Calibration for D8000 Samsung through Pioneer VSX-1125 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 07-18-2011, 07:22 PM - Thread Starter
phoenix_ashes's Avatar
First time calibration.
I am having my new 55D8000 ISF video calibrated at the end of the month.
As I am set-up I run my blu-ray (sony BDPS570) and my PVR, (motorola DCX3400) through my receiver (pioneer VSX-1125-K) with a single input into the ARC HDMI port on the TV.
I would like to create 2 different calibrations on the tv - one for tv viewing, and one for movies.
Is calibration done only on the tv or does the receiver need to be calibrated as well?
phoenix_ashes is offline
post #2 of 30 Old 07-19-2011, 09:36 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Only on the TV. Pioneer receivers don't tend to have any calibration adjustments.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #3 of 30 Old 07-19-2011, 10:52 AM - Thread Starter
Have you had a chance to calibrate a d8000 yet? Does the 3D need to be calibrated seperately, or does the tv adjust to 3D content for the best image quality?
Also how does one have two movie settings? One for THX calibration and one for ISF?
post #4 of 30 Old 07-19-2011, 02:33 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Yeah, I have. Yes, 3D needs to be done separately.
It will only remember one movie mode setting for 2D and one for 3D. THX and ISF calibration are essentially the same; no need for different memories for them.
Chad B is offline
post #5 of 30 Old 07-19-2011, 02:51 PM
PlasmaPZ80U's Avatar
Quoted: 2316 Post(s)
Liked: 716
On my D550 there was an advanced section in the service menu and pressing 0-0-0-0 on the remote showed two options that were grayed out: "Picture_2d" and "Picture_3d." Are these available on some high end sets like the D8000 and what do they contain?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #6 of 30 Old 07-20-2011, 06:59 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
I wasn't able to get the 0000 trick to do anything on the D8000.
Chad B is offline
post #7 of 30 Old 07-20-2011, 07:12 AM
Liked: 716
So, it didn't even have the "Advanced" section at all?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #8 of 30 Old 07-20-2011, 07:30 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Not that I remember.
Chad B is offline
post #9 of 30 Old 07-20-2011, 06:09 PM - Thread Starter
So, my receiver says that it is THX certified - I take that to mean that the receiver is capable of rendering audio and video content that will meet the requirements that a THX film would demand, in terms of color, blacks, convergence, etc. without any loss or degraded quality - It uses the Marvell Advanced Qdeo 1080p/24fps Scaler for video.
I just want to make sure that the passthrough will be accurate to the disc content when the tv is calibrated...
post #10 of 30 Old 07-20-2011, 06:26 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Every HDMI equipped Pioneer receiver that I've used is accurate with the HDMI video (no degradation).
Chad B is offline
post #11 of 30 Old 09-10-2011, 09:30 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
I was able to get the advanced section to show up in the menu using a factory remote emulator but entering this section doesn't do anything and '0000' would not activate it. After I enter '0000' the service menu goes off and then back on again. btw, the emulator trick opens up many additional options under the other menu items (Control, SVC, etc.)
zoyd is offline
post #12 of 30 Old 09-10-2011, 02:36 PM
Liked: 716
where can I find this emulator?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #13 of 30 Old 09-10-2011, 02:49 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
From this post by zoyd.
http://www.avsforum.com/avs-vb/showt...3#post20881243
It's in German. (The program -- not zoyd's post. )
Larry
LarryInRI is offline
post #14 of 30 Old 09-10-2011, 03:37 PM
zoyd's Avatar
Liked: 1064
I was hoping to disable the gamma shifts in the advanced menu just to see how it affected performance but haven't been able to get into it yet.
zoyd is offline
post #15 of 30 Old 09-11-2011, 05:21 PM
Liked: 716
Larry
Does this let you access WB Movie? Also, once you're in can you use the regular remote to navigate or must you stick with the emulator? BTW, does an English version exist?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #16 of 30 Old 09-11-2011, 05:22 PM
Liked: 716
what do you mean by this? what gamma shifts?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #17 of 30 Old 09-11-2011, 05:25 PM
zoyd's Avatar
Liked: 1064
No, WB movie is under the (currently not accessible) advanced menu.
Yes, regular remote works for navigation.
No English version but the emulator tab is easy to navigate once connected.
zoyd is offline
post #18 of 30 Old 09-11-2011, 05:29 PM
zoyd's Avatar
Liked: 1064
Variable Y response to average video level (part of samsung's DNIe) can be disabled in the advanced menu
zoyd is offline
post #19 of 30 Old 09-11-2011, 05:29 PM
Liked: 716
In that case, are there any other useful calibration tools/menus that get unlocked via this emulator?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #20 of 30 Old 09-11-2011, 05:31 PM
Liked: 716
do you mean auto dimming/CE dimming?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #21 of 30 Old 09-11-2011, 05:32 PM
zoyd's Avatar
Liked: 1064
Not for calibration, no. Need advanced menu.
zoyd is offline
post #22 of 30 Old 09-11-2011, 05:41 PM
zoyd's Avatar
Liked: 1064
It's more involved than simple contrast enhancement and done to achieve a different effect on plasmas. The distribution of all Y gray levels is adjusted based on APL, low APL=lower gamma=more shadow detail in bright environments
zoyd is offline
post #23 of 30 Old 09-12-2011, 01:16 PM
Liked: 716
I was able to access the additional areas without a problem and took the opportunity to disable the Eco Sensor and Natural Mode, both of which I never use. The only thing that confused me was the various prompts that show up the first time I started the emulator. Starting it a second time was fast and automatic. I have the D550 LCD, BTW.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #24 of 30 Old 09-12-2011, 01:34 PM
zoyd's Avatar
Liked: 1064
Were you able to access the "Advanced" menu? Items in here include things like:
BM_slope
BM_start
BM_start_max
Lfunc_gain
Hfunc_gain
ACR-Offset
Skin-UV
FBE Sub color
M-Skin-UV
M-Sub Color
N_Skin_UV
N_Sub_Gamma
Color Gamut
and W/B Movie
zoyd is offline
post #25 of 30 Old 09-12-2011, 02:29 PM
Liked: 716
BM_slope
BM_start
BM_start_max
Lfunc_gain
Hfunc_gain
ACR-Offset
Skin-UV
FBE Sub color
M-Skin-UV
M-Sub Color
N_Skin_UV
N_Sub_Gamma
Color Gamut
and W/B Movie
nope, though advanced has always showed up on my D550 LCD (even without the emulator trick) but when I press 0000 only two grayed out options appear: Picture_2D and Picture_3D
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #26 of 30 Old 09-12-2011, 07:05 PM
zoyd's Avatar
Liked: 1064
Yep, those fields I mentioned are under the picture_2d menu. I can't even get them to appear grayed out.
zoyd is offline
post #27 of 30 Old 09-13-2011, 09:03 AM
Liked: 716
Has anyone been able to enter the advanced menu on the C and D series models yet? I would really like to use WB Movie.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #28 of 30 Old 09-15-2011, 05:40 AM
janos666's Avatar
Quoted: 23 Post(s)
They show up on my PS51D550 if I hit 0000 on the Advanced menu. However, they disappear again if I hit Factory and 3Speed (and they still show up as gray if I hit 0000 again in the factory mode SM).
I can't even get into the Expert menu, not to mention the advanced Picture_2D.
"DIY certified hobby-calibrator" (based on ChadB's "warning signs" list
janos666 is offline
post #29 of 30 Old 09-22-2011, 03:34 PM
Liked: 716
I just bought the service manual for my LN32D550. Hopefully, it should show how to enter the advanced portion of the service menu via a factory remote (or the emulated version of the factory remote in my case). I will report back if I find anything useful in the manual.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #30 of 30 Old 09-23-2011, 09:55 AM
Liked: 716
no luck, just found out that you can press info then factory while in the user menu to directly jump to the unlocked version of the service menu (no need to follow the previous procedure detailed above)
SM.doc 42.5k . file
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
Reply Display Calibration
