in a seperate post to help others that have an i1pro, since it has worked great for me and I'd like to share the information.
Dan
stereomandan is offline
post #7 of 15 Old 03-26-2011, 03:09 PM - Thread Starter
buzzard767's Avatar
Liked: 2393
A comment: Looking at this attachment, the GS numbers after 3 hours with no dark readings followed by those of a subsequent dark reading are close to the same and seem to indicate that it was the display that had the shift, not the meter. Is that normal/possible? The display is an LCD that had a one hour warm up before I started.
Buzz
post #8 of 15 Old 03-27-2011, 09:35 AM
Looks very stable to me. Seems as though you may be able to leave the meter up for your calibration run based on your results.
Dan
post #9 of 15 Old 04-27-2011, 10:15 AM
lodolfan's Avatar
Quoted: 240 Post(s)
Liked: 164
Is it safe to say we can get away doing the same with a DTP-94 meter?
PSN:Lodolfan16
XBL: Lodolfan16
LordXarsNexus to Shmoopy- "We're not playing Soccer, we're playing Rocket League!"
lodolfan is offline
post #10 of 15 Old 04-27-2011, 11:31 AM - Thread Starter
buzzard767's Avatar
Liked: 2393
It may have been my particular meter. It's easy enough for you to test yours.
1. Perform dark reading and take measurements.
2. Wait for some amount of time.
3. Take measurements.
4. Perform dark reading and take measurements.
If 1=3=4 then readings beyond the initial one not required.
If 3=4 but not =1 then the display has shifted.
If 1=4 but not =3 the meter has shifted and requires frequent calibrations.
The 3=4 but not=1 sample for my meter found max difference to be .002 and that was on only two of the 20 separate measurements, the rest being = or +/- .001. It's not like I'm calibrating studio monitors or something so that's close enough for me.
Buzz
post #11 of 15 Old 04-27-2011, 11:35 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Also you'll see bigger changes down at 10% or even 5%
The recommendations from us are based on the worst case scenario. The timers are there as a guideline, we don't require you to redo dark readings.
Joel Barsotti
SpectraCal
sotti is offline
post #12 of 15 Old 04-27-2011, 11:56 AM - Thread Starter
buzzard767's Avatar
Liked: 2393
I'm sure that is true. Since my first post in this thread Tom Huffman has advised that once a Chroma 5 is profiled to an i1Pro there is no reason to use the i1Pro. Consequently I now do both GS/Gamma and CMS with the C5.
My original test is with one i1Pro meter on one display over one time period. If anyone does a similar test with their meter I'd love to see the results posted here. My meter and test could be a fluke.
Buzz
post #13 of 15 Old 11-10-2012, 08:08 AM
p5browne's Avatar
Quoted: 2794 Post(s)
Liked: 2117
Despite profiling the i1Pro to the C5, the i1Pro will still give a better calibration!
After doing a profiled calibration, go back and read your results with the i1Pro. If Tom is correct , the results should be nearly identical. If not, maybe it's time to upgrade to a newer Meter to profile to.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #14 of 15 Old 11-10-2012, 08:28 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Buzzard, another thing you can do if you have not, is in calman, set the i1pro side button to do initialization. Then all you need to do is cover the hole and hit the button.. done.
NOTE: the button will not work if you have the initialization screen up..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #15 of 15 Old 11-10-2012, 09:22 AM - Thread Starter
buzzard767's Avatar
Liked: 2393
No, not always. I'm into real 65x65x65 3D LUTs produced from 17 point (4913 reads) profiles and a lot of these reads are very low luminance beyond which the i1Pro can read with any level of accuracy. I don't need to go back and reread. First I take "before" measurements with the i1Pro, then I profile, then I take "after" reads with the profiled meter. The report is my comparison. One needs nothing more than that. New meter? I'm using a Klein K10-A. New enough? wink.gif
I have the X-Rite tripod doodad. Time for a dark reading, slide the switch, take dark reading, reset the slide.
For the time being my tests are valid. I've asked others to try the same thing but nobody has....
Buzz
Reply Display Calibration
