X-Rite's Revolutionary New Colorimeter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1402 Old 06-19-2011, 11:14 PM - Thread Starter
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
X-Rite has developed a new and I think ground-breaking colorimeter, the i1 Display Pro III, which most will probably refer to as simply the Display 3.
It is not simply an update to the Display 2. It is a completely different design with an unprecedented price/performance ratio.
For a full review and online demos, see the ChromaPure web site.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #2 of 1402 Old 06-20-2011, 06:10 AM
ConnecTEDDD's Avatar
Quoted: 1672 Post(s)
Liked: 2083
Truly Amazing Performance For The Price! I Will Pre-Order it for sure!
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 1402 Old 06-20-2011, 06:23 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
Out of curiosity, I see in your signature line that you already have a Chroma 5. Is the increase in read speed your reason for a new meter?
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #4 of 1402 Old 06-20-2011, 06:49 AM
Liked: 2083
Mainly, The Lower Light Reading & The Repeatabily @ Very Low Levels Is The Reason.
I Want To Set More Accurate The 1,2,3,4% Patterns For My Pioneer KURO Using AVFoundry VideoEQ PRO.
Using VideoEQ You Can Add Grayscale Control Points With RGB Control Whenever You Like. 0.5% (RGB Level 17), 1% (RGB Level 18)...etc...Anywhere You Can Control.
Setting Correct the Levels Of Grayscale 1-5% (Not Only To Be Visible Using Reference Brightness Patterns But Setting The Correct Luminance For Each Step Of These Levels, Then You Will Have An Image With Greater Depth.
post #5 of 1402 Old 06-20-2011, 06:56 AM
buzzard767's Avatar
Liked: 2438
Mainly, The Lower Light Reading & The Repeatabily @ Very Low Levels Is The Reason. I Want To Set More Accurate The 1,2,3,4% Patterns For My Pioneer KURO Using AVFoundry VideoEQ PRO.
Ah. Makes sense.
"The Chroma 5 is rated down to 0.01 cd/m2 and this seems about right. However, the Display 3 will read light that is one-third as bright."
Buzz
post #6 of 1402 Old 06-20-2011, 07:11 AM
Liked: 2083
With My KURO, I'm using Chroma 5 @ CRT Mode Only. I Have By Far Greater Repeatability @ Luminence Readings Using This Mode, More Stable.
Chroma 5 Reads 0.025-1000 cd/m2 Using CRT Mode.
post #7 of 1402 Old 06-20-2011, 07:13 AM
Chad B's Avatar
Quoted: 567 Post(s)
Liked: 1327
Sounds sweet! Thanks Tom.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #8 of 1402 Old 06-20-2011, 07:58 AM
Liked: 2083
post #9 of 1402 Old 06-20-2011, 08:35 AM
janos666's Avatar
Quoted: 23 Post(s)
How does it behave on WCG displays? Does it need unique correction matrices for the usual PDPs? I guess they do but who knows...
"DIY certified hobby-calibrator" (based on ChadB's "warning signs" list
janos666 is offline
post #10 of 1402 Old 06-20-2011, 08:42 AM
Chad B's Avatar
Quoted: 567 Post(s)
Liked: 1327
Tom, does it put much if any physical pressure on the screen when using the counterweight in contact mode? I'm wondering if it will be OK with sensitive LCD screens.
post #11 of 1402 Old 06-20-2011, 08:44 AM - Thread Starter
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
It is very light weight, so I doubt that this would be a problem. I would use it in the non-contact mode in any case to avoid the problem altogether.
Tom Huffman
Springfield, MO
post #12 of 1402 Old 06-20-2011, 08:45 AM
Liked: 2083
I read these information about i1Display PRO @ Xrite Brochure....
Support for new & emerging display technologies: CCFL, White LED, RGB LED, Wide Gamut, New Future (field Upgradable)
post #13 of 1402 Old 06-20-2011, 08:48 AM
Liked: 2083
post #14 of 1402 Old 06-20-2011, 09:38 AM
janos666's Avatar
Quoted: 23 Post(s)
Sounds like I have a ColorMunki Photo to sell and a new toy to pick up.
It looks like their X-Rite product names are i1Display Pro and ColorMunki Display.
I wonder if there is any physical difference (between the Pro and non-Pro) except the case color. I don't wish to use their bundle software anyway.
According to this PDF, they use different software (no problem) but another difference that the faster measurement mode is only available with the Pro. But it still could be a limit on the software side (may be driver level) and I think I wouldn't use it anyway. (It's not a bad idea to give some time for the temporal dithering.)
janos666 is offline
post #15 of 1402 Old 06-20-2011, 10:35 AM
AtDaBeach's Avatar
Whats the thought on selling an I1 pro, and using this model for 100% of the time?
AtDaBeach is offline
post #16 of 1402 Old 06-20-2011, 10:45 AM
millerwill's Avatar
Quoted: 510 Post(s)
Liked: 305
Tom, Will it still be advisable to do the 'color correction' step in ChromaPure, using an I1Pro to correct the Display3?
millerwill is online now
post #17 of 1402 Old 06-20-2011, 10:55 AM
janos666's Avatar
Quoted: 23 Post(s)
Does it have a temperature sensor?
janos666 is offline
post #18 of 1402 Old 06-20-2011, 10:58 AM - Thread Starter
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
Couldn't hurt.
Tom Huffman
Springfield, MO
post #19 of 1402 Old 06-20-2011, 11:01 AM - Thread Starter
TomHuffman's Avatar
Quoted: 782 Post(s)
Liked: 667
A non contact device has no need for this.
Tom Huffman
Springfield, MO
post #20 of 1402 Old 06-20-2011, 11:05 AM
AtDaBeach's Avatar
I like the non contact design, and already have a tripod. I'd also prefer a meter that did not require profiling. I know you say "couldnt hurt", but do you feel it's everything the C5 is and better, and could actually allow a stand alone device for the $1200 and down group?
post #21 of 1402 Old 06-20-2011, 11:36 AM
janos666's Avatar
Quoted: 23 Post(s)
Yah, sure. I use even my colormunki in non-contact setup. But it requires a pitch black room.
janos666 is offline
post #22 of 1402 Old 06-20-2011, 11:46 AM
Liked: 2083
I saw that Tom has removed Chroma 5 Standard & PRO from ChromaPure Software Configuration Options and from Online Orders Page Also.
Maybe a benchmark of Klein K-10 vs. Chroma 5 & i1Display 3 will give a lot of answers to all for low light handling accurancy.
By-The-Way Does i1Display 3 include any certificate of performance like i1PRO?
post #23 of 1402 Old 06-20-2011, 12:33 PM
buzzard767's Avatar
Liked: 2438
Are dark reading required?
Buzz
post #24 of 1402 Old 06-20-2011, 12:40 PM
Liked: 2083
http://www.chromapure.com/products-d3.asp
''It is also one of the easiest devices to use because it requires no dark reading calibration. ''.....Tom Huffman
post #25 of 1402 Old 06-20-2011, 12:56 PM
millerwill's Avatar
Quoted: 510 Post(s)
Liked: 305
Tom, I don't understand the 'pricing': what I see is the Display3 bundled with CP software. Is this also the price if one already has the CP software (the Pro version)?
post #26 of 1402 Old 06-20-2011, 12:59 PM
buzzard767's Avatar
Liked: 2438
$269 + $10 according to an email I received from Tom.
Buzz
post #27 of 1402 Old 06-20-2011, 01:01 PM
AtDaBeach's Avatar
Nice. I'm thinking of selling the I1 and using this exclusively, in the Pro version.
post #28 of 1402 Old 06-20-2011, 01:03 PM
buzzard767's Avatar
Liked: 2438
In my case it makes more sense to sell my C5, not the i1Pro. The D3 is no more accurate than the C5 so will still need to be profiled.
Buzz
post #29 of 1402 Old 06-20-2011, 01:04 PM
AtDaBeach's Avatar
Thats what Im curious about. Is 0.006 splitting hairs, or substantial.
post #30 of 1402 Old 06-20-2011, 02:03 PM
janos666's Avatar
Quoted: 23 Post(s)
Is it a fact (did anybody compare the readings on a WCG display yet?) or only an assumption (based on the fact that it's a 3-stimulus colorimeter)?
I am wondering if the X-Rite software applies some kind of generic corrections for the given WCG-CCFL/LED/etc displays based on the EDID information? (Something like the Quato iColor software does?) Or it is really capable of working on WCG displays?
My i1LT was useless on my WCG-CCFL LCD display (Dell U2410 , > AdobeRGB or the integer encoded CIE Lab) but one of my friends had a freshly re-calibrated i1d2 (they just sent it back from Switzerland, it was about 2010.05.xx) which is actually worked on that display. It looked right and I could check it back some weeks later with my freshly bought ColorMunki. The WP showed an acceptable and usual deviance only (not bigger than a drift which could happen after I moved the display to a different location with different room temperature and some weeks passed...) So, I think these colorimeters could work relatively well on any display.
It could be a coincidence but I am optimistic about these new colorimeters. May be they will be accurate inside the integer encoded part of CIE Lab if not further.
But yah, may be everybody should wait with the "big online auction of the spectros" until it's tested on various displays.
janos666 is offline
Reply Display Calibration
